06-04-2022, 05:16 PM | #1 |
Rep 29
G20 inactivity for a long time. Battery disconnection
Hello, 2021 G20 owner here.
I need to leave the car for about 6 months without starting it. Unfortunately, it will stay outside (no indoor garage). I will buy a good car cover and use it but the main concern is the battery. A battery tender is not an option as there is no power outlet near the area the car will be. So I am thinking of disconnecting the battery. The car has two batteries. One on the bottom of the trunk and one in the engine compartment (passenger side) 1) do I disconnect both batteries? Or only the one in the trunk? 2) do I disconnect both poles? Or only the negative? Or only the positive? 3) when I get back, is it as simple as just connecting the battery(ies) and everything will work? 4) am I better off just leaving the batteries connected and let them die and replace them (or just charge them) when I get back? 5) The car has remote start. So I could start it occasionally remotely (using the app), maybe every week. But I am reading that remote start can be used only up to 2 times consecutively. Then the can needs to really start from inside in order to use remote start again. Any concerns or suggestions? Thank you ! |
Tags |
battery, g20 3 series |
