04-23-2021, 02:50 AM | #89 |
Rep 681
I have waited for the dealer to update my software to 03/2021. This was done yesterday and wiped most of my coding.
I’ve just put various coding features back in, including the tyre press and temp widget. Unfortunately, I still see only the numerical values for pressure and temperature, without the green tyres seen on iDrive.
rico2537.00 |
04-23-2021, 09:09 PM | #91 |
Rep 8
Also I was wondering, my m340i was purchased in June 2020 and I have the drive assistance package and was wondering will I be able to code in the telsa view in the instrument cluster?
04-23-2021, 10:03 PM | #92 |
Rep 207
04-24-2021, 12:58 AM | #93 |
Rep 8
04-24-2021, 01:55 AM | #95 |
Rep 207
Hi,
You need to have driving assistant professional (5AU) and Live cockpit professional (6U3) in order to have this view. I think vehicle manufactured after july 2019 should have by default. |
04-24-2021, 09:45 AM | #96 |
Rep 10
04-24-2021, 12:58 PM | #97 |
Rep 23
Download SteveAus pdf and it's the video in motion option. Pretty simple to do and bimmercode will instruct you on what to do after the coding. You need to do something manual with circle thing.
04-28-2021, 08:53 AM | #99 |
Rep 142
Drives: 2021 BMW M440i XD
Garage List 1984 Mazda RX7 GSL [0.00]
1999 Subaru Sambar [0.00] 1970 VW Beetle [0.00] 2024 BMW Z4 [5.00] 2021 BMW M440i Coupe [0.00] |
You also need to be on highway doing less than 60km/h...
I have a fully loaded G22 as well. The Driving assistant plus does not show up until I'm on the highway in stop and go traffic under 60km/h.. |
Pasty1876.00 |
04-28-2021, 11:09 PM | #100 |
Rep 357
Coding App
For some reason, I'm having trouble completing payment for the BimmerCode app on my phone. I've already contacted the developers and are waiting for further assistance from them.
In the meantime, is there another coding app anyone can recommend? |
06-02-2021, 01:47 PM | #102 |
Rep 1,479
Drives: 2020 M340Xi (G20)
G20 Cheat Sheet
Hi,
I have been following this thread and finally got around to converting my Excel spreadsheet that I use to PDF format so I could post. The codes are an accumulation of functions I have discovered and what I have picked up from this sub-forum (thanks to all of the terrific contributors), as well as some that came over from my previous F30. Believe you can use either Bimmercode or E-Sys (with either E-SysX or ProLauncher -- which is somewhat dated); the only exception is the SAS module which you can not code with Bimmercode Hope this help!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA Last edited by RSnic; 06-02-2021 at 01:49 PM.. Reason: Correctness |
06-04-2021, 10:53 PM | #103 |
Rep 7
I also got the same error while trying to code with BimmerCode once. But in reality none of the assistance systems was blocked or disabled. I tested it by driving for while and confirmed that all assistance systems were working fine . But I restored the previous ECU values from the backup in BimmerCode later.
I used bimmercode again after one week, got the same errors like the first time.After that I made another change like changing the dashboard theme or something in easy mode and coded again. The errors were gone after that. I have coded multiple times with BimmerCode to enable assisted driving view after every remote software upgrade, but I never got those errors again. Maybe it was a bug within BimmerCode itself. |
06-09-2021, 03:02 PM | #105 |
Rep 12
Does anyone know how to code it so that the car ready starts in Preset mode? It's there when I turn off the car, but when I restart it puts me in FM mode.
06-16-2021, 08:02 AM | #106 |
Rep 51
Drives: BMW 530 xdrive
hello, who can tell me how to code to have the "acc" option that I also have on my f10? thanks for the help...
06-16-2021, 09:16 AM | #107 |
Rep 6,749
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
"acc"? = Active Cruise Control? Can't code that, it's an option with a lot of hardware, not coding.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
06-16-2021, 02:11 PM | #108 |
Rep 383
Anyone know how to code the HUD to match the coded cockpit such as M Performance view?
06-17-2021, 03:38 AM | #109 |
Rep 6,749
Pretty sure the answer to this is no-can-do, but worth asking - is Auto High Beam code-able to always be on or remember last setting to avoid having to push the lower button on the blinker stalk on every start?
06-20-2021, 03:39 AM | #110 |
Rep 15
In my case it remembers the last setting without any coding. But you need to turn it on while the headlight are also on. Then the next day when it gets dark and automatic lights are on then together with auto high beam assist.
