Technical Topics Wheels and Tires vicfalc09 | ECS Tuning - 15mm (front) 12.5mm (rear) Wheel Spacer Installation
      08-17-2019, 10:58 AM   #1
vicfalc09
vicfalc09's Avatar
211
Drives: M340i xDrive
Just got these in and plan to put them on tomorrow. 15mm for the fronts and 12.5mm for the rears.
I took the opportunity to grab some new tools for the garage.
-3 Ton Floor Jack
-Breaker bar
-Torque wrench
-Protective socket set
[img]
View post on imgur.com
[/img]
Parts for install:
ECSTuning
ECS 15mm Wheel Spacer Kit & ECS Conical Seat Bolt Kit
https://www.ecstuning.com/b-ecs-part...002411ecskt17/
ECS 12.5mm Wheel Spacer & ECS Conical Seat Bolt Kit
https://www.ecstuning.com/b-ecs-part...002411ecskt18/
Anti-Seize Lubricant - 8oz
https://www.ecstuning.com/b-permatex...8oz/80078~pmx/
[img]
[/img]
Step 1 - Break the bolts and jack the car up and completely remove the wheel.
[img]
[/img]
Step 2 - Clean hub surface and apply anti-seize grease to the contact points where the spacer will meet the hub. Do not apply anti-seize to lug bolt threads or lug bolts.
[img]
[/img]
[img]
[/img]
Step 3 - Grab your spacer and align to the hub making sure to line up lug bolt threads and re mount your wheel.
[img]
[/img]
[img]
[/img]
[img]
[/img]
Step 4 - Be sure to apply the recommended torque settings for your spacers. See screen shot from linked pdf - http://bd8ba3c866c8cbc330ab-7b26c6f3...eelSpacers.pdf
[img]
[/img]
[img]
[/img]
Step 5 - Check out your before and afters. Much wider stance and the 12.5mm and 15mm and getting these wheels flush with the fenders now. I really like the look from the front with the wider stance.
BEFORE
[img]
[/img]
AFTER
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
Thanks hope this was helpful!!
-vicfalc09
      08-18-2019, 11:25 AM   #2
vicfalc09
vicfalc09's Avatar
211
Thread Updated (8-8-19)
      08-18-2019, 04:14 PM   #3
evo2335
Drives: G37 IPL (340i on the way)
Nice write up Vic. Definitely looks better with a little wider stance. It's all about the small details. Keep up the good work!
      08-18-2019, 07:06 PM   #4
Joro2819
Drives: 2009 BMW 750LI
How does the gap look with the spacing . Do you feel you may need to lower now that you have installed the spacers?
      08-22-2019, 12:15 AM   #5
SpaceGhost
Drives: 2022 M240i xdrive
Looks like you could go wider out back. Has anyone done 15 or 17mm in back?
Can you post a side shot to see the gap?
      08-22-2019, 07:52 AM   #6
vicfalc09
vicfalc09's Avatar
211
I'll post a side shot this weekend.
      08-25-2019, 05:30 PM   #7
vicfalc09
vicfalc09's Avatar
211
Side
      09-04-2019, 10:58 PM   #8
bimmer813
Drives: 2023 M4, 2024 X5 M60
vicfalc09 are you on a square wheel/tire all-season setup or are you wheels staggered?
Thanks!
      09-05-2019, 08:26 AM   #9
vicfalc09
vicfalc09's Avatar
211
Thanks!
Not staggered
      10-15-2019, 03:25 PM   #10
Prissy
Prissy's Avatar
Taiwan
1069
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
2010 BMW E92  [10.00]
Originally Posted by vicfalc09 View Post
Not staggered
I thought those oem wheels are staggered... no?
      11-13-2019, 06:10 PM   #11
Burrcold
Drives: 2024 M3 Comp xDrive
Not staggered if you choose all season tires (in this case you get square 8" wheels with 225's all around).
