12-30-2023, 03:26 AM | #1 |
Rep 30
Condensation on headlights
Hey
I've recently collected my 340i from the dealership and had noticed condensation forming on the nearside/left headlight. I understand that BMW calls this out in the operating manual as normal and that the condensation should disappear after mild usage. In my case, however, the condensation never really disappears and only happens on the left headlight. I've attached pictures to serve as reference. For people that have recently collected their G20, are they also experiencing some levels of condensation? I'm in London so the weather isn't excessively cold. Thanks! |
12-30-2023, 04:38 AM | #2 |
Rep 138
I had a bit in mine (both sides), bit less than yours though: was just mist on the inside of the lenses, no drops of water. I noticed it after I first drove it on a wet / cold day (so basically as soon as I got the car at the start of November). Haven’t seen it since despite keeping an eye out for it. The manual says “ If moisture increases, for example if there are water droplets in the lamp despite the head- lights being switched on, have the headlights checked” so I think if there are water droplets there and it never goes away I’d get the dealer to check it, even just for peace of mind.
12-30-2023, 12:32 PM | #3 | |
Rep 30
02-15-2024, 05:46 AM | #4 |
Rep 4
I just picked up my 2024 m340i and this happened. I think this is definitely not the normal amount that bmw expects, but what do you guys think? I definitely will still take it in to get it checked but it looks like the housing isn’t cracked at all.
02-15-2024, 06:19 AM | #5 |
Rep 8,095
Looks perfectly normal to me. The housings are not hermetically sealed and with the relatively low forward heat from LEDs it's to be expected.
Ian
02-15-2024, 09:47 AM | #7 |
Rep 138
That's not dissimilar to how mine looked when I first drove it in the rain after I got it: bit more there than there was in mine though. Only noticed it once in mine since, so you may well find yours resolves after a bit of time.
02-15-2024, 09:53 AM | #8 |
Rep 30
I'd concur with everyone else's comments. Also, the condensation subsided after a while and I no longer get the same amount as I did when I first got the car.
It might be better to wait and see if it subsides for you, too! |
04-22-2024, 05:22 PM | #10 |
Rep 518
Mine now look like this. The one with heavy condensation in doesn't clear even when it's been sat in the sun for hours. I've never used a pressure washer - only ever hand wash with a gentle hosepipe rinse. No sign of any damage such as stone chips etc.
G26 420d Gran Coupe MSport Black on black, MSport Pro Pack, Comfort Plus Pack, Harman Kardon audio
04-23-2024, 02:56 AM | #11 |
Rep 1,158
NS one most definitely needs replacing.
04-23-2024, 03:15 AM | #12 | |
Rep 280
As for the others and already commented, all others look to be normal. Even the new Merc I have now does it, worse than my bmw ever did, but again it’s all normal. |
04-23-2024, 04:45 AM | #13 | |
Rep 2,199
I have just had both of my rear light units replaced at my local dealership yesterday under warranty (my car's 17 months old) as they had water droplets forming in them. My front units do fog at times depending on weather conditions but certainly not to the extent of your NS one. Keep the photos you've put on here and have them available to e-mail to the dealership it will massively help to support your case to getting it sorted especially as you can show the stark difference between the units! |
zlatko135.50 TuffLittleUnit112.00 |
