Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin Light malfunction message 2020 330i xdrive
      06-13-2020, 09:56 PM   #1
cattt
Drives: Bmw 330i xdrive
2020 BMW 330i  [0.00]
Right front light malfunction message just showed up when i started the car but everything seems to be working fine so should i be worried
      06-13-2020, 11:03 PM   #2
VipinLJ
VipinLJ's Avatar
Since the lights work, did you try turning the car off and back on again? Did the error disappear?
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      06-14-2020, 12:59 AM   #3
cattt
Ya the message did go away after i turned it off and on again but i guess i bugged out because i gave it a wash with a pressure washer a few days ago and wondering if that messed something up
      06-14-2020, 01:57 AM   #4
VipinLJ
VipinLJ's Avatar
That ideally shouldn’t cause problems. I’ve pressure washed mine many times and never had any issues. Did you clean the engine bay too?
      06-14-2020, 02:37 AM   #5
cattt
Nope i didn’t clean the engine bay i just did a quick exterior wash for the first time honestly. I didn’t expect the washer to cause any problems either since it supposedly puts out around 1500 psi, unless would that be a bit too much for a car?
      06-14-2020, 10:34 AM   #6
VipinLJ
VipinLJ's Avatar
It could be the pressure washer but I think there’s an increased probability that it was just a random error that hopefully won’t pop up again. If you have an obd scanner, scan and see if error codes are present?
      06-15-2020, 12:02 AM   #7
cattt
I hope its not the pressure washer, what psi is your washer running at? I wish I had a scanner but that’s probably true it may have just been error message because it hasn’t popped up ever since
      06-15-2020, 12:08 AM   #8
VipinLJ
VipinLJ's Avatar
Karcher pushing around 2000 PSI. Zero issues so far.
      06-15-2020, 03:09 PM   #9
cattt
Oh gotcha I heard good things about the karchers. I really appreciate all the help thank you!
VipinLJ1949.00
      06-15-2020, 03:10 PM   #10
VipinLJ
VipinLJ's Avatar
You’re welcome! Let us know if this issue pops up again.
cattt1.50
