09-11-2023, 11:34 AM | #23 |
Rep 313
Can you give me like a walkthrough or a step by step of your process for installing. It got delivered today and I just wanna make sure I’ll get it done properly
09-24-2023, 11:27 AM | #24 |
Rep 441
Instead of swapping shifter I swapped entire car. Id8/no shifter/no laser lights drove me insane
Current 2016 435i X-Drive Gran Coupe AW
Previous 2015 335i X-Drive Sedan EB |
11-02-2023, 08:03 AM | #25 |
Rep 17
11-03-2023, 10:30 AM | #26 |
Rep 313
12-28-2023, 10:11 PM | #27 |
Rep 267
Drives: 2024 BMW X5 G05 LCI
Glad I found this thread. How has it been working? Is any coding needed? I have no idea how to code, and from what I understand there is no more coding on 2024 LCI vehicles.
Any advice on this swap will be appreciated! And FB wont accept me either! Last edited by PJ///M; 12-28-2023 at 10:12 PM.. Reason: Update |
12-28-2023, 10:15 PM | #28 |
Rep 573
Drives: 2023 BMW M340i
Nope, plug n play. Just look up a video on how to remove the center console trim and after you do that it’s just four t20s and it comes off. Then you just unplug the two wires connecting and just install the new shifter.
01-02-2024, 05:40 AM | #29 |
Rep 267
Thanks, I have disassembled and reassembled the center consule twice, each time failing to disconnect the two wires that are plugged into their harness. I'm going to try my third time today now that I found a video of how one of the wires unlatches from its harness. The other seems to be just a very typical connection that I just can't get to budge. I've disconnected the battery each time, but the second time I failed my attempt and then put everything back together again, after connecting the battery, I had an alert that my parking break malfunctioned and my vehicle wouldn't respond or turn off for about 2 to 3 minutes. I then locked everything up and came back in five minutes and it's back to normal. I don't know what I did to cause that but of course now I'm hesitating going back in for a third time. I've read the stories on here of how people have bricked their car making a swap. Again appreciate the community help and any more advice is much appreciated.
01-02-2024, 09:35 AM | #30 | |
Rep 573
PJ///M75.50 |
04-02-2024, 06:23 PM | #31 |
Rep 46
Tried this today and completed the pre-lci selector swap with some struggle (front clips and pink connector). The pre-lci shift lever works but not any of the buttons. Does the module need an update? anyone have insight on how to get these to work? Car is '23 LCI
04-03-2024, 09:31 AM | #32 | |
Rep 573
04-05-2024, 02:27 PM | #33 |
Rep 267
Uninstalled and selling.
If interested here is the link. https://www.bimmerpost.com/forums/sh...php?p=31048603 |
04-06-2024, 11:22 AM | #35 | |
Rep 267
This is authentic OEM BMw Here is one for Sale on ebay and it doesn’t even have all the functions available like lowering and lifting suspension. https://www.ebay.com/itm/15497589359...3Avlp_homepage Here is the shifter on IND: https://ind-distribution.com/product...RoCtLYQAvD_BwE |
XxSullyxX12324.00 |
04-06-2024, 01:48 PM | #36 |
Rep 59
OK, the ones I'm talking about are definitely oem and not knock offs but they arent glass like that one. They are the OEM g20 pre-lci m340 consoles a bunch of guys have bought on here. They are taken off of cars not brand new from BMW where you'd surely pay more than I'm talking about I'd imagine. What your selling maybe isnt compatible with the 3 series youre posting in. Thats the confusion. our suspensions dont raise etc.
2024 BMW M340i xDrive
PJ///M75.50 |
04-06-2024, 01:55 PM | #37 | |
Rep 573
PJ///M75.50 |
04-06-2024, 02:19 PM | #38 | |
Rep 267
Thanks for pointing it out! |
04-18-2024, 03:48 PM | #39 |
Rep 2
I'm in the middle of this swap now but seem to be stuck. Anyone know how to remove the CPU harness (small red one) from the bottom of the shifter? I have tried almost everything and I cant get this thing to budge. I attached an image of it.
PJ///M75.50 |
04-18-2024, 04:10 PM | #41 |
Rep 267
[QUOTE=tendafoot;31083921]I'm in the middle of this swap now but seem to be stuck. Anyone know how to remove the CPU harness (small red one) from the bottom of the shifter? I have tried almost everything and I cant get this thing to budge. I attached an image of it.
That one pulls right out. I had the same problem as you. It was really tough to pull it out, so I had to use needle nose pliers to wiggle it out. Just make sure to to pull by the wires themselves! The one with the latch was a problem for me too. I had to find YouTube videos for that one. |
04-19-2024, 07:18 AM | #43 |
Rep 267
