2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK 2020-4 New Maps - issue?
      02-21-2021, 03:12 AM   #1
Joedeejay
Drives: BMW G20
Just wondering if anyone else has downloaded the latest maps for their car and installed them with no issues? 2020-4 series of maps
Installed mine and now the Sat Nav is stuck in a loop. Tried the 30 second hold of power button to completely restart the idrive but still doing this. Rest of the idrive is behaving.
Vid of said issue
      02-21-2021, 03:50 AM   #2
Axeman15
Axeman15's Avatar
62
Drives: 330i M Sport
I wasn't aware there was a new update. I am downloading now and will let you know later if I have the same issue.
My car is booked in with Sytner on Tuesday for a free 1st year check so if it fails I will ask them to reset it if needed.
      02-21-2021, 04:16 AM   #3
Trevikins
Retired
Trevikins's Avatar
England
21
Drives: G20 320i M Sport
I had exactly the same problem with the last update (2020-3), which I put down to an iffy USB Flash Drive. Changed to a new 64GB Drive formatted as FAT32 and updated using the USB-C Port and it updated OK.
I’ve since updated to 2020-4 with no problems.
      02-21-2021, 04:33 AM   #4
xenon
xenon's Avatar
England
1397
Drives: 2021 G21 330i M-Sport
I thought maps updated OTA?
      02-21-2021, 04:41 AM   #5
seelark
seelark's Avatar
143
Drives: G20 330e M Sport Plus
It does OTA once in a blue moon. You can upload the latest once it becomes available if you so wish, as it could be 9/12 months and numerous updates before they get round to sending it, just like the main software update 🤷🏻*♂️
      02-21-2021, 05:05 AM   #6
woody320
Vid of said issue
Updated no issue. I always find that the opening splash screen does come up a couple of times but that normally because I have failed to remove the USB stick and it starts to try and update all over again.
      02-21-2021, 05:44 AM   #7
xenon
xenon's Avatar
England
1397
Ok so if you want to pre-empt OTA and do it manually, from where do you download the map updates?
      02-21-2021, 05:49 AM   #8
nogy1963
Drives: G20 M340i
Control section in the connected drive portal , under Map Update, its around 30gb download and requires a 64gb Usb stick.
      02-21-2021, 05:52 AM   #9
Axeman15
Axeman15's Avatar
62
Downloaded and installed, no issues.
      02-21-2021, 10:20 AM   #10
Joedeejay
Drives: BMW G20
Ah well, cheers guys. I'll use a different USB stick and redownload it all. See if I can reflash it
      02-21-2021, 10:39 AM   #11
nogy1963
Drives: G20 M340i
Same here no problems
      02-21-2021, 10:58 AM   #12
woody320
Does anyone know if the system warns you that there is a new update to download? I find myself having to fire up the updater weekly and by sheer chance just noticed the new update after it had gone through its "You have already downloaded this" On this occasion instead it a message popped up stating a new one was available.
sJohnny264.00
      02-21-2021, 11:15 AM   #13
nogy1963
Drives: G20 M340i
On my 330D f31 I had a few OTA updates, but usually just keep an eye on Forums for posts regarding updates and then check myself.
      02-21-2021, 01:31 PM   #14
srbs73
srbs73's Avatar
548
Drives: BMW i4 M50
I just did mine with no issues using 64GB stick. I think you can leave it between runs but I tend to let it complete with the engine running and then restart the nav.
      02-21-2021, 02:28 PM   #15
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
See here.... for tutorial
https://g20.bimmerpost.com/forums/sh....php?t=1712423
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      02-21-2021, 02:39 PM   #16
xenon
xenon's Avatar
England
1397
Thank you.
      02-22-2021, 08:13 AM   #17
Keith_C
Keith_C's Avatar
179
Drives: BMW 330i M Sport Plus
It's quite easy, as already said, go to the Map Update in the Control tab on the Connected Portal or you might have already downloaded the BMW Download Manager.
Open the BMW Download Manager and log in.
It should tell you if there is an update based on your VIN.
I put my 32gb USB drive into the PC and do a fresh format in NTFS and leave it there. You can use ExFAT, FAT32 or NTFS.
Start the download, I usually download to a New Folder on my desktop, so select that folder and let it download.
When it's downloaded, open the drop down button and select the USB drive that's just been formatted and it will unzip the files directly to the USB drive for you.
Eject the USB from the PC and either plug into the armrest or cupholder USB port depending on type of USB drive, I use USB-C, start the engine, follow pop ups, go to Nav and scroll to settings and down to update to see progress.
Took about 20mins to install fully.
      02-22-2021, 08:44 AM   #18
seelark
seelark's Avatar
143
Started the download at lunchtime with me and wife working from home and 2 kids home schooling 🙈
      02-22-2021, 10:40 AM   #19
Keith_C
Keith_C's Avatar
179
I feel your pain after having two 20+ year old lads who think Youtube and gaming is the be all and end all. Thankfully I ditched Sky's piss poor effort at Broadband and switched to Virgins 600mb Fibre and a Mesh system to give me downloads of over 60mb/sec all round the house.
      02-22-2021, 04:26 PM   #20
Joedeejay
Drives: BMW G20
Redownload of the maps and reinstall in the car seems to have sorted it. Phew.
srbs73547.50
      02-22-2021, 04:55 PM   #21
Axeman15
Axeman15's Avatar
62
Glad it's sorted
      02-24-2021, 02:54 PM   #22
GolanTrevize_86
Spain
Drives: BMW G20 320i B48B20B
I had issues too but different scenario. Last year maps available to download got freeze in 2019-3 (drive 7 road-map live), this affected more people at least in my country. Emailed Connected drive support and they fixed it some month after. In October 2020 2020-2 version was ready so I tried to install it as I've always done in my F30 and before this in my G20.
Well, the car sends a message that the FSC is not correct for the downloaded maps. Since October I'm in touch with bmw connected drive support but they don't solve the problem.
My theory is that they have the VIN changed or something since I contact them the very first time.
However the car updates the maps correctly via OTA.
Thank you in advance.
