08-19-2022, 07:21 PM | #1 |
Rep 47
Going Ceramic: What I "really" need and what not to waste money on?
I want do this myself and think I've decided to use CQUARTZ. I hope it is a good choice.
My car is a new 3 week old 2022 430i in Tanzanite Blue. When going to carpro.com or Autogeek, there are a few kits. However each CQUART kit is different. Some kits have only the CQUARTZ with cloth and applicator, some kits also have a Reload product, while other kits contain other chemicals. When watching "how to videos", those videos seem to be marketing 10 different products to prep the car, many seem to just wipe off the previously applied product. The marketing hype is confusing. So I'm asking what do I really need to buy and what is just fluff? I also would like to do the windows, wheels and calipers Respectfully, Bryan in Tucson Last edited by BKSinAZ; 08-20-2022 at 05:25 PM.. |
08-20-2022, 06:48 AM | #2 | |
Rep 440
08-20-2022, 08:39 AM | #3 | |
Rep 88
Drives: 2008 335xi coupe
If you use a product like CarPro Essence it will prep the surface for the coating saving a step, plus you don't have to touch the paint again after polishing. And while I haven't seen your paint, you should get great results with this and say a BOSS orange or yellow pad. Applying the coating is easy but it's all in the prep work. The fact that your car is only 3 weeks old is not relevant either, the same steps have to be done. I've seen 5-10 year old used cars in much better shape than new cars. Personally I would use Gyeon Mohs Evo which is a 3 year coating, 4 if you apply Skin. I prefer it without Skin but there's no right or wrong. I would also have different types of high quality MF towels at the ready because coatings & polishes can be particular in what type of towel works best. You didn't mention what polishers you own or may have access to, but you should have one that can handle 2-3" pads, not just one for 5.5"/6.5".
PPK | Mishimoto FMIC | ER CP | Forge DVs | RB Inlets | RB PCV | BMW PE | Dinan springs/Koni Yellows
08-20-2022, 11:11 AM | #4 |
Rep 47
08-20-2022, 11:31 AM | #6 | |
Rep 47
I have a dozen micro fiber towels. How many pads do you recommend? Just watched several old video reviews about how good Gyeon Mohs Evo was compared to CQUARTZ. Last edited by BKSinAZ; 08-20-2022 at 11:39 AM.. |
08-21-2022, 09:49 AM | #7 | |
Rep 88
I'm old school in most things and always want to work clean, so I'll change pads after a couple of sections/panels rather than clean them so I may use 6-10+ on a vehicle. Overkill probably but's it's just my way. I also don't have an air compressor. You could get away with 4, clean two and toss them in the dryer and they'll be ready by the time you're done with the other two. I'm "assuming" you don't have an air compressor but if you do that works great to clean them in a matter of seconds. For claying on your 3 week old car I would use a fine clay with tons of lube, then gently glide the clay over the paint. If you decide to use Essence (not Essence Plus) it's a little different than most polishes. It has a fairly long work time and does not have to be removed right away. In fact you could do the whole care before removing, and my experience has been that it comes off best if you give it some dwell time. Awesome product too.
08-21-2022, 10:51 AM | #8 | |
Rep 47
Plan on using McGuires M210 with the Lake pads you recommended. Will also use McGuires fine clay. I am trying to figure out the color of pad.... not sure if I should do a tiny bit of cutting. Currently I am undecided between Gyeon Mohs Evo and CQUARTZ. My concern with Gyeon is that their "cure" coating, I heard, needs reapplying VERY frequently compared to CQUARTZ "Gliss". Anyhow, I appreciate your replies and look forward to your opinions. Last edited by BKSinAZ; 08-21-2022 at 08:24 PM.. |
08-21-2022, 02:11 PM | #9 |
Rep 148
Another way to simplify the process is to use a clay mitt or clay towel during one of the wet decon steps. I usually do it while I wash the car or with the iron (fallout) remover. Don't forget your nitrile gloves and don't let the iron remover dry on the surface.
08-21-2022, 02:20 PM | #10 |
Rep 148
Another highly regarded polish is Perfect Finish from Sonax. This will provide a mild cut when used with a cutting pad (if the paint already has some swirls) and just enhances the gloss when used with a finishing pad.
Nothing against Meguiars products - I still have some in my arsenal. |
08-21-2022, 02:48 PM | #11 | |
Rep 47
Maybe my steps should be Wash Clay and lube One step Polish Wipe off with Alcohol dilution 3 parts water to one part Alcohol Ceramic base Ceramic topper What you all think? |
08-21-2022, 05:32 PM | #12 | |
Rep 88
You can get a little cut from the polish, the pad or both. It sounds like your paint is in the condition 3 week old paint should be in so M210 might not need any assistance. Easy enough to find out though with test spots.
08-22-2022, 07:55 AM | #13 |
Rep 148
Fallout removal is only part of a decon. Decontamination is the removal of everything on the painted surface that does not belong there. This includes fallout (mostly iron particles from the air, your brakes, etc.), sap and tar, and of course embedded dirt that normal washing can't remove. Decon is usually broken down into chemical (e.g., iron, tar or sap remover) and mechanical via clay.
08-26-2022, 07:26 PM | #14 |
Rep 47
Is there a difference between polish vs. Glaze? I wanted to use Meguiars M210 polish, but when looking at product, it says polish glaze.
Keep in mind that the car is 3-4 weeks old with no swirls. |
08-27-2022, 02:08 PM | #15 | |
Rep 88
08-31-2022, 01:55 PM | #16 |
Rep 1,468
I have done ceramic on my G20 and a few other BMWs.
the paint is hard and will likely need a 2 step correction to get it right. my steps: wash car chemical decon mechanical decon rinse and dry correct paint with maguaris m100 and mf pads IPA wipe down polish paint with sonax perfect finish using a middle of the road polish pad. it cant be too fine or it wont work. wash and dry car again apply ceramic
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
09-01-2022, 07:46 AM | #17 | |
Rep 88
A 2-step is overkill in this situation. Plus I'm a big believer in removing as little clearcoat as possible because that is the best protection.
ultrared93103.00 |
09-11-2022, 05:34 PM | #18 | |
Rep 47
Anyhow, this should be last question on this subject... Should I use McGuires #9 instead of the m210? The #9 is slightly less abrasive than the m210. I tried to google my questions, but there are no comparisons between #9 and m210. The info I was able to locate: on a scale of 0 to 12, the abrasive is 3.5 with the m210 and abrasive is 3.0 with #9, but not sure if .5 percent less abrasive will produce more gloss and depth or which is easier to use. Your opinion? |
