08-26-2021, 08:19 PM | #1 |
Rep 62
New M340i oil changes
Hi everyone. I just bought a new 2021 M340i. I see mixed opinions on here about oil change intervals. Some say to do what BMW says and change every 10k miles (or whenever the sensor says to do it) and other say to do every 5k.
The new car maintenance coverage comes with 3 years/36k free oil changes, which is basically three of them. My plan is to do them myself at 5k and then go get the free one at the dealer at 10k, and repeat the process. Do you guys think this is reasonable? Also I am concerned about how the oil sensor lets me know that it's time to go to the dealer for an oil change. For example, right now it says "next service in 9800 miles". If I change the oil at 5k, is it going to extend the service notice or is that pre-programmed? Also, will the dealer know that I changed it at 5k based on the oil sensor. I'm sure the oil will be black in color. |
08-27-2021, 08:18 AM | #2 |
Rep 853
Drives: 2020 BMW M340i xDrive
I think this is a topic I feel fairly confident on speaking to after some time asking my own set of questions.
First things first, if you're leasing, stick with the free BMW maintenance. Full stop. If you're owning, continue reading. Entirely your prerogative however frequent you want to change your oil. If you're not tracking the vehicle regularly, that may be a bit overkill. But again, your prerogative. Instead of a dipstick, we get an oil level sensor. That's all it does. It's not the oil sensor that notifies you of when you need to change the oil. It's iDrive, specifically the service internal counter. It'll take into account the default change interval, and modify it based on how you operate the vehicle. It may shorten it if it picks up you're driving around a lot. You can change the oil as many times as you want, but the service interval message isn't going to change unless it's been reset. Again, it's just a level measuring sensor. It's not going to tell the dealership that you've changed the oil. The color and the overall appearance of the oil may give away that it's fresher than what should be in there at 10K. But the dealership will more than likely not care. Unless you filled with the incorrect oil spec, the engine craps out, and you want to utilize the warranty. From what I've been able to understand, the recommended BMW oil to use is BMW Longlife-01 FE, Longlife-14 FE+, or Longlife-17 FE+, 0w20 or 0w30. Those oil specs are tailored for fuel efficiency (hence the FE) and not necessarily engine longevity. If you're leasing, screw it. Just let the dealership deal with it at whatever interval and enjoy the free Wi-Fi in the waiting area. But if you're owning, your better bet is to switch to BMW Longlife-01 or Longlife-04 as those oils are more suited to protect the engine at the cost of a couple MPG. There's a few threads that go into detail as to why that is. Search for posts by "edycol". Long post, but congratulations on the car! It may seem logical to inundate yourself with keeping with the service and whatnot cause it's a BMW and what they're known for. But these newer engines are beasts, and are more like teenagers than geriatrics. Just keep the tank full and drive with a heavy foot. The car will love you for it. |
08-27-2021, 07:59 PM | #3 |
Rep 62
Thank you so much for your reply, it definitely lowered some of my anxiety on this oil thing.
So I have a 2021 which means I have the GPF (i couldnt find where to confirm it officially). From what I understood, I should use LL-04 0W-20. After reading all these other posts combined with youtube comments saying the same thing, I am confused. I see so many posts saying that 0W-20 is garbage and it doesn't provide the adequate lubrication. So, they recommend 0W-30 or 5W-30. I completely understand this from the technical standpoint. However, I am terrified to go against the owner's manual because of potentially losing my warranty. I don't mean to sound too much like an amateur but this is my first BMW ever and knowing how expensive it is to fix just deters me in this case. What brand and viscosity would you recommend? Also if the free oil changes at the dealer are 0W-20, would mixing viscosities every other oil change be harmful? |
08-27-2021, 08:37 PM | #4 | |
Rep 1,485
If planning to keep vehicle, use LL04. LL04 doesn't come in 0W20 flavor. It comes in 5W30 or 5W40. Grade is not important as the fact you should stick to LL04 specification. There are numerous oils to choose from, but most convenient and really good one would be Pennzoil Platinum Euro L 5W30 going for $22 for 5qt in your local Wal Mart. |
BMWRNMD15.50 |
08-28-2021, 08:17 AM | #5 |
Rep 2,699
Drives: 23 X5MC
I am not concerned about the oil changes. The car usually prompts me to change at about 6-8k miles. When I first had the car I had to add a quart between changes. Now that I have about 30k on it it seems to need less. The oil and the car are designed to up to 10k miles between oil changes. Besides they are free up tp 36k miles, as many as the car calls for.
BMWRNMD15.50 |
08-28-2021, 09:05 AM | #6 |
Rep 95
ultrared93103.00 |
08-30-2021, 06:46 AM | #7 | ||
Rep 853
I second the Pennzoil Platinum Euro L recommendation. Mostly because that's what I bought to put in the car next weekend. I'm still under free maintenance, but I'd rather get better oil in the car sooner than later. |
BMWRNMD15.50 |
08-30-2021, 10:22 AM | #8 | |
Rep 62
08-30-2021, 10:27 AM | #9 |
Rep 853
Oh no, I'm not using the dealership changes at all. Doing my own changes with 5w30 from here on out. I believe there's folks on here that do swap viscosities as needed from time to time. Some will use a heavier oil for hard tracking then swap down for day to day, or seasonal fluctuations.
BMWRNMD15.50 |
08-30-2021, 11:17 AM | #10 | |
Rep 62
So I guess in this case (as with most mods) it's a "do it at your own risk" type of thing right? (even though technically there should be no issues) |
08-30-2021, 11:40 AM | #11 | |
Rep 853
Pennzoil Platinum Euro L is still BMW Longlife-04 approved oil. In Europe, oil spec is LL04 for the B58. BMW specifies 0w20 for use in NA to comply with CAFE/EPA, as lighter oil is more fuel efficient. Same engine, just different requirements. So you're not "breaking" anything on the engine by switching your engine oil. Last edited by k4sh_90; 08-30-2021 at 11:47 AM.. |
08-30-2021, 12:11 PM | #12 | |
Rep 62
k4sh_90539.00 |
08-30-2021, 12:25 PM | #13 |
Rep 853
08-30-2021, 05:17 PM | #14 | |||
Rep 1,485
B48/58 engines, like all engines can take any grade. But remember fellas, grade is irrelevant, approval is what matters! BMW like all European manufacturers base oil approvals on HTHS (High Temperature High Shear) not grade. LL01 and LL04 are minimum HTHS 3.5cp. HTHS? Resistance of oil to temporary or permanent loss of viscosity. Higher HTHS, more resistance. But, you don't want to go crazy in that department. Higher HTHS=worse mpg. Someone mentioned mixing grades. That is fine. One of API requirements is for oils to be able to mix; different oils and different grades. |
09-07-2021, 11:52 AM | #15 |
Rep 853
Topped off the engine with Pennzoil Euro L 5w30 this last weekend. So far so good on the engine. Been trying to run the engine a little hard in my daily driving, something that's quite a bit more entertaining since I installed the Dinan axle-back exhaust.
BMWRNMD15.50 |
09-08-2021, 12:24 PM | #16 | |
Rep 62
Also I just watched a video of that exhaust and it sounds amazing! I definitely like the sounds more compared to MPE. |
09-08-2021, 09:20 PM | #17 | ||
Rep 1,485
Thicker oil will achieve operating temperature faster as resistance is higher. However, at much lower temperatures 0W20 will flow better. At KV40 (kinematic viscosity at 40c) 0W20 will flow better and in case of let's say need for WOT, will provide bit faster lubrication. IMO, flow of 5W30 oils that are LL04 is sufficient for proper lubrication in cold months in lower 48. In Alaska or Canada, like Edmonton, 0W20 might be better choice during winter. |
BMWRNMD15.50 |
09-09-2021, 06:50 AM | #18 | |
Rep 853
To double what edycol said, the car doesn't need to be driven harder due to the oil. It's been me having a want to drive the car hard. It is a BMW after all. |
BMWRNMD15.50 |
09-09-2021, 07:05 PM | #19 | |
Rep 62
How much oil does the M340i take? (I think it should be the same for 2020 and 2021). It seems like BMW withheld the majority of specifications in the owner's manual. I could only find oil type but not capacity. Do you know of any reliable source for spec info on this car? |
09-09-2021, 07:20 PM | #20 | ||
Rep 853
I took a screenshot off the Driver's Guide app regarding oil types. It does say to only use LL-01 FE, LL-14 FE+, or LL-17 FE+. The FE spec is for NA to satisfy CAFE requirements for fuel efficiency. But using LL-04 is for engine lifetime.
09-09-2021, 07:22 PM | #21 |
Rep 853
For more detailed (emphasis on detailed) information about maintenance for the M340i, check out this post.
Service manual for the G20: https://www.bimmerpost.com/forums/sh...php?p=27587923
10-02-2021, 08:32 PM | #22 |
Rep 6
Drives: 2022 M340i xDrive
I just leased a new 2022 M340i. While I do the oil changes on my other 3 vehicles, this BMW will go to the dealer for the FREE oil changes! The NO maintenance for 3 yr/36K miles helped seal the deal.
MattEcho53.00 |
