12-08-2019, 08:13 PM | #1 |
Rep 1,003
No door chime?
Does everyone's door chime when open? I just noticed the other day mines doesn't chime at all. I tried different ways to see if one way would trigger it, such as open door when car is running and opening it after closing it once entering.
No luck, anyone else with this issue? |
12-08-2019, 08:30 PM | #2 | |
1942
Rep 3,521
12-08-2019, 09:30 PM | #3 | ||
Rep 1,003
12-09-2019, 05:20 PM | #7 |
X3M Comp is a beast
89
Rep 171
My goes to park and shuts the car off if i open the door. no chime. Is the chime only when you have a key in the ignition? With fob there should be no chime.
12-09-2019, 05:26 PM | #8 |
Rep 1,003
Correct once door opens mines shuts off too. Is there any that actually still use ignition? I didn't think there was.
12-09-2019, 07:36 PM | #9 | |
933
Rep 4,325
Drives: M340
I think, BMW briefly chimes if you open the door and your seat-belt it not on. Unlike others stated, my car only turns off when i wanted to which is when I press the ignition. It would annoy the crap out of me if it turned itself off every-time I opened the door.
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW ....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
12-09-2019, 07:37 PM | #10 |
1942
Rep 3,521
Mine doesn’t shut off when I open the door. It goes into P when I do that. And yes. I don’t think you can code the chimes off in the Audi. But I didn’t think it was too annoying since it was a slow beep. If it was faster or louder, it would have been annoying.
12-09-2019, 07:40 PM | #11 | ||
Rep 1,003
12-09-2019, 08:47 PM | #12 |
Rep 1,532
Mine chimes 3 times if I get in the car and keep the doors open, after that no more chimes.
Prior's: E36, E46 x2
