Marketplace Vendors Classifieds Engine / Drivetrain / Exhaust / Bolt-ons getBMWparts.com | New Dinan G2x Cold Air Intakes (Strut Brace Compatible)!!!
      02-22-2022, 11:55 AM   #1
Evan@Tischer
Evan@Tischer's Avatar
3822
Drives: Online Parts Sales
Arrow getBMWparts.com | New Dinan G2x Cold Air Intakes (Strut Brace Compatible)!!!
BIMMERPOST / Classifieds
Asking Price:
None
Item Interest
getBMWparts.com | New Dinan G2x 3 & 4 Series Cold Air Intakes (Strut Brace Compatible)!!!
Part Number(s): D760-0058 (G2x Mx40i), D760-0059 (G2x x30i)
Application(s):
2019-2022 G20 M340i (D760-0058)
2020-2022 G22/G23/G26 M440i (D760-0058)
2019-2022 G20 330i (D760-0059)
2020-2022 G22/G23/G26 430i (D760-0059)
Features and Benefits: (G2x Mx40i Cold Air Intake):
  • More Power: Max gains of 9 WHP and 8 lb-ft of torque @ 6500 RPM on a completely stock vehicle.
  • Enjoyably louder, sportier sound.
  • Improved throttle response.
  • Outflows factory intake by 58% or more.
  • Larger volume air box (60% larger than stock).
  • 40% increase in filter area (stock: 82 inē, Dinan: 115 inē) for optimum flow.
  • Compatible with all G2x Mx40i's with and without factory bracing.
  • Quick and easy installation
The Story (G2x Mx40i Cold Air Intake):
The M440i/M340i is an impressive car in terms of performance and style but that is not conveyed when viewing its lackluster stock intake system swaddled by seemingly unfinished strut braces. In stock trim, the M440i/M340i comes with a dry and lifeless air box housing a basic panel filter that is also accompanied by an intake resonator whose job it is to eliminate turbo/intake noises. The same noises that those in the performance world relish. Essentially BMW has seen fit to give M440i/M340i owners an air box that looks uninspiring, flows adequately but not ideally, and emits no noise. The exact opposite of what the platform exudes otherwise. The Dinan carbon fiber intake for the platform rights these wrongs and delivers a semi-open intake capable of flowing 58% more air than the stock system resulting in additional top end power and increased throttle response. At the same time revealing a more aggressive, sporty carbon fiber appearance, and an increase in sound courtesy of the removal of the intake resonator and implementation of a semi-open design.
In order to achieve the gains in flow that set the Dinan intake system apart, the entire lower box of the system, and not just the lid, has been reworked and enlarged in an effort to make use of as much of the available real estate as possible within the engine bay. In turn, this allows a 40% larger, custom, free flowing filter to be housed within and maximum flow to be realized. However, a secondary inlet has always been desired by Dinan in order to effectively fill the volume of the enlarged air box and increased filter surface area. This desire led to a multitude of experiments being conducted on the effectiveness of a possible open-air inlet in the system. With different shapes, locations, and sizes of openings being tested, the goal was to ensure that the added secondary inlet did not cause any unwarranted side effects such as an increase in air temps in the system. This is commonplace with open-air intake systems where overheated engine bay air is employed in the intake tract. The results of these tests showed that the patterned openings present in the final iteration of the box located on the opposite side from the engine provided a perfect balance of additional volume to assist the factory inlet all the while not causing an increase in turbo inlet temperatures. This was the case regardless of testing conditions (single/multiple gear pulls, constant speed, 0-100mph runs, etc.).
With more air being pulled into the system, throttle response is improved and additional power is realized in the form of max gains of +9 WHP / +8 ft-lbs of torque. The secondary air inlets also allow the intake system to be more audible so the turbo spool and BOV can be appreciated. A stark difference from Dinan's traditional fully sealed systems where induction noise is not nearly as recognizable. Not to be outdone by the increased power and sound, the outwardly visible system is made of immaculate carbon fiber so the under the hood appeal is vastly improved over its drab and utilitarian beginnings. A worthy piece to add to an already impressive vehicle.
NOTE:
For those who already own a non-brace compatible Dinan intake (D760-0052) but now want to run braces without purchasing a completely new intake kit you can order the retrofit kit (lid and hardware) separately for $84.95. To do so contact the Dinan tech sales department at 1-800-341-5480 and request part number D763-0185.
Features and Benefits: (G2x x30i Cold Air Intake):
  • Beautifully crafted carbon fiber construction (lid and tube).
  • Compatible with all G2x x30i's with and without factory bracing.
  • Quick and easy installation.
The Story (G2x x30i Cold Air Intake):
In the quest to be all things to all people at an attractive price point the 430i/330i has been reduced to a mundane, albeit pragmatic, core with elements devoid of any character both outwardly and inwardly. For example, in stock trim, the 430i/330i comes with a utilitarian and lifeless air box swaddled by seemingly unfinished braces and housing a basic panel filter that is also accompanied by an intake resonator whose job it is to eliminate turbo/intake noises. The same noises that those in the performance world relish. Essentially, BMW has seen fit to give 430i/330i owners an air box that looks uninspiring, flows adequately but not ideally, and emits no noise. The Dinan carbon fiber intake for the platform rights these wrongs and delivers a semi-open intake capable of flowing 58% more air than the stock system resulting in improved throttle response and the elimination of a potential roadblock when opting to pursue a high-powered build (upgraded turbo, fueling, etc.). At the same time the Dinan kit unveils a more aggressive, sporty carbon fiber appearance, and an increase in sound courtesy of the removal of the intake resonator and implementation of the semi-open design.
In order to accomplish the feat in flow that sets the Dinan intake system apart the entire lower box of the system, and not just the lid, has been reworked and enlarged in an effort to make use of as much of the available real estate as possible within the engine bay. In turn, this allows a 40% larger, custom, free flowing filter to be housed within and maximum flow to be realized. However, a secondary inlet has always been desired by Dinan in order to effectively fill the volume of the enlarged air box and increased filter surface area. This desire led to a multitude of experiments being conducted on the effectiveness of a possible open-air inlet in the system. With different shapes, locations, and sizes of openings being tested, the goal was to ensure that the added secondary inlet did not cause any unwarranted side effects such as an increase in air temps in the system. This is commonplace with open-air intake systems where overheated engine bay air is employed in the intake tract. The results of these tests showed that the patterned openings present in the final iteration of the box on the opposite side from the engine provided a perfect balance of additional volume to assist the factory snorkel all the while not causing an increase in turbo inlet temperatures. This was the case regardless of testing conditions (single/multiple gear pulls, constant speed, 0-100mph runs, etc.).
While the additional flow does not translate to any noteworthy rise in power output for stock or basic bolt-on equipped vehicles, the Dinan intake system does expand the potential of the platforms power ceiling. Put simply, those striving to build a more potent and robust solution, complete with turbo and fueling upgrades, will be allowed to maximize the results without worry of the intake system being a limiting factor. Regardless of the level of build, the secondary air inlets allow the intake system to be more audible so the turbo spool and BOV can be appreciated. A stark difference from Dinan's traditional fully sealed systems where induction noise is not nearly as recognizable. Not to be outdone by the increased flow and sound, the outwardly visible system is made of immaculate carbon fiber so the under the hood appeal is vastly improved over its drab and utilitarian beginnings. In and of itself, making it worth the price of admission.
NOTE:
For those who already own a non-brace compatible Dinan intake (D760-0055) but now want to run braces without purchasing a completely new intake kit you can order the retrofit kit (lid and hardware) separately for $84.95. To do so contact the Dinan tech sales department at 1-800-341-5480 and request part number D763-0185.
Contact Us today for special forum pricing on all Dinan Performance Parts!!!
Evan Winstead · Internet Parts Director
Contact Us | Facebook | Twitter | New: Shop Porsche & Audi parts!
      06-23-2022, 01:15 PM   #2
Evan@Tischer
3822
330 intake, cai, cold air intake, dinan, dinan cai, dinan cold air, dinan intake, dinan parts, getbmwparts, m340 intake
