09-03-2023, 12:29 AM | #45 |
Rep 104
Drives: 2023 BMW 330e LCI M - Sport
Thank you
Looking forward to the discovery! I need this on my US 330e LCI
09-04-2023, 11:54 AM | #46 |
Rep 160
I tested
I exactly copied and pasted staging 1 and staging2
to FLM2 left and right. and now it is long ass welcome light that I would even forget it is still welcoming. I do not understand why my welcome light is for about 40sec. about at timestamp 0:24 it "does" the real welcome animation part(Left to Right) it supposed to do in the beginning. and when i lock the doors, the animation is perfect. I made compilation of all the presets that 2023 bmw 330ix has in cafd. hope it helps.. I still couldn't figure out which part to edit to make the outcome as what I want. But if we figure out the logic.. we can customize our headlight animation for sure.. it was pain in my ass to code every single items.. and test it out.. Last edited by the3mw; 09-10-2023 at 03:01 PM.. |
dhock_holiday210.50 chrish_22111.00 |
11-21-2023, 05:05 PM | #52 |
Rep 300
People are looking specifically for the EU spec one (at least not without significant delay in start). While your research unearthed a lot of potentially interesting options, that is different than the original thread.
11-21-2023, 05:12 PM | #53 | |
Rep 160
But for me if I don’t unlock from key fob,(opening by getting closer) it just works the same as eu without delay You just gotta try it. If you read the thread carefully, everyone has different outputs from the same coding. Why don't you try it and share? Last edited by the3mw; 11-21-2023 at 05:18 PM.. |
11-22-2023, 02:22 AM | #54 |
B58 Power
492
Rep 628
Sorry, still had no time :-(
Currently the car is a garage queen.
12-31-2023, 09:44 AM | #56 | |
Rep 6
Starting with Wert_18, as it is dead simple. This one does not have any animations. Unlocking instantly turns on the low beams, and it switches them off after about 20 seconds. Data looks like this: Code:
Raw: 01 00 01 01 00 Section 01: Definition 01: 0x01 0x00 Then, take a look at Wert_01. It is more complicated then Wert_18 for sure, but looks somewhat identical to Wert_18 in its effect. Unlocking instantly turns on the low beams, locking turns them off. Code:
Raw: 01 00 01 02 0A 04 01 01 9B 00 Section 01: Definition 01: 0x02 0x0A Section 04: (Why 04? Where is 02 and 03?) Definition 01: 0x9B 0x00 Moving on to Wert_3, where I actually started to count the frames. The video has 30 frames/second, thus 1 frame is about 33 ms. Code:
40 frames / 1320 ms: No light visible 3 frames / 99 ms: animation to low DLR, inner tube only 3 frames / 99 ms: animation to full DLR or even lowbeam(?), all tubes 7 frames / 231 ms: animation to medium DLR, all tubes 170 frames / 5610 ms: stays the same 3 frames / 99 ms: animation to low DLR, all butes 1 frame / 33 ms: animation to medium DLR, all tubes at least 80 frames, but cuts off: stays the same Taking a look at the data: Code:
Raw: 01 00 0C 23 00 32 00 0A 64 32 64 32 64 32 64 32 64 32 64 32 64 32 64 32 64 05 00 Section 01: Definition 01: 0x23 0x00 Definition 02: 0x32 0x00 Definition 03: 0x0A 0x64 Definition 04: 0x32 0x64 Definition 05: 0x32 0x64 Definition 06: 0x32 0x64 Definition 07: 0x32 0x64 Definition 08: 0x32 0x64 Definition 09: 0x32 0x64 Definition 10: 0x32 0x64 Definition 11: 0x32 0x64 Definition 12: 0x05 0x00 If we say that for the first two definitions of section 1, we see 0x23 and 0x32 and use that as a time unit where no animation is visible, this would be 85 decimal time units. 1320 ms divided by 85 is about 16-ish, which is close to the magic number of 16.7ms meaning the animation would run with 60 fps. But, again, doubtful... As a final one, Wert_02 has a very similar data to Wert_03 and looks kind of similar, but has more sections: Code:
Raw: 01 00 0C 23 00 32 00 0A 64 32 64 32 64 32 64 32 64 32 64 32 64 32 64 32 64 05 00 02 00 04 01 05 2B 0A 2B 14 2B 1E 03 00 03 2B 14 2B 0A 2C 00 Section 01: IDENTICAL TO Wert_03, see above Section 02: Definition 01: 0x01 0x05 Definition 02: 0x2B 0x0A Definition 03: 0x2B 0x14 Definition 03: 0x2B 0x1E Section 03: Definition 01: 0x2B 0x14 Definition 02: 0x2B 0x0A Definition 03: 0x2C 0x00 Last edited by Hyperion42; 12-31-2023 at 10:30 AM.. |
the3mw78.00 |
12-31-2023, 02:52 PM | #57 | |
Rep 5
Hello. Is yellow drl a module or is it possible with coding? |
02-07-2024, 08:26 PM | #59 |
Rep 1
MichaelNRW491.50 dhock_holiday210.50 |
03-04-2024, 09:33 PM | #60 |
Rep 300
Used the custom values in the Youtube video on my 2023 M340i xDrive and confirmed they work! No delays, it functions just like the3mw indicated and mimics the EU spec lights without any delay (although they still don't sweep left to right like the EU ones, it's more inside out).
Pasting below in case the video link ever breaks: EU spec custom values: Staging1_Data 01, 00, 0F, 19, 00, 28, 00, 3C, 00, 3C, 00, 3C, 00, 3F, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 32, 32, 00, 02, 00, 0B, 5A, 00, 21, 1E, 05, 1E, 03, 64, 03, 1E, 0D, 1E, 03, 64, 03, 1E, 0A, 1E, 21, 64, 4B, 1E, 03, 00, 0B, 5A, 00, 21, 1E, 08, 1E, 03, 64, 03, 1E, 08, 1E, 03, 64, 03, 1E, 0D, 1E, 21, 64, 4B, 1E, 04, 00, 0B, 2D, 1E, 14, 1E, 08, 1E, 06, 1E, 09, 5F, 03, 62, 03, 64, 03, 62, 02, 60, 53, 00, 03, 00, 05, 00, 0A, 2D, 1E, 23, 1E, 06, 1E, 09, 5F, 03, 62, 03, 64, 03, 62, 02, 60, 4B, 00, 03, 00, 06, 00, 03, 41, 00, 32, 43, 80, 43, 07, 00, 03, 01, 43, 64, 43, 96, 00, 08, 00, 0B, 01, 00, 21, 1E, 05, 1E, 03, 64, 03, 1E, 0D, 1E, 03, 64, 03, 1E, 0A, 1E, 21, 64, 4B, 1E, 09, 00, 0B, 01, 00, 21, 1E, 08, 1E, 03, 64, 03, 1E, 08, 1E, 03, 64, 03, 1E, 0D, 1E, 21, 64, 4B, 1E, 0A, 00, 03, 01, 00, 32, 43, 80, 43, 0B, 00, 02, 01, 00, 05, 64, 0C, 00, 0B, 5A, 00, 21, 1E, 03, 1E, 03, 64, 03, 1E, 12, 1E, 03, 64, 03, 1E, 08, 1E, 21, 64, 4B, 1E, 0D, 00, 0A, 5A, 00, 21, 1E, 03, 64, 03, 1E, 17 Staging2_Data 1E, 03, 64, 03, 1E, 05, 1E, 21, 64, 4B, 1E, 0E, 00, 0B, 01, 00, 21, 1E, 03, 1E, 03, 64, 03, 1E, 12, 1E, 03, 64, 03, 1E, 08, 1E, 21, 64, 4B, 1E, 0F, 00, 0A, 01, 00, 21, 1E, 03, 64, 03, 1E, 17, 1E, 03, 64, 03, 1E, 05, 1E, 21, 64, 4B, 1E, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00 Need to paste into both FLM modules using a tool like BimmerUtility. Last edited by alep85; 03-05-2024 at 03:30 PM.. |
phani_ch19.00 |
03-05-2024, 09:41 AM | #61 | |
Rep 160
It is all from MichaelNRW ! |
03-05-2024, 09:50 AM | #62 |
Rep 300
03-05-2024, 11:09 AM | #63 |
Rep 104
Has anyone managed to make it function correctly instead of both headlights mirroring each other? I want it like EU where it’ll swipe from one side to the other?
03-05-2024, 03:48 PM | #64 | |
Rep 300
03-06-2024, 10:32 AM | #65 |
B58 Power
492
Rep 628
We never found a way to make it sweep from left to right and back.
Maybe we need to have a look at other ECUs involved like the BDC? Something has to give the tact so left starts before right. Can someone with an US spec LCI send me a complete backup of all ncd´s? I can try to compare them to the EU spec LCI. Maybe there´s more than we currently see.
Calvindubois42.00 |
03-06-2024, 11:06 AM | #66 | |
Rep 104
Here you go! https://www.dropbox.com/scl/fo/466v2...xeys0h6gv&dl=0 I doubt my matrix high beams function 100% like EU, I’ve done everything I can. They work great but don’t seem like a sharp cutoff. If want to take a peak at that too 🤭 |
MichaelNRW491.50 |
