02-14-2018, 03:08 PM | #23 | |
Rep 6,196
On the street, it was just a floor mat, so I just reached down and moved it. On the track, it was stuck throttle body, so I just left it in one gear and did a lap around the track like that to the pits, it is really not hard to slow down a car with a stuck throttle. |
02-14-2018, 04:18 PM | #24 |
1Addict
3234
Rep 7,894
+1, when my water pump went I used the button to kill my engine to keep it from overheating. Definitely works in a 2010.
02-14-2018, 05:13 PM | #25 |
Rep 3,204
I had this happen on my E30 once, the cruise control servo yanked the throttle to full open. I put the car in neutral and stopped the car on the shoulder. I did not have the cruise control engaged at the time, and was going about 40mph before we went full throttle. It was disconcerting to say the least.
02-14-2018, 07:13 PM | #26 |
Global Moderator
6381
Rep 2,309
Drives: E90 M3 6MT
I call BS on the whole thing.
The car was an E53 X5. Not only is there no such thing as a transmission that locks-out neutral at any speed but also the automatic transmissions of that generation were still "physical", meaning one could physically move the gear selector into neutral. So that throws out the "electronics glitching" theory. And then there's the key. E53 X5s still used physical keys in the ignition, where the user would insert the key and turn clockwise to start. The opposite, counter-clockwise motion would've shut the engine off. The guy had 30+ minutes. Even in a "panic" situation, there were a number of solutions available and that's before we discuss the braking options. There's simply no excuse. The guy is an idiot.
2011.5 E90 ///M3 | 6-Speed Manual | Slicktop | Jerez Black | Fox Red
E9x M3 Press/Media Archives Thread | S65-based Racing Engines Thread |
02-14-2018, 07:31 PM | #27 |
1Addict
3234
Rep 7,894
Assuming the car maxes out at 155mph, how long until the tank is empty in the heavy X5 at that speed?
02-14-2018, 07:48 PM | #28 |
Rep 1,086
Having lapped a totally stock Mustang Shelby GT 350 around a road course at full chat, I’m with you. In a pretty short time, the guy in the BMW concocted a pretty good story for beating a major speeding ticket - too bad there were a few holes big enough to drive his car through.
02-14-2018, 07:59 PM | #29 |
dances with roads
4732
Rep 4,096
02-14-2018, 08:22 PM | #30 |
Rep 6,003
Why did he avoid the spike strips? Seems like he was doing it on purpose.
MightyMouseTech4337.50 |
02-15-2018, 04:09 AM | #31 |
Rep 344
Few things he could’ve done:
- he went through a stretch of road that had guardrails. Rub up against the rails to stop the car, - throw the shifter to neutral, or even try reverse, - gently try parking brake I have a very hard time believing this is true. How much did Mercedes or Audi pay him to do this? |
02-15-2018, 07:52 AM | #32 |
Rep 1,702
I think this guy is full of shit (not you, the driver)....BUT, if my vehicle was speeding out of control, losing my tires (and any control of the vehicle I have) would be the last thing I'd want.
02-15-2018, 03:36 PM | #34 |
Rep 2,873
I 'm not saying it is legit, but on the other hand, people don't think straight under high stress (and I've heard some crazy stories about what you can get IC circuits to do with the right blitz of EMF or radiation). Personally, I'd consider rubbing a guardrail at 90+mph or hitting spike strips to be about as good an option as opening the door and jumping out - I know it is the right thing to do, but hard to bring yourself to do it. Other than hang on and wait for it to run dry, there isn't really much else to do if it won't go into neutral or shut down. I'd want to see more info on this, especially what the brake pads looked like.
02-15-2018, 11:21 PM | #35 |
11817
Rep 23,187
02-16-2018, 09:47 AM | #36 |
armchair enthusiast
221
Rep 1,019
I'm inclined to believe that it's far more likely that either the driver was an idiot or trying to get out of a ticket, than it was actually impossible to put the car in neutral or shut the car off.
I tested the "hold the start/stop button down for 3 seconds to stop the engine while moving" feature in my car very early in my ownership, since it was my first pushbutton start/stop car, to make sure I understood the feature.
'18 340i xDrive EB/Dakota, 6-speed manual, M-sport
'02 325Cic vert AW/Montana leather, 5-speed manual, premium/removable hardtop '93 850Ci Oxford Green/Parchment, auto '71 Buick Riviera, 455 V8 land yacht |
02-16-2018, 10:34 PM | #37 |
Rep 1,908
No. When your brakes overpower your tires, that's called a successful STOP or rather, a proper wheel/brake engagement! Conversely, when the car’s momentum overpowers the mechanical operation of the brakes and tires... hence why we now have ABS, that's a skid or something similar. My brakes work on ICE, as their job is to stop the rotation of the tires itself but, the momentum of the vehicle in conjunction with the ice's surface, I continue to slide. A modulating brake allows for a controlled stop over a distance v. And total brake engagement without control over a distance.
02-16-2018, 10:46 PM | #38 |
That Libertarian Guy
4039
Rep 6,363
02-22-2018, 11:54 AM | #39 | |
Rep 2,873
"As this chart shows, each car’s braking system is capable of generating more than 500 braking horsepower, and no car in this group has an engine with more than 200 horsepower. A key point to remember, however: You must brake HARD. Merely squeezing the brakes on a runaway vehicle will gradually overheat them to the point where they’ll fade to uselessness." I really wish these car mags had tried it a second or third time in a row. Not saying the guy's story was legit, just that it isn't impossible. One photo of the brakes on the SUV after all this would likely end all the speculation. |
03-01-2018, 10:29 PM | #40 | |
Gateropode
329
Rep 2,848
If the driver (incorrectly) brakes lightly for a period of time, with the gas pedal stuck, it will overheat the brakes and/or boil the fluid. At this point, even vigorous application of brakes will have marginal to no effect. |
03-01-2018, 10:44 PM | #41 | |
Gateropode
329
Rep 2,848
Neutral and engine shutoff are the proper solutions to that issue. Or a single hard, pedal to the metal brake application will get you to stop. |
03-02-2018, 07:15 AM | #42 |
Rep 6,196
Reverse is fine. It won't go into gear until it is nearly stopped anyways.
03-03-2018, 09:10 AM | #43 |
Rep 1,486
Drives: 2012 e92 M3 DCT ZCP
Has anybody be heard any update on this, or still "under investigation"?
03-03-2018, 11:04 AM | #44 |
Rep 1,850
Even if he can't think of shifting to neutral, brakes are required by law to stop the car in first gear at full throttle. A full panic stop will get the car down from speed. What kind of crazy fool gets in the situation where he is terrified for his life and has the free time and attention to fucking call the authorities but can't summon the adrenaline to press the brakes hard for a few seconds?
