05-05-2021, 11:01 AM | #1 |
Rep 3,130
NEW RELEASE: Dinan BMW G20 330i Carbon Fiber Cold Air Intake System
Dinan BMW G20 330i Carbon Fiber Cold Air Intake System Part Number(s): D760-0055 Applications:
Release Date: Available Now! Description: In the quest to be all things to all people at an attractive price point the 330i has been reduced to a mundane, albeit pragmatic, core with elements devoid of any character both outwardly and inwardly. For example, in stock trim, the 330i comes with a utilitarian and lifeless air box housing a basic panel filter that is also accompanied by an intake resonator whose job it is to eliminate turbo/intake noises. The same noises that those in the performance world relish. Essentially, BMW has seen fit to give 330i owners an air box that looks uninspiring, flows adequately but not ideally, and emits no noise. The Dinan carbon fiber intake for the platform rights these wrongs and delivers a semi-open intake capable of flowing 58% more air than the stock system resulting in improved throttle response and the elimination of a potential roadblock when opting to pursue a high-powered build (upgraded turbo, fueling, etc). At the same time the Dinan kit unveils a more aggressive, sporty carbon fiber appearance, and an increase in sound courtesy of the removal of the intake resonator and implementation of the semi-open design. In order to accomplish the feat in flow that sets the Dinan intake system apart the entire lower box of the system, and not just the lid, has been reworked and enlarged in an effort to make use of as much of the available real estate as possible within the engine bay. In turn, this allows a 40% larger, custom, free flowing filter to be housed within and maximum flow to be realized. However, a secondary inlet has always been desired by Dinan in order to effectively fill the volume of the enlarged air box and increased filter surface area. This desire led to a multitude of experiments being conducted on the effectiveness of a possible open-air inlet in the system. With different shapes, locations, and sizes of openings being tested, the goal was to ensure that the added secondary inlet did not cause any unwarranted side effects such as an increase in air temps in the system. This is commonplace with open-air intake systems where overheated engine bay air is employed in the intake tract. The results of these tests showed that the patterned openings present in the final iteration of the box on the opposite side from the engine provided a perfect balance of additional volume to assist the factory snorkel all the while not causing an increase in turbo inlet temperatures. This was the case regardless of testing conditions (single/multiple gear pulls, constant speed, 0-100mph runs, etc.). While the additional flow does not translate to any noteworthy rise in power output for stock or basic bolt-on equipped vehicles, the Dinan intake system does expand the potential of the platforms power ceiling. Put simply, those striving to build a more potent and robust solution, complete with turbo and fueling upgrades, will be allowed to maximize the results without worry of the intake system being a limiting factor. Regardless of the level of build, the secondary air inlets allow the intake system to be more audible so the turbo spool and BOV can be appreciated. A stark difference from Dinan's traditional fully sealed systems where induction noise is not nearly as recognizable. Not to be outdone by the increased flow and sound, the outwardly visible system is made of immaculate carbon fiber so the under the hood appeal is vastly improved over its drab and utilitarian beginnings. In and of itself, making it worth the price of admission. Features/Benefits:
05-06-2021, 08:37 AM | #3 |
Joint Chiefs of Staff
24279
Rep 190,975
05-07-2021, 07:54 AM | #5 |
Rep 3,130
'21 ECU's have not been cracked. Being worked on by us and about everyone else in the industry but who knows when that breakthrough may occur. Once it does occur though we will have a tune for it.
05-07-2021, 08:37 AM | #6 |
Rep 505
Just out of curiosity will this fit the G20 330e as well ?
2019 G20 330e - 2021 to ... 2006 E90 335i - 2013 to 2021 1999 E46 323i - 2001 to 2011 |
05-07-2021, 08:50 AM | #7 |
Rep 3,130
05-07-2021, 12:01 PM | #10 |
Rep 115
05-07-2021, 12:51 PM | #11 |
Rep 3,130
It's not a fully open system so it wouldnt make as much noise as a filter on a stick design but in rough terms I would say its about 20% more volume then stock. Get a sense of sound from the video above although it still has the background music overlayed in there. =/ Still, with headphones on I think it gives a decent sense of what to expect. I'll put in a request for just a sound blurb from the media team but the car isnt due back until next week as its on a "field trip" for altitude testing / verification.
05-07-2021, 01:47 PM | #12 | |
Rep 115
05-13-2021, 02:16 PM | #13 |
Rep 2
Looks beautiful! Now, I'm torn between this and the MST Intake system. This is probably a noob question: Is it feasible to combine this with the MST turbo Inlet Pipe? In order to replace the OEM plastic inlet pipe.
05-13-2021, 02:56 PM | #14 |
Rep 3,130
05-14-2021, 01:59 PM | #15 |
Rep 428
Dinan_Engineering any plans to develop an exhaust for the 330i?
2020 MG 330i xDrive M Sport
2023 AR M3 Competition M xDrive |
05-14-2021, 03:01 PM | #16 |
Rep 3,130
Yes. Development is done. It's on productions plate now. That said, they are mired in backorders for exhausts (demand over the last year and change has been immense to say the least) so new SKU's are on the backburner for them at present.
05-17-2021, 08:22 AM | #17 |
Rep 428
The springs were worth the wait so I'm sure the exhaust will be the same. Patiently waiting!
05-21-2021, 07:20 PM | #18 |
Rep 28
I received my intake and am on step 5 of the installation where it says to remove this hose clamp on the lower part of the original tube. What type of clamp is this? It’s different than the one pictured in the instructions, used elsewhere in the intake system. Build date is 09/2019. Is this a single-use clamp?
05-21-2021, 09:22 PM | #20 | |
Rep 3,130
05-25-2021, 03:47 PM | #21 |
Rep 47
sound
hey guys wondering if anyone has installed this without any exhaust mods
have a 2021 m340i non m exhaust wondering if i install only this dinan cold air intake will i hear feel a difference. thank you |
