01-28-2021, 03:45 PM | #1 |
Rep 343
No Phone Data on Carplay
Hi,
My iPhone 12 (I wiped the car to add this from scratch) has suddenly started to have no data when using Carplay. I can see what is happening. The phone is connecting to the car's wifi and trying to use that for internet. the giveaway is the wifi symbol on the Carplay main screen. When it works properly I see 3G/4G instead and all is fine. I have never used/tried the cars hotspot for internet. I have disabled internet in the cars settings but it is ignoring it sometimes. I tried a reboot also. If I turn off wifi completely in the car and turn it back on again it works for a bit then goes back to using wifi randomly. I need the wifi on for wireless Carplay to work though. I received July OTA update ok. Any ideas geniuses???? |
01-30-2021, 10:46 AM | #2 | |
Rep 1,161
The key bit that fixed it for me, I changed the name of the iPhone under General - About - Name. I think before it was “Steve’s iPhone XS Max” and I changed it to “Steve iPhone XS”. I then went through the pairing of a new phone and bingo, it worked! Not sure if just changing the name was the main thing, as it had been working with the longer name with apostrophe before. Good luck, hope it works! |
01-31-2021, 11:04 PM | #3 |
Rep 343
Thanks Steve. I saw what may have been your post or a similar one elsewhere. It was working before though and my phone name is fairly short. It is driving me nuts. It works fine then suddenly my phone connects to the cars wifi hotspot for internet and all data connectivity is lost. If I turn wifi off and on in the cars settings it works again for a random time, seconds to minutes then does it again! So frustrating. Will try changing name and wiping it yet again thanks.
02-01-2021, 07:31 AM | #4 |
Rep 105
Drives: G21 Touring
Garage List 2020 Porsche Taycan ... [0.00]
2012 BMW M3 Frozen ... [0.00] 2020 330e G21 M spo ... [0.00] 2012 Aston Martin DBS [0.00] 2019 Honda NSX [0.00] 2017 Aston Martin V12S [0.00] |
Hi guys,
I have exactly the same problem- no data when using car play. I have tried changing the phones name but to no avail. Let me know if you find a solution? |
02-01-2021, 08:07 AM | #5 |
Rep 68
I had to change the phones settings on my iDdrive to "not share the internet access" - so the phone still could use the WiFi connection but it didn't treat that connection as internet access.
Is this the problem? |
02-01-2021, 08:38 AM | #6 |
Rep 343
I selected Internet off in the iDrive mobile phone settings? I was told this fixes it but it hasn't for me.
02-01-2021, 08:47 AM | #7 |
Rep 68
It's not internet off, it's the sharing setting
Thread here may help https://g05.bimmerpost.com/forums/sh....php?t=1623752 |
02-01-2021, 12:43 PM | #8 | |
Rep 1,161
The reason I knew mine was something to do with my pairing was that when my daughter was in the car, she takes over the CarPlay with her Apple Music, so I knew it was something with my iPhone as hers was behaving normally. I just thought of an additional step I forgot to mention. When deleting the pairing must do step 2 below as well: 1) Delete all the connections to that iPhone in the iDrive mobile connections 2) On the iPhone, go to Settings - General - CarPlay - BMWxxxxx (for your car) and select “Forget This Car” 3) On the iPhone, delete the car from Bluetooth and Wi-fi connections 4) Make sure Internet option is disabled on iDrive in the car 5) Go through the new phone pairing process again |
02-01-2021, 11:48 PM | #9 | |
Rep 343
02-02-2021, 01:50 AM | #10 |
Rep 584
I could be wrong but clear your car details off your phone and phone details off the car so you're starting from scratch. Then just go into the CarPlay settings on your phone, don't bother with Bluetooth in the car, and connect that way. I seem to think that's how I did it and it works perfectly. So don't pair your phone to the car apart from CarPlay. Fingers crossed.....
02-02-2021, 03:53 AM | #11 | |
Rep 343
02-02-2021, 07:49 AM | #13 |
Rep 343
02-02-2021, 08:17 AM | #14 |
Rep 68
Sounds like your phone is trying to use your car as the source of data rather than your phone network. Have you tried the full remove phone from car and forget bmw on your Bluetooth and WiFi on your phone
danorman777101.50 |
02-02-2021, 08:26 AM | #15 |
Rep 57
Might this help?
danorman777101.50 |
02-02-2021, 10:58 AM | #17 |
Rep 1,161
I think the problem is with the phone not clearing out the connection properly. Have you tried another iphone?
The series of steps I posted previously sorted it for me and I'd gone through several unsuccessful rounds of trying to re-pair it. Nuclear option could be the Settings - General - Reset - Reset Network Settings Problem with this is if you have a lot of wifi networks configured, you have to reconnect / enter the password again. Did you try the 5 steps i posted before? |
danorman777101.50 |
02-03-2021, 06:03 AM | #18 | |
Rep 343
Jasperistops28.50 |
02-03-2021, 10:31 AM | #19 |
Rep 343
I followed the 5 steps and wiped my phone from the car and re-added it and touch wood it has worked so far so thank you all very much. I did shrink the phone name also so not sure if that helps also?
I will report back after a longer drive but fingers crossed. |
Jasperistops28.50 |
02-03-2021, 03:17 PM | #20 | |
Rep 1,161
Agree, losing all the stored Wi-fi settings is a nightmare. |
Jasperistops28.50 |
02-15-2021, 08:19 AM | #21 |
Rep 343
It is back!!
Worked perfectly on the way to work. Coming home my phone decided to log back on the the cars hotspot randomly and use that again. Internet in car still turned off so now driving me completely bonkers. Turn wifi off in car then back on again and this fixes it for a random few minutes. I feel a dealer visit coming on sadly. |
02-15-2021, 09:40 AM | #22 | |
Rep 1,161
