07-29-2023, 03:02 PM | #287 | |
General
10489
Rep 40,980
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
08-08-2023, 05:24 AM | #288 | |
Rep 6
I have an i4 m50 ... and wanted to code lane change assist , but I need bimmerutility. I only have a licensed bimmercode, so can't do it with that one Thanks Rob |
08-13-2023, 12:25 AM | #290 |
Andmdit
Rep 24
Drives: 2021 BMW 330ix
Supported OBD2 Connectors?
Sorry if this has been asked somewhere before but I wasn't finding anything in search... Is the BimmerUtility OBd2 connector the only one that's compatible with iPhone and android? I have the OBDLink CX that I use with bimmercode. Will this work? The website says
"In order to link your vehicle using BimmerUtility, you will need to use one of the OBD adapters that we support. Please note that we only offer assistance for ENET cables or ENET Wi-Fi adapters" But there is no list of the OBD adapters... |
08-13-2023, 08:30 AM | #291 | |
General
10489
Rep 40,980
08-17-2023, 09:56 AM | #292 |
Rep 314
Hello, a friend asks me for help because he has a digital meter, and would like to install it instead of the analog one, he asks me if possible to code with BU ??? do you know if possible and which line to correct? Thank you for your help
David |
08-17-2023, 10:01 AM | #293 |
General
10489
Rep 40,980
Are you saying he is doing an Instrument Cluster (KOMBI) retofit?
08-17-2023, 10:34 AM | #295 |
General
10489
Rep 40,980
Install new KOMBI, add 6WA or 6WB accordingly to FA, and VO Code KOMBI / DKOMBI and Head Unit. BU not needed for VO Coding, only FDL Coding.
Davg31110.00 |
08-17-2023, 10:36 AM | #297 |
General
10489
Rep 40,980
08-17-2023, 10:42 AM | #300 |
General
10489
Rep 40,980
No idea on Bimmercode. I don't use it. I mean just VO Code it with E-Sys and PSdZData Lite.
Davg31110.00 |
08-17-2023, 10:51 AM | #302 |
General
10489
Rep 40,980
PM sent.
Davg31110.00 |
08-25-2023, 06:39 PM | #303 |
What is this? Where am I? How did I get here?
Rep 14
Sorry, just getting started here so total noob questions.
Tried tonight to make a few changes. The youtube video for BU shows opening esys, but this is no longer required, correct? Is there a better way to track what cafd you made changes too? I'm doing the cheat codes now and keeping manual notes, but without the ability to quickly copy the cafd I am editing this is immensly tedious. Still lots of questions and I very much feel like I'm going about this the wrong way so I apologize now for what will likely be a lot of questions |
08-25-2023, 06:43 PM | #304 | |
General
10489
Rep 40,980
You need to manually keep track of what you code.
08-26-2023, 07:39 AM | #305 |
Rep 14
Thank you
More questions for the group. If I read the cheat codes or cheet sheets correctly, a modification that requires changes in multiple areas has all changes together in the same section of the cheat. Having never used previous launchers I don't know if applying a "cheat" did all the changes at once but I'm assuming so. Meanwhile BU seems to require that you apply each section of the cheat to each ecu independent. Is there any way to easily see what other ecus I should be updating if I want to apply a cheat? I feel like for any cheat I have to jump on the internet to find a forum post in order to find what all ecus I should be updating. Even reading the cheat off github doesn't help as I don't see the ecu name listed. |
08-30-2023, 11:55 AM | #306 | |
Rep 2
I see you are from Belgium like me (I'm from Flanders tho but english/french shouldn't be a problem). I have a BMW i4 eDrive40 with steering assistant, lane assistant and dynamic cruise control. I would like to enable lane assistant aswell. Is there any way you can help me out with that as you have all the tools needed to do this? I just made my account on this forum so I can't yet DM you. Sincerely, Nic |
08-30-2023, 01:14 PM | #308 |
Rep 2
