05-26-2019, 07:00 PM | #1 |
Rep 12
CarPlay issues
Has anybody have issues connecting their iPhones to use CarPlay? My phone finds my 330i but I don’t know what else to do to get my apps to show on the screen. Any help will be appreciated.
05-26-2019, 09:02 PM | #2 |
Rep 241
Delete device from car. Forget from phone. Re pair. Accept CarPlay on phone and car. Also under Mobile devices make sure WiFi is on
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey BMW CCA #522637 use me as a referral for BMW CCA |
PandaMobile90.50 |
05-27-2019, 02:08 AM | #3 |
Rep 448
Drives: G20 330i M Sport
I also have 'bluetooth' switched on my phone but not sure if required but worth a try
05-27-2019, 02:15 AM | #4 |
Rep 21
So, waiting for my 330i to pop out, I have been given with a fully equipped (M sport, executive package, HK, all the driving assistants, etc.) 320D xDrive for a weekend and had a chance to give it a 450 kilometers test drive. I found it superb and a great improvement over F30 (which I will replace with g20 330i within next month). One thing however which seemed not to work that flawlessly was the Bluetooth iPhone integration. The connection (iDrive as well as CarPlay modes) was dropped several times. I had to reboot the phone in order to reconnect, play with Bt, Wifi settings, delete the phone and reconnect it a couple of times. So I guess its not that rare issue.
PandaMobile90.50 |
05-27-2019, 05:31 AM | #5 |
Rep 223
I wonder, what version of iOS do you use? I read somewhere that updating from 12.2 to 12.3 solves some issues. Did it and had no drop outs this morning. 1hr drive.
Grz D.!
PandaMobile90.50 |
05-27-2019, 08:35 AM | #6 |
Rep 12
05-27-2019, 11:44 AM | #7 |
Rep 12
I just updated my phone with the latest and greatest version. CarPlay is nowhere to be found in my settings 🤷🏽*♂️
05-27-2019, 12:59 PM | #8 | |
Rep 67
05-27-2019, 04:42 PM | #9 | ||
Rep 402
PandaMobile90.50 |
05-27-2019, 08:41 PM | #10 | |
Rep 315
I’m getting my car in a few weeks having CarPlay was one of the major decisions to get this car. Maybe I should just bail out on my order. |
PandaMobile90.50 |
05-27-2019, 10:31 PM | #11 | |
Rep 422
05-30-2019, 12:18 PM | #12 |
Rep 425
I've had CarPlay in rental cars (mostly Chevys) for a couple of years now. Has worked flawlessly there.
I have a 330i on order - odd that the only car manufacturer that charges for CarPlay would have so many issues.
2019 G20 330i xDrive Med. Blue/Cognac Leather ZCV|ZPP|ZPX|HK|Remote Start (Ret'd)
2016 F06 640i xDrive Med. Blue/Red Leather MSport|B&O|Driver Asst+|Cold|Night (Ret'd) 2013 F30 335i xDrive Mineral Grey/Black Leather (Ret'd) 2011 E90 328i xDrive Space Grey/Black Leather(Ret'd) 2009 E90 328i xDrive Monaco Blue/(Ret'd) 2007 E90 328i xDrive Graphite (Ret'd) |
05-30-2019, 02:05 PM | #14 |
Rep 74
Drives: BMW 330i G20 2019 Sportline
I recently purchased the new 3 Series g20. Wonderful car.
However I am having a problem with the app waze in apple car play. As far as I know apple car play uses wifi to connect withe the vehicle. The problem is the waze app turns the map randomly and losses the route selected starting again from the point/strett where the map turns itself. Other symptom is the map turns upside down and sometimes is like the car is moving backwards in the map. Has anybody experienced this? Solutions? Update for the firmware? Connecting with usb seems not to be possible, only wifi for using apple car play. By the way, when I disconnect the iphone from the car the app works perfectly with no bugs. Thanks for your help |
06-10-2019, 08:02 AM | #15 |
Rep 3
I recently got the new G20. The first day I played with the bluetooth and tried to connect carplay it worked for couple hours and disconnected afterwards. Now I tried to reconnect over the com->mobile device and the idrive system will freeze after I tried to add a device or delete the current device. In another words, the bluetooth is not responsive at all.
Any one knows a possible solution to reset the bluetooth system of idrive? Or how to reboot the idrive system? I believe mine is in version 7.0. I tried to turn off the car, locked, turn on and it still gives me the same bluetooth issue. There seems to be a bug of it. Thank you for your help. |
06-12-2019, 06:47 PM | #16 |
Rep 422
So one of the BMWNA reps called me to check in about the car (which is a nice touch that I didn't think they would do). I told them about the only real issue I've had being the apple CarPlay. They acknowledged the issues, and said that I should try deleting my phone from the car and delete my car from apple CarPlay in my phone. After doing that, try re-pairing. They said that may need to be done whenever iOS updates. I tried it.
It didn't work. Oh well. Will wait til iDrive updates, and then try again. Bluetooth for me until then, which is sort of a bummer. |
06-13-2019, 07:18 AM | #17 |
Rep 74
Yesterday I traveled with a friend in a Jeep Compass with APC. None of the bugs described here appeared on this car. How can BMW be have so many problems with APC? Are the other makers genius in IT or the IT guys from BMW are simply narrowminded? Cannot believe a luxury?? car has so many issues
06-13-2019, 07:52 PM | #18 | |
Rep 219
Drives: '19 G20 330i & '19 G01 X3
- Via the iDrive "Apps" - You will see a grey screen with the choice to either select Installed Apps or the BMW Store. Select neither option. - Press the OPTION button near your iDrive controller. - Select "Update Installed Apps and Services." - After the update is complete, select "Close." - Activate a sleep cycle in your vehicle by pressing and holding the mute (VOL) button for 30-45 seconds with the car on but parked. |
PandaMobile90.50 |
06-15-2019, 09:45 AM | #19 |
Rep 36
Mine connects about half the time. It seems it’s beca my phone is still connected to my homes wifi when I start the car. If I manually connect to the cars wifi and disconnect/ re- connect the phone in idrive CarPlay works.
Seems like an obvious problem that bmw should have known about. |
PandaMobile90.50 |
06-15-2019, 12:22 PM | #20 |
Rep 500
Mine connects all of the time without issue but then the car / phone lose connection. It tries to reconnect but usually fails. On the next start up it's connected again.
I'm using a iPhone X with the everything up to date. |
06-15-2019, 01:23 PM | #21 | |
Rep 4,546
Clearly BMW has OS and/or Bluetooth driver issues they need to resolve. That said, Bluetooth is a pretty crap technology to begin with and it's rarely trouble free. Even previous generations of iDrive has their fair share of issues. Probably not as bad as iDrive 7 is dealing with now, but they've had them.
06-15-2019, 01:33 PM | #22 | |
Rep 500
