Technical Topics B48 4-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications Who has the quickest G20 330i on Bimmerpost?
      02-10-2021, 12:09 AM   #133
viper1ts
viper1ts's Avatar
Drives: 2020 330i Msport
Your map 3 times are impressive! Best I've gotten with map 3 was 13.14s IIRC. But that was a one off. All other runs have been in the 13.2s range.
Is yours an xDrive or RWD? Also, what is your trap speed at the quarter mile? Do you have the EWG connector?
It's RWD, and trap was 104.9.
No EWG yet but I've been following what you've been doing with the custom map and definitely intrigued.
      02-10-2021, 12:25 AM   #134
VipinLJ
VipinLJ's Avatar
Yes. Post your logs in the N54tech website and see what Terry and the others say. And then you can go from there. Lots of helpful people there. I'm sure you'll be able to get better numbers than me. And the EWG connector helps too.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      02-21-2021, 07:09 PM   #135
pdbmw
pdbmw's Avatar
Drives: BMW 2019 G20, WRX 2019
2019 330i xdrive  [0.00]
2020 X3 M40  [0.00]
Torque pro reliable to measure 0 to 60MPH?
How reliable is Torque Pro to measure 0 to 60MHP? I have installed RC tuning on Sport mode, running sport+ mode (via Bimmercode) and I've got 4.8s (picture below). It is a little bit cold here (around 24F) but not too slippery.
      02-22-2021, 09:05 AM   #136
vTuga
vTuga's Avatar
Portugal
92
Drives: 2020 BMW 330e G20
I don't think it's accurate. But I'm curious what the results with a draggy would be. Is that the Race Chip GTS?
      02-22-2021, 10:19 AM   #137
VipinLJ
VipinLJ's Avatar
Does torque pro read from a dongle attached to the OBD port? If so, it probably reads the values from the ECU which are inaccurate.
      02-22-2021, 07:51 PM   #138
pdbmw
pdbmw's Avatar
2020 X3 M40  [0.00]
Yes, this is a RC GTS. I'm very surprised with the results as I was getting around 5.2s before. I'm going to experiment with changing the settings to 'RACE' mode on the RC to see if there is an improvement. And it is still snowy here - so I expect to at least get a few ms better. I believe torque pro reads from the tablet sensors (Samsung in this case) - so may not be accurate but cannot be off for more than some ms either - I think.
      02-22-2021, 09:47 PM   #139
VipinLJ
VipinLJ's Avatar
Hmmm .I'm not sure. I know my phone GPS readings vary a lot. I've had cases where it says 7.xs in one run and the very next run, it says 4.4xs when nothing has changed. Dragy is extremely accurate. You can't use phone apps for a before and after because of the variation.
      02-24-2021, 09:20 PM   #140
JTYAMSHAYIN
JTYAMSHAYIN's Avatar
Drives: BMW 330i
@VipinLJ curious what's been your quickest time on the custom map with just 93 octane?
      02-24-2021, 11:46 PM   #141
VipinLJ
VipinLJ's Avatar
I don't think I can run my custom map with only 93oct. I'll have timing problems because of the boost and reduced octane rating. Which is why I run ~E25 religiously.
When I can't find any E85 near me (like say, when I'm far away from home and run out of fuel, which happened once), I run map 3 till I get home and fill E85.
With map 3 and 93octane, my car used to do 13.3-13.4s quarter miles and 5.1-5.2s 0-60s.
      02-25-2021, 04:53 AM   #142
vTuga
vTuga's Avatar
Portugal
92
That’s pretty close to my 330e with the ventura box in map 5.
Right now I took the box off to take the car for diagnostics (because of those codes were still there). BMW scanned and tested the car and said everything is fine, the codes must have been temporary and for some reason carly was still showing them. Very nice service from my dealership, charged me nothing and even cleaned and washed the car for free.
      02-25-2021, 12:47 PM   #143
VipinLJ
VipinLJ's Avatar
Did you mail the Ventura guys regarding the codes? My JB4 hasn't thrown any codes except for a few low fuel pressure codes a while back. Cleared those and it went away. I've also taken the car in for service after that, after uninstalling the JB4 and they said my car was clean. No codes and no flagging
      02-26-2021, 07:05 AM   #144
vTuga
vTuga's Avatar
Portugal
92
Yes I’ve been in touch with them. At first they told me the codes should be temporary. But then as they didn’t disappear they started to think it might be a fault with the camshaft sensor, and even offered to send me a sensor for me to replace. I decided to first take it to service to confirm the issue, and it came out clean. So no need to replace anything.
VipinLJ1941.50
      03-19-2021, 08:10 AM   #145
DawnRacer
Sweden
51
Drives: G20 330i M-Sport
The snow has melted around here so I did a quick 0-60 run on Nokia 18' 225 winter tyres. Putting the summer wheels on Monday so I wanted to check the difference. (Sadly there's no flat roads where I live long enough for 1/4m)
My car was remapped at a local tuning shop. Didn't have a Dragy before so unfortunately I don't know stock performance.
It's a 330i m sport - RWD
VipinLJ1941.50
      03-19-2021, 09:16 AM   #146
bquatt
Drives: 2020 330xi m-sport
Would definitely expect to see better numbers out of a flashed 330. Those are stock #s. Traction issues?
      03-19-2021, 09:23 AM   #147
DawnRacer
Sweden
51
Yes definitely, winter tires have terrible traction on dry roads, I'm fully expecting to get below 5s with summer rubber.
bquatt218.50
      03-19-2021, 12:40 PM   #148
VipinLJ
VipinLJ's Avatar
Those times might appear to be the same as stock. But it depends on your car. My car did 0-60 in 6.1s stock.
Plus poor performance from the winter tyres and reduced grip wouldn't have helped. I'm looking forward to numbers with summer tyres on and better weather conditions. I also hope you find a road to do 1/4 mile runs. 100-200kmph is the best to know how much power a car actually makes.
Probably traction issues. Plus winter tyres. Definitely don't help. My car did much worse when it was stock.
      03-20-2021, 02:35 PM   #149
bquatt
Just took a long trip on the PA turnpike today and I just needed to make an admiration post for this car. My car is completely stock but it still pulls so nicely, even up to 120-130 mph, especially considering that it's a 2.0 turbo 4. I truly feel like a stage 1 flash would make this car a unicorn DD. It's close enough to that already Hope you all are enjoying the car as much as I am!
      03-20-2021, 06:42 PM   #150
DawnRacer
Sweden
51
Yeah, stock performance is already seriously good. But also how composed it is at high speeds and how agile it feels around corners. I'm in love mine still, one year on.
Now starts the tinkering however...
bquatt218.50
      03-24-2021, 02:55 PM   #151
JTYAMSHAYIN
Drives: BMW 330i
VipinLJ how accurate has your dragy been when compared to the Speedo. Just purchased one and noticed it was off by quite a bit. Haven't played with it to much but something I noticed when trying it out quickly this morning.
Also, where did you mount yours?
      03-24-2021, 09:07 PM   #152
VipinLJ
VipinLJ's Avatar
So...
Usually, it's pretty damn spot on (the speedometer reads exactly 2mph higher than what my dragy shows, right down to when the speed changes (i.e, say I use cruise control to cruise at 70mph (as per the speedometer); dragy will show 68mph. If I increase the speed by 1mph, dragy speed also increases exactly by 1mph at the same time the speedo changes (maybe 1s slower at most)). This happens around 95% of the time.
But
Say a warning message pops up on my live cockpit. It could be something like tyre pressure change, low fuel, low engine oil (I've had those warnings pop up). I notice that the speedo suddenly shows a larger error. When that happens (it has happened many many times, with the most recent happening being today when fuel was low and the warning popped up (yellow triangle sign with less than 30 miles remaining warning)). But this larger error is also spot on (for lack of a better word). When this error is present, for speeds usually above around 40-50mph, the error becomes exactly 5mph (dragy shows 5mph less than speedo reading). Above 100 mph, it increases to 7mph. At lower speeds, it's usually 3mph. This error corrects itself after the warning goes off and the car has been driven for around 50-60 miles. I can also reproduce it (playing with the tyre settings or measuring engine oil levels brings this up too). No one will notice the error unless they're running an app on the side showing GPS speeds. I noticed it first after my tyre swap (they didn't reset the TPMS and I fiddled a lot with tyre settings). I did a dragy run a few days after the swap and realized I couldn't record a 62-124mph run (dragy stopped at 123 when speedo showed 130). If it wasn't for that, I would never have noticed the error. At first, I thought it was the TPMS sensor somehow causing the issue. Then I thought it was my JB4. Later I realised it was the idrive doing it. People thought I was crazy but I recorded videos with cruise control activated and car and dragy readings in the same frame to prove the error existed.
I know it's crazy but it's true. At least in my car. Without this freak error, it's spot on.
And I mount my dragy right behind the iDrive screen. You can keep it anywhere as long as it can get satellite signals.
      03-29-2021, 07:35 PM   #153
bquatt
Anyone see that the Dinan B58 flash was released today?
https://www.dinancars.com/blog/post/...gine_software/
The B46/48 flash is supposedly towards the end of development and is being road tested in a few weeks at Road Atlanta. If all goes well then i'd imagine it will be released shortly thereafter.
VipinLJ1941.50
      03-31-2021, 06:55 PM   #154
Alienwarez567
Drives: BMW 330I G20
My 330I with Octan 100 when from 0-100 in 5.2 sec no mods at all and with 2 fat guys in it according to dragy
bquatt218.50
