06-16-2019, 05:49 PM | #1 |
Rep 241
Had the car for 2months now. There is a rattling noise coming from either the trunk or back seats anyone had any luck identifying the mystery creaking sound in their G20??
Update on rattle with a solution: Solution for center speaker rattle: Cause: frequency of 175Hz causes the plastic grate to vibrate. The sound is created due to lack of silencing material around plastic contact points Solution: remove grate add silencing material to cover contact points. Guide: https://g20.bimmerpost.com/forums/sh....php?t=1652142
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey BMW CCA #522637 use me as a referral for BMW CCA |
06-16-2019, 06:14 PM | #2 |
Rep 911
Ok. So I'm not crazy... occasionally I hear a creaking/squeaking noise, sounds like it's coming from the back. Also, when in sport+ I hear a vibration type sound in the front, near the console.
Current: 2020 M340i
Previous: 2016 M4 Sakhir Orange Not too distant future: ///M3 or ///M5 (ED) |
DKF201.50 |
06-16-2019, 07:36 PM | #3 |
Rep 381
Only noise complaint I have is the cup holder... when my water bottle is in there it vibrates and makes a annoying quiet rattling noise.... a lot of different types of water bottles all of them make noise
06-16-2019, 08:14 PM | #4 | |
Rep 315
06-16-2019, 08:16 PM | #5 | ||
Rep 315
Vinnief96104.50 |
06-16-2019, 08:19 PM | #6 | |||
Rep 911
Current: 2020 M340i
CyclingBroStyle233.00 |
06-17-2019, 07:29 AM | #7 |
Rep 194
I bought my wife a 2019 Lexus ES350 FSport. Started hearing an annoying rattle from what appeared to come from dash. Turns out it was driver visor. Slide visor mirror cover into open position, rattle gone. Just weird where those rattles actually are. Maddening for sure.
Isow319.00 PandaMobile92.50 |
06-17-2019, 11:17 AM | #8 |
Rep 2,432
Drives: 2021 M2C
So the vaunted G20 DOES have rattles!!!
06-17-2019, 12:08 PM | #9 |
Rep 20
I don't know if it's the same thing that you guys are noticing, but check the passenger side seat belt buckle. Sometimes it coils and the metal rattles against the side of the interior when you accelerate.
CyclingBroStyle233.00 ayv_g207.00 |
06-17-2019, 01:57 PM | #10 |
Rep 315
It wasn't that...last time it happened, my girlfriend was sat beside me with the seat belt done up.
06-17-2019, 02:01 PM | #11 |
Rep 241
Potential Sources:
-Rear headrests -Rear cup holders -Cable that is attached to the roof of the trunk which allows seats to fold I plan on applying tape to all these locations. Will report back findings.
06-17-2019, 02:08 PM | #12 |
I ///M Fan
336
Rep 367
Noice can come from the trunk. Try to push on the trunk when it’s closed and listen if you do hear the noice. I Saw this in a review video.
FossieBear20.50 |
06-17-2019, 03:03 PM | #14 |
Rep 219
Drives: '19 G20 330i & '19 G01 X3
My car is rattling in the back.. I was thinking it is the middle seat belt anchor. The belt might be rattling. That was my next thing to check...
06-17-2019, 03:07 PM | #15 | |
Rep 584
But what you hear in the rear is the typical BMW shadowline trim and doors rubbing against it. Gummi Pfledge is your friend. I've had to use it on all my bimmers with shadowline trim. |
cpbandit1340.50 |
06-17-2019, 03:19 PM | #16 | |
Rep 2,432
Drives: 2021 M2C
However, if you are in a bind and want a repair quickly, I used WD-40 dry lube (which you can pick up at any Pep Boys/AutoZone). I sprayed all the door sills and shadowline real good and all the rattles went away. Quiet as a vault now. |
06-18-2019, 09:10 PM | #17 |
Rep 14
Same situation, had the car about 3 months, definite creaking from the rear, not inside the cabin because rear seat passenger says it's behind them. Not the worst noise and with radio on I tune it out, but when I am in quiet mode can definitely hear it.
06-18-2019, 09:17 PM | #18 |
Rep 381
2 months ownership can say I don't have this rear end knock your all talking about.. my cabin is extremely quiet I drive muted radio and comfort and not rattling or creaking, If its a widespread issue im sure bmw will address it, to early tho?? No??
06-19-2019, 02:20 AM | #19 |
Rep 1
Mine started creaking and rattling from the rear, just one week after buying. Worsening day by day. Noise seemed to be coming from the heat shields plates which partitions the muffler/exhaust from the base of the trunk. 2 of the 3 heat shields were creaking with applying light pressure. After readjusting the position and tension of the plates, the noise have improved but still noticeable when going over bumps and on gravel roads.
Didn't expect a new Bimmer to sound like my old school bus. |
06-19-2019, 06:47 AM | #20 |
Rep 103
No noises for me....yet (currently at 500 miles). But shadowline trim was my first thought, as I had that issue with my F30 M-Sport.
06-19-2019, 09:41 AM | #21 | |
Rep 124
Drives: 2020 M340i TB II
06-19-2019, 09:49 AM | #22 |
Rep 316
The car is very quiet inside small little noise will exasperate anyone.
