08-07-2019, 08:57 AM | #46 |
Rep 2,290
08-07-2019, 09:22 PM | #47 |
Rep 78
No issues with the sensors in the one time I drove/parked it since install
24 M3 xDrive Fire Orange - Incoming PCD
23 M2 Manual Sapphire Black 21 M3 Manual Brooklyn Grey 20 M340i Portimao Blue 11 E92 M3 Space Gray |
Bmwguy199424.00 HapkidoNinja43.00 |
08-10-2019, 10:45 AM | #50 | |
Rep 12
How difficult was to amount sly bracket? How do you like it so far? |
08-10-2019, 07:17 PM | #51 | |
Rep 2,290
https://g20.bimmerpost.com/forums/sh...1599592&page=2 |
08-14-2019, 07:18 AM | #53 |
Rep 3,074
Drives: G06/G20/F30/F15/F10/E90
I just bought this item and I confirm it doesn't fit ... someone said that the F30 hooks can fit the G20 but turned out not true
https://www.amazon.com/dp/B01JHERJJ4..._.T.uDbNJ3TH0N Looking for suggestion thanks! |
08-14-2019, 08:59 AM | #54 | |
Rep 2,290
If you read my post above, you will see a related thread where folks have discussed another product that appears to be successful. |
08-14-2019, 12:34 PM | #55 | ||
Rep 3,074
Pauleebe379.50 |
08-16-2019, 06:42 PM | #56 | |
Rep 3,074
08-17-2019, 11:11 AM | #57 |
Rep 2,290
Really? Others have posted its working fine in the other thread.
08-17-2019, 12:41 PM | #58 | |
Rep 3,074
08-18-2019, 10:39 AM | #60 |
Rep 78
Here's my cravenspeed which is still having zero sensor issues after a couple weeks on the car
Pauleebe379.50 |
08-18-2019, 02:52 PM | #61 |
Rep 32
My cravenspeed arrived yesterday. I was able to install and after about 5 mins or so of adjusting, was able to get it to work without triggering the sensor. I did want the plate to be a bit more front facing, so I then bought a washer and am using the larger hole to move the plate a bit more center and more front facing. This worked pretty well and no sensor issues.
The only bummer is that while I was adjusting it, the plate did lose its hold and rotated - slicing a small gash in my PPF. I’ll get it fixed, but annoying for sure. The other note is the cravenspeed uses imperial screws to fashion the plate to the holder. I ran to Home Depot to find the bolts in black, but they did have them. Going to get them from a local hardware store or amazon on Monday. |
08-19-2019, 07:54 PM | #62 |
Rep 2,290
Finally got mine installed too:
Didn't drive it around a bunch yet, but pulled in and out of a parking spot and turned on the parking sensor/cameras, and no sensor went off. I think it's safe to say this solution works on the G20 without tripping sensors. EDIT: Photo link died so had to re-upload Last edited by Pauleebe; 08-20-2019 at 12:39 PM.. |
08-20-2019, 10:12 AM | #63 |
Rep 12
I installed the same one yesterday. I was alittle nervous about the plate/the screw hold touching and scratching the bumper so I taped some adhesive to the back of the plate. After adjusting around, it seems to work pretty well.
However, it will throw off PDC when I am closer objects (close to the car in the front or when parking). I am not sure which part is throwing off the sensors. I noticed there is a sensor by the fog light in lower grill as well. |
08-20-2019, 11:01 AM | #64 |
Rep 49
I installed the CravenSpeed mount last Saturday. Initially noticed the front sensor was triggered occasionally, but I played with the mount's positioning and stopped having issues.
08-20-2019, 12:47 PM | #65 | |
Rep 2,290
As an FYI, when my vehicle approaches a close item (gate at my parking lot is an example), the sensors are tripped. However, this happened prior to this bracket and is a function (or flaw?) of the car's design itself. If helpful, my bolt is installed all the way to the right side of the hole in the bracket. I haven't had any sensor issues and will report back if I do. |
08-21-2019, 10:04 AM | #66 |
Rep 12
Just want to update you guys...
I removed the license plate holder and removed the small padding in the back that I have placed. The padding was less than 0.5cm thick. Reinstalled everything and it's no longer tripping the PDC sensors. I think the system may be too sensitive and picking up padding for some reason. It will go off when I pull into a parking spot and if I am closer to an obj but seems the plate does make the system think that there is something closer. Overall, seems like it's working well now. |
Tags |
license plates, towhook |
