10-23-2023, 04:49 PM | #1 |
Rep 67
Intake Valve Cleaning
Has anyone used the CRC Turbo and Intake Valve cleaner? I'm thinking of using this product but want to see what others think of it. Also, where did you inject it into the motor? It has been suggested it can be done through the MAF sensor opening. Has anybody used the MAF opening?
Thanks |
10-25-2023, 09:26 AM | #2 |
Rep 36
I've used it on a few turbos before. Spray it in just past the MAP/MAF sensor. Don't spray it on the sensor though it is petroleum based and might coat the sensor. I use a very light spray of electronic parts cleaner on the sensor. If you spray with too much pressure it might damage the thin wires.
If you haven't already add a oil catch can to help prevent the build up on the valves. |
10-25-2023, 09:50 AM | #3 | |
Rep 67
