02-17-2024, 12:56 AM | #771 | |
Rep 7
02-20-2024, 10:21 AM | #773 |
Rep 558
Tcarter777712.00 |
02-20-2024, 04:20 PM | #774 |
Rep 23
Tcarter777712.00 |
02-20-2024, 05:14 PM | #775 |
Rep 558
Yes I can see that - the front is darn near flush and the rear does "poke" a bit but this where it just comes down to personal preference I suppose
02-21-2024, 03:29 PM | #776 |
Rep 23
Someone with BBS CI-R tires.
20'- 9 et 25 front axle. 20'- 10 et 45 rear axle. If so, could you share experiences and if the assembly was optimal. Advisable tire, 245/35 R20 95Y, rear 275/30 R20 97Y previous. |
02-21-2024, 03:31 PM | #777 |
Rep 23
20'- 9 et 25 front axle. 20'- 10 et 45 rear axle. If so, could you share experiences and if the assembly was optimal. Advisable tire, 245/35 R20 95Y,previous 275/30 R20 97Y, rear |
02-25-2024, 10:59 PM | #780 |
Turbo fever
218
Rep 141
Drives: 2024 M340i
Garage List 2024 BMW M340i [8.75]
2014 Porsche 911 Tu ... [9.63] 2017 BMW X5M (SOLD) [9.50] 2013 Porsche Boxster S [9.00] |
Should have posted here as well...wheels are on. Love 'em.
WHEELS!
FULL SIZE https://i.ibb.co/rF4HwV3/IMG-2548.jpg
02-26-2024, 05:13 AM | #781 | |
Rep 23
02-26-2024, 07:55 AM | #782 | |
Rep 369
Did you have adaptive M suspension or stock? |
02-27-2024, 02:45 PM | #783 | |
Turbo fever
218
Rep 141
Drives: 2024 M340i
The assembly was optimal? Sorry, not sure I understand the question. I bolted the wheels on myself. They fit just fine. Friction on the front axle?? Sorry, I don't understand that concern either. For wheel fitment, I followed aggressive street specs from Apex wheels. I went with a tire choice that was of my own -- went with the 40 profile front and i haven't had any rubbing, outside of an occasional little rub when in comfort setting on freeway, hitting a big dip at speed (because I am lowered on Dinan springs). That's only happened a couple of times. Overall fitment seems pretty good. I may go to a 35 profile front, on the next set of tires. I am RWD. No spacers needed or used.
02-28-2024, 02:12 AM | #784 | |
Rep 23
My question is, if the front wheels are close to the shock strut. In my case I have adaptive, the strut is thicker. Does your vehicle have adaptive damping? Thank you. |
02-28-2024, 02:38 PM | #785 | |
Rep 23
02-28-2024, 05:44 PM | #786 | |
Turbo fever
218
Rep 141
Drives: 2024 M340i
I have adaptive and they fit fine without rubbing. Plenty of room.
02-29-2024, 03:17 AM | #787 |
Rep 23
03-04-2024, 08:31 AM | #788 | |
Rep 23
Do you think it stands out a little? Thank you. |
03-05-2024, 02:28 AM | #789 |
Rep 5
My setup
Concaver CVR5 Front 19x9 Et32 Platinum Black Rear 20x10.5 Et43 Platinum Black Tire Pirelli P-Zero PZ4* Front 245/40r19 Rear 285/30r20 The rear has no problem, but the front tire rubs the suspension "disc" (rightside more then the leftside). Solution i made, was bend a little the disc and lower the wheelhub for just a few mm and the problem was solve. I also tried the Michelin PS4S. I didn't love the stretch and it hasn't got the * (BMW only symbol). So I purchase the PZ4. But they make this type of tire for different car brands. For example, they have the PZ4* and the PZ4 L* (L= Lexus). The first one is a little stretched (i think it is use on a mini) the second one (L*) not and that looks nice in my case. PZ4 * PZ4 L* |
03-05-2024, 02:53 AM | #790 |
Rep 23
03-05-2024, 03:24 AM | #791 |
Rep 5
No other friction at all. I am affraid the wheel will stick out of the fender with lower offset. And i do not like that. 235/40r19 and 275/30r20 are the most safe decision in this case.
03-05-2024, 08:34 AM | #792 |
Rep 23
Tire 245/40 r19, has an external diameter of 678.6mm. Tire 245/35 r19, external diameter 654.1. Perhaps this is the cause of rubbing with the shock absorber disc.
