05-14-2023, 08:51 PM | #1 |
Rep 514
Advise on M340 with H&R springs + Front lip?
Hey guys, haven't posted in a long time, but I have my M340 for a year now & LOVING IT! After going to a BMW meet yesterday I pulled the trigger on buying sports H&R springs.
I recently put 13mm spacers all around on my staggered setup, and it really would look best with a drop. I also bought a front lip 2 weeks ago which I did not install yet (mod season): https://maxtondesign.ca/collections/...30754831761543 Question, will adding the lip after lowering be too much? I do live in Canada (Montreal specifically) with crappy roads, and I don't want to scrap it. Hoping for some suggestions from others who have had a similar setup.
2022 BMW M340 X-Drive
2020 BMW X3 30i M-Package (retired) 2018 BMW 440i X-Drive Gran Coupe l Premium Enhanced Package l M-Performance Package + M-Performance Pack 2 (retired) 2013 BMW 335i X-Drive (retired) |
05-15-2023, 10:39 AM | #2 |
Joint Chiefs of Staff
24198
Rep 190,805
Certainly, installing a front lip on a lowered car is doable but it demands caution.
As your car is already lowered, you can use this as a reference for the clearance you currently have. Before installing the front lip, measure its thickness and compare it to the current ground clearance. This will give you an idea of how much closer the lip will be to the ground once installed.
05-15-2023, 01:07 PM | #3 |
Rep 514
Thanks Mike. The pictures are showing stock, I didn't receive the springs yet. But good idea to estimate the height...
A few buddies suggested removing the lip for winter since we get a lot of snow, and putting it back in the spring. Not if that's a good idea...
05-15-2023, 01:35 PM | #4 |
Rep 38
Drives: 2020 BMW M340i X-Drive Exc Pkg
I’ve been to Montreal a handful of times and I think you could pull it off. Just get a cheap one and replace when you inevitably break it. Won’t be the snow that gets you
05-15-2023, 07:27 PM | #5 | |
24198
Rep 190,805
In my case, I'm adding a front lip to my car, which is already significantly lowered. However, I've planned for this as my springs are adjustable. I anticipate that I'll need to slightly raise the car to accommodate the additional clearance required by the front lip.
05-15-2023, 09:46 PM | #6 |
Rep 79
Drives: 2020 M340i xDrive | 1987 325iS
Let me know how you like the H&R springs. I’m in NJ with mild to very bad roads and I’m regretting having them installed, just a warning.
05-15-2023, 10:40 PM | #7 |
Rep 514
How come you regret it? Harsh? Do you have run flats? Mine came with Michelin Pilot 4S for summer... but my winters are RFT.
05-16-2023, 12:21 AM | #8 |
Rep 1,115
There are several front lips out there that have different thickness/height as Mike mentioned. I treat front lips like a disposable commodity. Don’t be surprised if it gets busted after one time curbing a parking block, or not angling the car enough when going down a steep driveway.
05-16-2023, 10:40 PM | #9 |
Rep 514
Big thanks to Mike!! I decided to cancel my H&R and get the Dinan springs with the handling kit. I'll post pics after its installed.
05-18-2023, 08:41 AM | #10 |
Rep 79
I switched to Conti DWS's for winter and 4S's for summer. Still not pretty harsh. I'm ok with it being stiff, I'm not ok when it gives a very hard knock on medium bumps and noisy too. light squeak on slow compressions.
05-18-2023, 09:35 AM | #11 |
24198
Rep 190,805
06-22-2023, 08:58 PM | #12 |
Rep 514
Update!
Installed Dinan Springs & Handling kit thanks to our friends @[mike@x-ph.com](contact:216704 I also added: -M4 Style Spoiler -Rear M performance diffuser -Maxton Design front lip -13 mm spacers all around (staggered wheels) Rear is pretty flush... debating to put 15mm in front possibly Highly recommend the Dinan springs, not harsh and rebound much improved.
02-26-2024, 12:27 AM | #13 |
Rep 38
02-29-2024, 03:18 PM | #14 | |
Rep 32
Drives: 2020 M340ix
02-29-2024, 05:25 PM | #15 |
24198
Rep 190,805
H&R VTF
03-07-2024, 09:12 PM | #16 |
Rep 547
Nice stuff.
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
