Technical Topics DIYs and Coding Discussions LCI Shifter Retrofit?
      11-20-2022, 10:33 AM   #23
GOTOFMS
GOTOFMS's Avatar
I decided to install the incorrect part until the new one arrives.
Sandpiper121.50
      11-20-2022, 10:36 AM   #24
Technic
Technic's Avatar
2288
Drives: 2021 i3S, 2024 i4 M50
Please PM the eBay seller name of this shifter.
      11-20-2022, 11:34 AM   #25
Technic
Technic's Avatar
2288
Thanks!
      11-20-2022, 12:15 PM   #26
larrylam646
larrylam646's Avatar
Drives: 2020 M340i xDrive
Does the gear selector work properly i.e. can you select S programming mode?
Also retrofitted idrive controller and filler plate from an M8 to match the gloss black of the gear selector.
2020 Black Sapphire M340iX
      11-20-2022, 12:56 PM   #27
GOTOFMS
GOTOFMS's Avatar
No luck on "S" selection yet. I've been keeping an eye out for the glossy pieces to complete the look.
      11-20-2022, 10:52 PM   #28
bimmerstar
bimmerstar's Avatar
Drives: 2020 BMW M340xi
any part numbers on the gloss i drive control ?
2024 G87 Zandvoort Blue M2 w/ Buckets - Stock 93| 0-60 TBD | 1/4 TBD | 60-130 TBD
2020 G20 Tanzanite Blue II M340 xDrive - E30 BM3| 0-60 3.28 | 1/4 11.39@123 | 60-130 9.56
Past:
2017 W205 Black C43 AMG - E40 FBO No Turbo | 0-60 3.21 | 1/4 11.18@124 | 60-130 9.17
      11-21-2022, 05:55 AM   #29
larrylam646
idrive controller -65829423195
filler plate -65826995221
Reference:
https://bimmercat.com/bmw/en/search/...M8/USA/65_3121
      12-12-2022, 11:38 PM   #30
mlurker
Drives: BMW G05 X5 45e
Any way to do the opposite - replace LCI with pre-LCI?
pej744593.00
      12-13-2022, 07:06 AM   #31
larrylam646
May be possible only if your vehicle's EGS HW version can be flashed with the pre-LCI EGS FW.
Please note:
1) Without flashing EGS with pre-LCI FW, you will (likely) not be able to select S-mode. You will need to use E-sys + psdzdata (full) in order to flash the EGS and only if BTLD, CAFD, SWFK and SWFL are available for your EGS HW version.
2) Any time you replace HW that is not supported by/compatible with your vehicle (and included in your vehicle FA), SW recalls (dealers uses ISTA+), ECU ("idrive") OTA and dealer (ISTA+) updates will (likely) no longer be possible without first reverting HW back to factory. You can alway update your vehicle's ECUs SW/FW (for SW recalls and "idrive" updates ) using E-sys but doing so is not for the faint-of-heart. You really have to know what you are doing.
pej744593.00
      12-14-2022, 12:26 AM   #32
mlurker
Please note:
Thanks. Looks very complicated.
      12-29-2022, 12:18 PM   #33
Daily_Dravit
Daily_Dravit's Avatar
39
Update here?
      02-22-2023, 07:22 AM   #34
soi3847
soi3847's Avatar
Drives: BMW G20 320i M Performance
I'm not meet yet g20 lci svt list.
usually glass panel have more one swfk than matt panel.
but g20 has only matt option.
so can't ISTA firmware update and rsu ota.
      02-23-2023, 06:39 PM   #35
Davg31
Drives: G23
Hello, thank you for the information, but I can't find the link to the seller?
David
      03-06-2023, 12:48 PM   #36
hodgson-p@hotmail.co.uk
Phil
41
Drives: Bmw g05
Who is the seller on eBay with these I am after one for me g05
      03-24-2023, 07:10 PM   #37
dhock_holiday
Drives: VW Jetta
The all gloss black looks great! Now the question is will this work for LCI models, I'd like to get back the physical Auto/Start stop button and "Adaptive" option for the suspension
      03-24-2023, 07:50 PM   #38
phillyd2
Drives: 2020 M340i XDrive
I’m not going to do this but kudos to you guys as it looks interesting.
      07-11-2023, 07:38 AM   #39
Pdxordts
Pdxordts's Avatar
Drives: BMW G29
2020 BMW Z4  [0.00]
I’ve got this shifter and the clear plastic is cracked. I’d like to replace it Will I have to recode it ?
      07-12-2023, 05:04 AM   #40
larrylam646
BMW sells a repair kit for your OEM console that includes this trim piece.
Kit sells for ~ $140 for the kit.
Reference: https://parts.bmwmonterey.com/a/BMW_...l/61_6097.html
Attached is the instructions to replace this trim piece.
Last edited by larrylam646; 07-12-2023 at 05:11 AM.. Reason: Trim removal reference
      07-12-2023, 05:52 AM   #41
Pdxordts
Pdxordts's Avatar
Drives: BMW G29
2020 BMW Z4  [0.00]
Larry. Thanks so much for the info. I had no idea. I don’t see the clear part of the shifter in the illustration. I guess it’s the same for a 2020 ?
      07-12-2023, 08:40 AM   #42
larrylam646
Yes, 2019-2023... see attached screenshots for "WHAT THIS FITS" and the illustration highlighting the "clear part".
      07-12-2023, 09:57 AM   #43
Pdxordts
Pdxordts's Avatar
Drives: BMW G29
2020 BMW Z4  [0.00]
Thx larry. I also need the clear part for the shift knob.
      07-12-2023, 12:13 PM   #44
B58-M340iX
Drives: 2021 M340i xDrive
Oooh, now I need to find this same repair kit for the M3 so I can get the real OEM red start/stop button
