12-02-2020, 12:50 PM | #1 |
Rep 134
What's the fastest you went?
Curious to see numbers on what speeds everyone reached. Of course these numbers were obtained in a legal fashion. I've gotten to 135/7 MPH stock 2021 M340. I assume I have a speed limiter since the car wouldn't go faster than that.
12-02-2020, 12:57 PM | #2 |
Rep 5,484
Drives: 23 X7 40i; 23 M3; 24 cooper s
Same here, 135 mph. I was actually pretty surprised and disappointed when I hit the limiter at that speed because I had read beforehand that the top speed was limited to 155 mph, and especially considering the M340i still had a lot of steam to keep going. But I suppose it's better for my safety.
2023 BMW X7 xDrive40i
2023 BMW M3 6MT 2024 Mini Cooper S Convertible '20 BMW m340i... '20 BMW X5 40i... '16 Infiniti Q50 RS 400... '10 Lexus RX 350... '08 Lexus IS 350... '00 Nissan Maxima... '93 Nissan Maxima |
12-02-2020, 01:00 PM | #4 | |
Rep 134
wtwo317968.50 |
12-02-2020, 01:01 PM | #5 |
Rep 134
Sometimes I'm cruising and then look down and I'm at 110. It's so effortless and handles so well you don't even realize you're going that fast. Very impressive but can get dangerous if you're not paying attention.
M340i Pride209.00 |
12-02-2020, 01:05 PM | #6 |
Rep 1,712
oh yes same thing happens to me often... Cruising on a fwy and i am barely on the throttle, its an EASY 95 lol. Got to be careful.
12-02-2020, 01:37 PM | #7 |
Rep 3
The fastest I've gone is 165mph (in Mexico). I ran out of room or else I would have done a top speed run. I'm Stage 1 Tuned by Carbahn Autoworks with squared PS4'S at 245/35/R19. Before the tune I was limited to 131 because the car came with all-season run flats rated to 130.
12-02-2020, 01:38 PM | #8 | |
Rep 5,484
And yes, the track and cooling packages gives you that 155 top speed. I just didn't realize this until after I hit that limiter at 135 one day and had to come back and research why my car wasn't getting to the listed top speed
MBM3401026.00 |
12-02-2020, 02:01 PM | #9 |
Rep 2,964
160ish Mission Stage2 2017 340 deserted desert road on the way to the BMW thermal performance driving center - car still had more to give I did not
138 on the water and that felt waaaay faster than the 160 in the car - my knees were literally shaking an hour later |
Musaabi119.00 |
12-02-2020, 02:05 PM | #10 |
Rep 6,233
Drives: 2018 340i M Sport
Actually the 155 mph is based on the tire/wheel set up that came from the factory. It’s not necessary to have the track package. If the car came equipped with staggered, high performance, summer tires the limiter is set at 155. If it came with a square, all season set up the limiter is set at 130 mph.
12-02-2020, 02:12 PM | #11 |
Rep 134
My legs would be shaking at 160 as well
12-02-2020, 02:13 PM | #12 | ||
Rep 134
12-02-2020, 04:19 PM | #13 |
Rep 7
160 (258km/u) in my stock G21 330i on the German Autobahn ;-)
12-02-2020, 04:19 PM | #14 |
1942
Rep 3,521
I've hit 135mph as per readings obtained from the OBD port (live cockpit only showed 130 and wouldn't increase since the road was flat though OBD readings said 135). Dragy at the same time verified that it was 129mph and not increasing. Our cars have limiters because of the tyres.
12-02-2020, 04:27 PM | #16 | |
Rep 134
12-02-2020, 05:00 PM | #17 | |
1942
Rep 3,521
I swapped tyres today (got non-RFTs since the OEM RFTs were at 5/32). There's a feature called auto learn in the TPMS part of the iDrive. It couldn't learn about my tyres but I guess it might be able to do it on BMW approved tyres? Not sure if that changes the speed limiter if it detects high performance summer tyres.
12-02-2020, 05:40 PM | #18 | ||
Rep 134
12-02-2020, 05:49 PM | #19 | |||
Rep 134
12-02-2020, 06:38 PM | #20 | ||
Rep 2,557
Stupid is wanting to go 150mph but not understanding 1) tire construction and safety limits 2) the optimal way to order your car to safely do so. BMW knows most of their customers don't care to know these details but might roll the throttle to the floor on occasion, hence the reduced limiter |
12-02-2020, 06:42 PM | #21 | |||
Rep 134
12-02-2020, 07:36 PM | #22 | ||||
Rep 2,557
2)the setting you refer above to will not change the speed limiter it will only change the recommended tire pressure. why? See your own comment about being able to enter inaccurate information. The only way to get the limiter changed is through coding. |
