2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions How do you close the hood?
      11-30-2020, 12:30 AM   #1
jbarba
jbarba's Avatar
Spain
44
Drives: G21 320i
Im unable to close the hood in one step. I need to make it in two steps:
1.- Let it down from 30/40 cms. Engages a bit, burt not totally (like when you push one time to open it)
2.- Comoletely close it pushing on both sides at the same time.
User manual said that must be done in one step, but doing so hood stays open.
      11-30-2020, 02:00 AM   #2
Yossi123
Drives: 330xi G21
Do not push the hood it as it may bend.
You need to find the proper height to drop it, most likely it will be more than 40cm.
Check out this thread: https://g20.bimmerpost.com/forums/sh....php?t=1689668
jbarba44.00
      11-30-2020, 08:14 AM   #3
Amos91
Drives: G20 320d
Slam it down harder should cover you 😅
      11-30-2020, 09:02 AM   #4
rcz22
Drives: 2024 G80 M3 6MT
I was just in for service - my new 2021, wouldn't close all the way on the passenger side, leaving a 1in gap - since I also did not want to bend the hood I brought it in...
the tech had to make a minor adjustment to one of the springs, but more importantly he told me that the bmw emblem is meant to be pressed on
so drop the hood gently until it stops... then to close all the way press with the palm of your hand on the bmw emblem - that has worked for me since.
MBM3401026.00
      11-30-2020, 09:51 AM   #5
Soul_Glo
Soul_Glo's Avatar
Drives: G20
I drop it from above 50 cm. Around 30 it doesn't lock properly and I have to push down which doesn't always work.
      11-30-2020, 10:26 AM   #6
SportySpice
SportySpice's Avatar
You have slam it down (or close "energetically" per the manual). It's much lighter than the F30 hood so just letting it drop won't work and pushing it into place once it's nearly closed may dent the hood.
Soul_Glo13342.00
      11-30-2020, 10:42 AM   #7
Merami fan
めらみぽっぷ fan
Merami fan's Avatar
Drives: 2020 330i xDrive
^ Do not push, especially on the sides. It's designed to be slammed. Just unlatch it and try to slam it again if it doesn't close properly.
I thought it was stuck/defective at first, too. Seems like it's the same on all G generation cars (same on 2 X5s I tried).
Username and profile picture in admiration of the goddess of treble, めらみぽっぷ (Meramipop).
https://www.youtube.com/watch?v=fQYWhQXOeQg
https://open.spotify.com/playlist/1w...1L3y6cmPEyGSoI
      11-30-2020, 01:40 PM   #8
jbarba
jbarba's Avatar
Spain
44
Drives: G21 320i
Thanks for all the replies!! I'll test it from 50 or more cms.
      12-01-2020, 09:14 AM   #9
gofast182
Drives: 2020 M340i xDrive
After picking up my new M340i at the Performance Center last Dec. we drove to Asheville for a few days. As we're getting ready to leave for home the valet brings my 3 day old car around and one side of the hood isn't latched. Upon further inspection there is a slight dent. Turns out the valets at the hotel wanted to check out the engine and couldn't get the hood closed (they were reprimanded and the hotel paid for the PDR). Moral of the story is close the hood by letting it drop, not pushing on it.
2019 X5 xDrive 40i, Mineral White
2006 S2000, Berlina Black (Track car)
jbarba44.00
      12-01-2020, 09:24 AM   #10
M340i Pride
Drives: 2020 BMW M340i
I gently "drop it like its hot" from the top position, all the way up. Not slamming it mind you, but because of the height, just a gently push down is enough to lock it up nicely.
jbarba44.00
      12-01-2020, 09:52 AM   #11
jbarba
jbarba's Avatar
Spain
44
Drives: G21 320i
haha, i'll drop it like it burns. and from top. really like this metaphor.
      12-01-2020, 11:48 AM   #12
SportySpice
Dropping doesn't cut it. The hood weighs nothing. You have to put some effort behind it.
jbarba44.00
