Technical Topics Wheels and Tires Post Your Aftermarket Wheel Set Up!
      04-20-2024, 04:17 PM   #815
slm266
slm266's Avatar
Drives: 2020 M340 xdrive
VMR 710 19”
Front 8.5” et 25 + 12mm spacer 245/40/19
Rear 9.5” et 33 + 5mm spacer 275/35/19
Update: Just a hair of poke and rubbing when reverse turning, i decided to do only 5mm spacer front + no spacer rear for a flush fit.
Lowered on eibach springs
      04-22-2024, 12:14 PM   #816
peteranton
peteranton's Avatar
18
Drives: M340i, 135i E88, X1
Originally Posted by slm266 View Post
VMR 710 19”
Looks great, I have them on a LeMans Blue 135i in Hyper Silver. Are yours Gunmetal?
      04-22-2024, 12:22 PM   #817
slm266
slm266's Avatar
Yeah gun metal. Did you put bmw center caps on yours?
      04-22-2024, 01:24 PM   #818
peteranton
peteranton's Avatar
18
Yes, the center caps were a direct fit on the V710, but on a 135i. VMR can't confirm that the same thing with happen on their 5/112, 66.6 wheels, as I'm planning on getting V802 wheels for a black M340i. And, they only offer Gunmetal on the V710, and not the V802. I'm afraid the Anthracite may be too dark, that's why I asked if yours were gunmetal... but I already have that wheel on another car. Decisions!
      04-22-2024, 08:09 PM   #819
slm266
slm266's Avatar
I ordered some 68mm bmw caps off eBay based on some other threads that I read
      04-23-2024, 02:30 AM   #820
Jose_4w3
Drives: 2013 BMW M2
Originally Posted by Codybug View Post
will 19" 2 piece wheels fit on the front of a 2022 BMW M4 G82 comp coup / with the big calipers // need help
I would say you better check the specifications of calipers first.
If the calipers are too big, you can only put 1-piece 19" or 2-piece 20" on the front wheels.
Feel free to contact RVRN Wheels for any specific requests or questions you may have. Our engineer will check for you.
Check out custom wheels project for BMW M3 Competition,
Front: 1pc 19"
Rear: 2pc 20"
      04-23-2024, 06:39 AM   #821
Chewy0189
Drives: BMW M340i
Originally Posted by TONY BMW View Post
Could you tell me, what is the ET you use? Thank you.
Sorry for the late response.
ET 28 Front. ET 42 Back.
      04-25-2024, 03:03 AM   #822
TONY BMW
Drives: BMW G20 330I
Thank you very much. It looks great. Any friction with the shock strut on the front axle? They advised me an ET of 25 for 20x9, and this way we moved 3mm away from the strut, what do you think about this?
      04-25-2024, 02:23 PM   #823
Chewy0189
Drives: BMW M340i
I'm currently running KW V3 coilovers and I have no issues.
I honestly couldn't give any advice. I'm not nearly well enough versed. The shop I went to was highly recommended in my area and they knew the size to use.
      04-25-2024, 03:12 PM   #824
stince
m340i Enjoyer.
stince's Avatar
Drives: F10 535xi | G20 m340i
Man.. all these photos.
Trying to find the best setup for my dravit m340 on h&r's.
      04-29-2024, 02:49 PM   #825
Printertom
Printertom's Avatar
156
Drives: 2020 M340i xdrive Tanz Blue
BBS Unlimited 19x9 19x10
      04-30-2024, 09:47 PM   #826
b58matt
Drives: 2021 bmw m340i xdrive
Hey Everyone,
I’m planning on going staggered on my aftermarket wheel setup in my 21 m340 xdrive. Has anyone had any issues with staggered wheels on xdrive drive train? Let me know! Thanks
      05-01-2024, 07:38 AM   #827
slm266
slm266's Avatar
Originally Posted by b58matt View Post
Hey Everyone,
The %difference in diameter/circumference needs to be within 1% front/back.
225/40 + 255/35, 235+265, 245+275
I’m running 245/40/19 on 8.5J+25 front (5mm spacer) + 275/35/19 on 9.5J+33 rear (no spacer) xdrive adaptive suspension eibach springs
Pay attention to maximum tire width for wheel size
      05-01-2024, 08:58 AM   #828
b58matt
Thanks for your feedback. So I’m planning on getting a really aggressive setup for my m340. Fronts I want 19x9.5 with 255/35/19 tires and rear 19x10.5 with 285/30/19 tires.
I used a online calculator and for the front circumference is -0.4% and the rear is -1.5% with the specs I mentioned. Would that be considered safe since it’s within 1%?
      05-01-2024, 09:02 AM   #829
slm266
slm266's Avatar
https://tiresize.com/comparison/
You compare front to back, that’s a 1.2% change
      05-01-2024, 09:44 AM   #830
b58matt
slm266
Kindly take a look at the percentage I got for the circumference difference. Is that too much of a difference?
Oem tires on my vehicle are 225:40/19 square
      05-01-2024, 10:28 AM   #831
slm266
slm266's Avatar
slm266
Matt, the 1% refers the new front compared to the new back, not the old front to new front, or old rear to new rear.
      05-03-2024, 09:59 AM   #832
JR340i
Drives: 22 BMW M340i xDrive
by any chance anyone know which wheels these are?
      05-03-2024, 04:31 PM   #833
Revinity
Revinity's Avatar
2020 BMW M340i xDrive on stock suspension
Brada CX2's in Satin Bronze
Front: 20x9 +25 with 245/35/20
Rear: 20x10 +40 with 285/30/20
I did end up running 3mm spacers in the front for that *little* bit of extra clearance. May not have needed it, but went with them anyway. No issues with rubbing. Attached one picture dead on from the back so you can see how they sit.
The Satin Bronze color is amazing, and changes a little bit depending on the light it's in. Figured it was a good compliment to the Cognac interior. Very happy with the quality and finish on the wheels.
HUGE shout out to Vibe Motorsports for helping me through this entire process. Vahan, you're the man. I've purchased a lot of wheels over the years and this has been the best experience I've had, hands down. They know their stuff and will follow through to make sure you are satisfied.
Name:  DSC05665 Edit small.jpg
Name:  DSC05658 EDIT small.jpg
Name:  DSC05652 EDIT small.jpg
2020 BMW M340i / Alpine White / Cognac / Brada CX2's
      05-03-2024, 06:04 PM   #834
VIBE Motorsports
General
VIBE Motorsports's Avatar
Drives: E92 M3 & F06 Gran Coupe & F10
Attachment 3448970
Attachment 3448969
Attachment 3448968
Attachment 3448971
Looks amazing!! It was a pleasure working with you!
Thank you!
Have questions? Contact us below
bmw@vibemotorsports.com.
800-814-8423 Ext 107 Ask for Tom
https://www.vibemotorsports.com/wheels
      05-05-2024, 06:29 PM   #835
zachBMW
Zach
zachBMW's Avatar
Drives: 2019 330i xDrive
KONIG Neoform’s on stock ride height G20 330i
      Yesterday, 05:40 PM   #836
manikdprsvinX5
manikdprsvinX5's Avatar
Drives: 2007 BMW X5
Went up by one inch foe my summer shoes 👞
