07-17-2023, 04:41 PM | #45 | |
Rep 7,459
2) it doesn't just make it easier, it's pretty much impossible to FDL code without one. 3) esys ultra is 110 euro, that's $123 USD vs. $79.99 for the protool coding license. It's significantly more expensive, and you can't even compare the diagnostics license of protool because it's significantly more feature rich.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
07-18-2023, 01:57 PM | #46 | |
Rep 113
Drives: X63.0D, 911C4S
07-18-2023, 02:01 PM | #47 | |
Rep 113
07-18-2023, 03:05 PM | #48 | |
Rep 7,459
1) There's a reason why FDL coding exists and why launchers have been around forever.... 2) You're incorrect, if you modify the FA the dealer will be able to detect them because the FA list is cross referenced with your vin generated FA... There's a whole thread about FA coding but not writing to the VCM and why when you setup ESYS it shouldn't have update TAL and VCM upon execution..... Also when the dealer does a software update it's done via vin, so regardless of your FA it will be reverted back to default. Protool's diagnostics does far more than error code resets. It has ISTA level functionality where it can activate parts on the car like recalibrate the GHAS, release the rear e brake for servicing etc.
07-18-2023, 03:55 PM | #49 | |
Rep 113
I am happy you like Protool so much as for me don't see any advantage to the items I have. |
07-18-2023, 04:58 PM | #50 | |
Rep 7,459
Bimmercode to me is useless because it cannot code a significant amount of ecus on the car, and the freely available esys launchers can't either as they're too old and the CAFD mappings are out of date.
07-29-2023, 01:43 PM | #51 | |
Rep 113
07-29-2023, 02:12 PM | #52 |
Rep 7,459
I haven't tried this personally, but I think it's still better to buy a cheap android tablet.
08-13-2023, 09:47 AM | #53 |
Rep 113
has anyone tried to code TPMS on a RFD car from Europe using FA coding not VO code? know the changes?
08-13-2023, 09:48 AM | #54 |
Rep 113
08-13-2023, 02:31 PM | #55 |
Rep 7,459
Let us know if it works.
08-14-2023, 04:35 PM | #57 |
Rep 7,459
You should email or facebook message protool in regards to that question. I'm not sure what would be needed to code the amp.
02-12-2024, 12:07 PM | #58 |
Rep 3
Hello all,
Can someone point me in the right direction, i bought the Master license of Protool, i added 8TH in VO, now i have 3 lines on the screen and i'm stuck here. I have the original 7E SLI FSC code but i can't figure how to write it or which module to write it in. Can someone help me please? 2017 X3 F25. Thank you |
02-12-2024, 02:40 PM | #59 | |
Rep 7,459
04-08-2024, 08:21 AM | #60 |
Rep 2
Live data
Hi, new here.
ProTool questions: How do I calibrate the transfer case actuator? What section on ProTool is it listed? Also, which section can I see the live data for the wheel speed sensors? Thanks |
