Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics HUD Sport display issue on 07/2020
      09-25-2020, 08:42 PM   #1
phayze
Drives: BMW
HUD does not display sport meter in sport mode when set to “Display in SPORT mode”
It will only display if set to “Always”.
Anyone facing this issue with software 07/2020?
      09-26-2020, 04:34 AM   #2
G20NZ
Drives: 2010 135i
Yup I'm having the same issue, no idea if there's a fix for it yet but was planning to mention it to the dealership
      09-26-2020, 05:22 AM   #3
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
I am as well, after v07/2020.45
Al
Retired: 2014 328i
BMW CCA
      09-27-2020, 07:53 AM   #4
Osheatwo
Drives: BMW M3 Comp Xdrive
2021 BMW X5 M50i  [10.00]
2023 BMW 330E  [10.00]
Same here. Received the 07/2020 update at dealer this week and since then it no longer works. Can only get it to show if you put it on "always on".
Even search bimmercode to see if way to recode it but no luck.
Thought about taking back to dealer but will wait now since I know more people are having the same problem.
      11-19-2020, 04:34 AM   #5
ClearSkies
Drives: 330i
Yep I am also having the same problem on 07/2020.54 OTA update. Please let us know if there is a way to fix this!
      11-19-2020, 05:21 AM   #6
RSnic
RSnic's Avatar
Well, got my first OTA update taking my car from version 07/2020.45 to 07/2020.54.
Now I don't even have iDrive menu option to display Tach in HUD!!!
Al
Retired: 2014 328i
BMW CCA
      11-20-2020, 06:05 PM   #7
rcz22
Drives: 2024 G80 M3 6MT
Hey - I also updated to .54 and I have the option to switch to tach in all modes or just sport ::
      11-20-2020, 06:38 PM   #8
phayze
Drives: BMW
Does your show the tach when u switch to show when in sport mode?
      11-20-2020, 06:40 PM   #9
rcz22
Yes
      11-28-2020, 11:55 PM   #10
Ikester19
Ikester19's Avatar
2018 330i LCI  [0.00]
2020 G20 M340ix  [0.00]
Anyone found a fix on this yet? After OTA .54 update the sport displays on HUD have disappeared. Can see the sport display on HUD when set to 'Always' in the iDrive but when I set to 'In Sports mode' it is not there..
      11-29-2020, 11:39 AM   #11
NYC_340i
I have the same issue after updating to 7/2020.60. I doubt anyone here will be able to get a fix even with coding. Sounds like this is something BMW needs to fix in a update. I am not sure if anyone has 11/2020 yet to confirm if it's fixed in that version.
Ikester192124.00
      12-01-2020, 06:57 AM   #12
phayze
Drives: BMW
I’m also checking that out. Going update to 11/2020 and will revert if it solve the HUD problem or not.
      12-02-2020, 12:37 AM   #13
keng799
Thailand
Drives: BMW G20 330e
Having the same problem after upgrade.
      12-02-2020, 05:38 AM   #14
phayze
Drives: BMW
What version you upgrade to?
      12-08-2020, 05:30 AM   #15
phayze
Drives: BMW
11/2020 also same issue. Any know what to code to resolve this issue?
      01-27-2021, 05:33 PM   #16
tnsatbhs
tnsatbhs's Avatar
Drives: 2020 BMW M340i xDrive
Anyone come across a solution to this issue? I just upgraded to 7/2020 and no longer get the sport display only in sport mode.
      01-28-2021, 04:03 AM   #17
helmet91
helmet91's Avatar
Netherlands
298
I find it hard to believe that there isn't some setting to turn to aktiv in Bimmercode that will fix this.
      01-28-2021, 05:01 AM   #18
biglesias31
biglesias31's Avatar
Drives: BMW X3
BMW is aware of this problem and is working on a fix. I'll let you guys know when they release a software update to fix this!
tnsatbhs120.00
RSnic657.50
      02-04-2021, 08:42 PM   #19
CommTech guy
Drives: 2020 Tanzanite M340i xDrive
I just noticed this bug too! I finally got the update, a day after the cool holiday messages, now this. Aggravated it’s Jan 2021 and this has been around since last September. Fix this by giving us Track mode dash��!
      02-05-2021, 03:59 AM   #20
phayze
Drives: BMW
What software version fix the bug?
      02-05-2021, 05:32 AM   #21
Freelancer withour work
Freelancer withour work's Avatar
South Korea
9
Drives: BMW G20 320i M Sport
There is an fdl cheat code.
This is not a bug, bmw mapped different data.
bmw doesn't work
Updating to 20.11 does not fix it.
2014 ~ 2017 Chevrolet Cruze J300 1.8
2017 ~ 2019 Mercedes Benz W205 C200
2019 ~ 2020 KIA Motors YG K7 Premier 3.0
2020 ~ BMW G20 320i
      02-05-2021, 07:10 AM   #22
phayze
Drives: BMW
Do you have the code?
bmw doesn't work
