Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics Trunk 12V Power Port?
      06-10-2019, 08:24 AM   #1
phillyd2
Drives: 2020 M340i XDrive
Where is it?
OM says: “A socket is located on the right side in the cargo area. Unfold the cover” which from the picture looks like its next to the fuses but I can’t fine it. I have a M340i with a spare tire.
      06-10-2019, 10:42 AM   #2
Pauleebe
Pauleebe's Avatar
Drives: Inbetween BMW's.
I could be wrong, but some additional ports or power outlets depend on the packages you ordered your vehicle with.
      06-10-2019, 11:36 AM   #3
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
Trunk 12V socket is part of what is called the “Luggage Package”...
      06-10-2019, 12:51 PM   #4
Hysnbrg
Drives: 2024 X3 30;2020 M340;2016 340
Wait, is this really a thing?
Or was that sarcasm, I can't tell lol
      06-10-2019, 01:35 PM   #5
phillyd2
Don't know if Luggage Package was a joke or not either but I think I got every package available.
      06-10-2019, 03:21 PM   #6
Encanto
Encanto's Avatar
(493) Storage Package -used to be named "Luggage Package"- standard in the M340i. Used to be optional in BMW 3-Series several years ago.
My 2018 M3 has the trunk 12V socket with the standard (493).
      06-10-2019, 07:34 PM   #7
phillyd2
(493) Storage Package -used to be named "Luggage Package"- statndard in the M340i. Used to be optional in BMW 3-Series several years ago.
Good info but where is it then?
      06-10-2019, 08:00 PM   #8
Encanto
Encanto's Avatar
If you do not see it then it may have been removed from the package by the bean counters of BMWUSA.
      08-01-2020, 11:07 PM   #9
BMW11
Drives: M340
Curious why BMW took away the extra power port under the glovebox and replace it with one in the trunk?, and what advantages or usage would a typical BMW owner need a power port back there?
VipinLJ1941.50
      08-02-2020, 02:12 AM   #10
Yossi123
Drives: 330xi G21
Portable mini car fridge
      08-02-2020, 12:24 PM   #11
del82
Drives: BMW M340i xdrive
On my M340i, UK car, it is on the right hand side, just above the cubby hole.
Current: 2020 M340i
Past: M140i, Z4 35is
      08-02-2020, 12:49 PM   #12
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Hi,
On my M340 (US), I have 12v receptacle in trunk in the recess on the passenger side -- opposite of where it was on my F30.
Also, there is no receptacle under glove compartment like I had on my F30. Still have one between cupholders & one at back of console
Al
Retired: 2014 328i
BMW CCA
      08-13-2020, 09:40 AM   #13
LogicalApex
Drives: 2020 BMW 530xe
2020 BMW 530xe  [0.00]
Check the order guide and your Window Sticker.
If it is supposed to be there and is missing it may be a factory mistake. Sort of how my G30 is missing the valet switch for the trunk in the glove box because they forgot to install it at the factory...
      12-25-2021, 06:36 PM   #14
Mccobk01
Mccobk01's Avatar
2020 M340i  [0.00]
Outlet
Was anyone able to figure this out? I’m looking for the outlet in my 2020 M340i cargo area and cannot seem to locate the 12v outlet back there. The owners manual seems to indicate there should be an outlet. Is it hidden and how do I find it?
      12-25-2021, 11:00 PM   #15
VipinLJ
VipinLJ's Avatar
It isn't hidden. It's in plain sight. Photo from my 2020 330i attached below.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      12-26-2021, 12:52 AM   #16
Mccobk01
Mccobk01's Avatar
2020 M340i  [0.00]
Hmm, not there on my 2020 M340i
      12-26-2021, 03:14 AM   #17
Bc2005
Drives: 2021 M340i
I have one there in my 201 M340i. It’s hard to see and at an unusual angle, so maybe look a little harder.
My F30 also had a power point up under the dash near the passenger’s left foot, and one in the rear console. Both were very convenient locations.
      12-26-2021, 06:58 PM   #18
VipinLJ
VipinLJ's Avatar
That's weird that my 2020 330i has it whereas your 2020 M340i doesn't. And apparently the 2021 M340i has it too? Idk what BMW was thinking!
      12-26-2021, 06:58 PM   #19
Mccobk01
Mccobk01's Avatar
2020 M340i  [0.00]
Missing
Did a thorough check and absolutely no outlet or outlet covers located in the cargo area. I have a spare setup and wonder if maybe they left it off because of it?
      12-26-2021, 07:01 PM   #20
VipinLJ
VipinLJ's Avatar
Ah that may be the case. Mine came with RFTs and a deeper trunk.
      12-27-2021, 05:15 AM   #21
G22b58
Drives: G22
In my configurator it's noted, in the option 493 which includes the 12V outlet in the trunk, that it is deleted when the spare tire option is selected. Don't know the reason but that gives the answer.
      12-27-2021, 10:20 PM   #22
Mccobk01
Mccobk01's Avatar
2020 M340i  [0.00]
Outlet
Thank you, I was wondering if that was the case. Could be differences in the panels. That suing said, I wonder if I have one hidden behind the panel?
