05-20-2020, 06:53 AM | #45 | |
Rep 157
Yes, looking forward to popping out for my daily exercise, thinking Land's End would be a good place to start |
Karl V100.50 |
06-01-2020, 09:45 AM | #46 |
Rep 177
Hi guys, I'd like to charge my battery using CTEK charger, but I'm not sure where the negative terminal is located under the bonnet. According to my manual there is a designated place for a negative cable (green circle), buy it looks like it's noting there. Ot at least it doesn't stand out in any way.
Where did you connect the negative cable? The yellow circle perhaps? Looks likely to me, but I won't try if I am not sure. |
06-01-2020, 09:57 AM | #48 | |
Grumpy Old Git
443
Rep 923
Retired:
Yossi12378.00 |
07-14-2020, 01:48 PM | #49 | |
Rep 31
For trickle charger I believe CTEK is overkill, but CTEK is an 'all-round' solution, it is smart to know when to provide higher current/voltage and when to stop, and possibly recover a dead battery. so if you aren't price-sensitive go for it. If all you want is a 'top up' trickle charger then there are much more (cheaper) choices, I recommend those with no more than 3A current output and no more than 14V peak voltage since AMG batteries are more sensitive (overheat etc) to high current. If you plan to keep the charger connected for a prolonged period, get a smart one (microprocessor controlled), it will switch to a very low <1A current once fully charged. Just beware, it will take a long time to charge. e.g. BMW battery is typically ~90Ah, if your charger outputs 2A, it will take approx. 90/2 = 45 hours. to charge full. |
07-22-2020, 09:30 AM | #50 |
Rep 23
Finally got round to sorting one out. Battery notification went away for a couple of weeks but came back again over the weekend and got annoyed with stop start never working so went and bought the CTEK recommended here. Arrived today and after digging this post out to see where the negative terminal was (shoddy instructions!) it's currently on charge. 2 hours in and currently on the bulk stage in AGM mode. Hoping it'll be more or less sorted before nip out tonight.
07-22-2020, 04:00 PM | #51 | |
Rep 156
07-23-2020, 03:31 AM | #52 |
Grumpy Old Git
443
Rep 923
I had a longish run on Sunday and my Start/Stop started working again for a couple of days then stopped. So decided to put the battery on charge last night. After 4 hours the CTEK had it fully charged and then I did the software update to 11/2019.70. My first OTA update.
Retired:
F10 520D M Sport E60 520D SE Volvo S60 type R Last edited by Tam the Bam; 07-23-2020 at 03:56 AM.. |
01-09-2021, 10:20 AM | #53 |
Rep 1,039
02-03-2021, 04:37 AM | #54 |
Rep 13
Drives: G20 320i M Sport
Discharging every 6-8 weeks
Just wondering you guys are experiencing the similar frustration of having to fully charge from 'low battery' every couple of months? I do drive a little (probably 30-40 miles/week school run's etc), but in the current lockdown of course, she does not get a proper run.
I previously took it back to BMW early on in lockdown v1 and they told me there was a discharge issue with keyless access, so they replaced the door handle. If it's common 'discharge speed' at the moment, I can deal with it, if it isn't, I need to get back on them again. I charge it probably 12 hours at a time. By the sound of it I should be using the AGM setting on my CTEK, rather than the 'standard' mode? |
02-03-2021, 05:04 AM | #55 | |
Grumpy Old Git
443
Rep 923
Yes AGM setting should be used. My car is not being used much at present, due to restrictions, and I’ve had to charge every 4 to 6 weeks since early November.. When I eventually get a service I’m going to ask the dealer about this issue.
Retired:
02-03-2021, 05:31 AM | #56 |
Rep 8,081
Is this down to comfort access perhaps? I don't have comfort access but I've never charged the battery and it's been fine, even with no journeys for 2 months.
Ian
02-03-2021, 05:37 AM | #57 |
Rep 114
This may be all in my imagination, but during 1st lockdown I was trickle charging every 2-3 weeks or so. Over the Summer, I decided to turn off the 'unlock on approach' option just because I didn't like the idea of the car locking / unlocking as I was walking around in the garage / garden at home.
Since the kids broke up from school in December (what, about 6 weeks now?), I have used the car probably twice on small trips and the battery's showing no signs of needing a top up. Like I say - this may all just be in my head, but thought it worth sharing just in case there is a little bit of science in there somewhere.
Digital drive: F90 M5
Analogue drive: Ariel Nomad |
02-03-2021, 06:44 AM | #58 |
Rep 73
Mines been similar, comfort access and I have to charge the battery every 3-4 weeks when it's not used.
Do others think it's a fault? I'd rather not approach the dealer unless I have to as they have already put me off buying another BMW ever again |
02-03-2021, 07:00 AM | #59 | |
Rep 15,858
My F11 (with comfort access) seems to draw more than expected. Winter time I've 'topped' the battery a couple of times, as habit. this winter with virtually no use I'm attaching the charger every couple of weeks. |
02-03-2021, 08:15 AM | #61 |
Rep 379
Having worked from home and spent a lot of time abroad since 2007 meaning the car was unused for sometimes up to 8 week, the battery drain is not a new phenomenon. On my 56 plate 330d I actually had the situation where the alarm was activated due to low battery state, requiring BMW emergency service callout. Since then i have used a maintainer on subsequent BMWs 3s, 4, X5 and not had any issues.
One issue highlighted a few posts back is that if you unlock the car before checking the maintainer status you will get the appearance of being back at stage 3 or 4. I figure this is due to current draws of the car fooling the maintainer. Generally overnight is sufficient. |
02-03-2021, 09:03 AM | #63 |
Rep 15,858
I haven't made any tests, just a bit of mental math which suggests it may be more than the 20mA that my model may draw when asleep.
On a car like mine, the draw can be up to 80mA before we get a warning. I've no data to suggest what the G2x models are rated at. |
02-03-2021, 09:09 AM | #64 | |
Rep 15,858
Years back we'd simply get a flat battery, or if fortunate, first key sign that attention was necessary, slow cranking. The lockdowns and colder weather show up the limitations of high energy demands, and not getting enough regular charging. |
02-03-2021, 09:21 AM | #65 |
Rep 13
Good to know that it's not just me, thanks!
Yes, I'm sure the drain is all around the comfort access - I also turned of the 'unlock on approach' as I could hear the car unlock when I walked past the front door (car was parked about 2m away from it). But I love the keyless entry too much to turn that feature off. It's a real pity if it has been poorly developed. Also, thanks for confirming AGM setting as I suspected. I will give it a significantly longer charge when it is dry out again. |
02-15-2021, 08:38 AM | #66 |
Rep 23
I am slightly concerned about the battery status in mine. Was in for a service last week and I mentioned about the low battery warnings to be told it was fine. Went out the other night (was bitterly cold outside), drove for about 20 mins averaging 40mph, stopped and within a minute of engine off, battery warning message and all the electronics shut off seconds later. It's back on the charger again today to see if that sorts it out. This can't be normal surely? The wife's 69 plate A class does less mileage than me currently and stop start etc. all work fine.
