01-07-2021, 10:42 AM | #1 |
Rep 858
330e UK supplied charging / granny cable
Hello all. Just joined as recently ordered a 330e.
Just trying to sort out home charging set-up (first dip into EV) and whilst I over-analyse the minefield of thousands of options for dedicated home charging points, I need to prepare for temporarily just using the supplied granny lead. The car will be kept on driveway not close to the garage so the brick part of the cable will be outside and will therefore somehow need to be protected from the elements a little. Can I please trouble someone to let me know approx dimensions of the supplied cable? Mainly need the approx dimensions of the brick, length of cable from brick to 3 pin plug, brick to car nozzle etc? Thanks in advance.
01-07-2021, 10:45 AM | #2 |
Rep 86
Hi mate
My brick goes outside as bmw said it’s waterproof Brick is around half a meter from the plug, then another couple of meters to the pump Usually charges in around 4 hours at 10amp |
01-07-2021, 10:49 AM | #3 |
Rep 320
I tend to tuck the 'brick' under the front of the car so it's not directly in the elements, back in the day when I used to charge the car!!
Arrived: '20 330e M Sport in Mineral Grey
'03 MY 996 Turbo in Arctic Silver Gone: '18 Golf GTI Performance DSG in Tungsten |
01-07-2021, 10:54 AM | #4 |
Rep 858
Thanks for the replies. I heard people tuck their bricks under the car, or on the top of the front tyre, but with only a meter or so of cable from the 3pin plug, how is that done? Thanks again.
01-07-2021, 11:49 AM | #5 |
Rep 86
Sorry mate my bad just Been out to check it’s about 1.5m from the plug to the brick
01-08-2021, 05:47 AM | #9 |
Rep 57
I'm thinking of getting one of these until I sort my charging point out.
https://www.toughleads.co.uk/collect...19514035929176 |
01-08-2021, 05:49 AM | #10 | |
Rep 858
Some get a bad rap for number of faults (Rolec) Some get a slated for crap app (EO) Some just up and coming and promising functionality in future releases (SyncEV) Some have terrible looking charging points (BP) Some have usage charges after the 3 year warranty, but fail to mention that in any literature (BP) and almost all have very little information of their product. All very generic. "It charges a car. Buy Now" ...so its a bit of a minefield that I'm still navigating.
01-08-2021, 06:22 AM | #12 | |
Rep 256
01-08-2021, 07:25 AM | #13 | |
Rep 858
Seen a couple of posts from people complaining their chargers didnt like getting wet and ended up under buckets or in weatherproof boxes so thought that would be something I should do.
01-08-2021, 07:32 AM | #14 | |
Rep 320
01-10-2021, 03:09 AM | #15 | |
Rep 256
The box I referred to is the weather proof socket that is part of the external lead, I also went for an inline RCD to add a level of safety. |
01-10-2021, 06:23 PM | #18 | ||
Rep 68
02-26-2021, 11:13 AM | #19 |
Rep 858
Dont suppose anyone has ever measured the supplied granny cable end-to-end have they and would know the approx length?
Vaguely recall its about 5 metres, but that would make it about 20cm short for me from socket to closest parking space! Would rather not have to think about buying nn extension cable for either end if I can get away with it. type-2 extension cable would be best option as could keep granny charger under cover, but are ridiculously priced.
02-27-2021, 06:12 AM | #22 |
Rep 256
I’m also running a tough leads extension from my cabin through the trellis on top of my fence and attached to a concrete post. All works well. I’ve done 3,260 miles and I’ve filled the fuel tank 3 times with ~ half a tank left. I’m mostly doing local miles due to lockdown and I plug in after every trip. The charge time, on the 3 pin, hasn’t yet been an issue for me.
