Technical Topics Cosmetic Maintenance: Wash, Wax, Detailing, Repairs Dent/bend above rear wheel
      02-02-2023, 09:53 AM   #1
DAN
Drives: G20 320d M Portimao Blue
Hi,
I’ve just noticed a dent/bend in the bodywork above my rear wheel on the left-hand side. This must’ve been done sometime after I cleaned it last week as I’m sure I would’ve noticed it.
Anyway, for now I’m thinking it may just pop straight out - there doesn’t appear to be any damage to the paintwork itself.
My question is, how easy is it to get behind that panel? Presumably the easiest access would be behind the rear wheel arch liner. Is that easy to get into?
EDIT: removed dropbox link and added image as attachment
Last edited by DAN; 02-02-2023 at 11:52 AM.. Reason: removed dropbox link and added image as attachment
      02-02-2023, 11:51 AM   #2
ergarza
Drives: BMW 340 M Sport
Really easy to get there, there is a plastic cover that you can easily remove. Of course if you remove the wheel is much easier
      02-02-2023, 11:54 AM   #3
DAN
Added photo to original post.
Good to know - thanks - I'll remove the wheel at some point and give it a go.
Is it just bolts or some horrible clips...?
      02-02-2023, 11:57 AM   #4
ergarza
Your baby will be fine, but if I were you, I would take it to a PDR (Painless Dent Removal) expert to avoid the paint to crack or a bad finish.
      02-02-2023, 11:58 AM   #5
ergarza
Just bolts, I took it some months ago and I believe that have some pics, as soon as I get home tonight I will check
      02-02-2023, 07:42 PM   #6
VipinLJ
VipinLJ's Avatar
+1 to that. I'd take it to a PDR guy too. It might pop right back easily but there's a slight chance the paint can crack. Then you have bigger issues. Shouldn't cost much to remove the dent too.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
