Technical Topics Wheels and Tires 235/40/19 or 245/35/19 for Xdrive adaptive suspension
      03-27-2024, 09:28 AM   #1
Vortexshifter09
Drives: M340 2020
Want to ditch my 225/40/19 for either the 235/40/19 or 245/35/19 I have the 792m wheels not sure if they are 8 inch or 8.5 inch wide. Which would be my best bet? I’m looking at ps4s? I’ve seen that long forum about tire sizes already but not much is mentioned about 235/40/19 on a adaptive suspension Xdrive
Which would be better for handling and cutting up
      03-27-2024, 03:20 PM   #2
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
I went from the stock RFTs to 235/40 Pilot Sport All Season all around and definitely think it is an improvement, although hard to say if that has more to do with being Non-RFT versus the different width.
Keep in mind a 235/40 will have a slightly taller sidewall than a 225/40 (but still within the 1% tolerance), so the wider tire should be a bit smoother/better at absorbing bumps also.
Current: 2021 340xi
Retired:
2018 330xi | 2016 340i 6MT | 2013 335i 6MT |
2011 328i 6MT (N52) | 2008 335xi (N54)
      03-27-2024, 03:26 PM   #3
peelerec
peelerec's Avatar
988
2022 BMW M340i  [0.00]
I highly recommend 235/40/19. Definitely improvement in grip, handling and comfort.
      03-27-2024, 04:38 PM   #4
prostcfc
prostcfc's Avatar
Drives: 2020 BMW M340i
Why would a 1% difference from stock matter if running square? The 1% bogey is cited for xDrive cars that run staggered setups. Am I missing something other than a trivial speedo error? For e.g., I'm moving to 245/35-19 for my current 19x9 track setup, which is ~1.3% different from stock.
      03-27-2024, 09:16 PM   #5
XxSullyxX123
XxSullyxX123's Avatar
24
Drives: '24 M340i xDrive, '20 Rubicon
You are correct. The 1% is front vs back for the transfer case on the xdrive system.
2024 BMW M340i xDrive
      04-01-2024, 12:31 PM   #6
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
Right, I was actually referring to the spedo error, but your right, that is nota big deal anyway
Current: 2021 340xi
Retired:
      04-01-2024, 08:01 PM   #7
I800C0LLECT
I800C0LLECT's Avatar
Drives: BMW M340
I have staggered wheels with xdrive and just ordered 225/45/19 and 255/40/19 tire sizes. It should give me an extra half inch of sidewall. Can't wait to see how it rides
      04-18-2024, 08:11 PM   #8
GreenStreet
Drives: 330
Any updates on how these fit and ride? Any pictures?
      04-18-2024, 09:27 PM   #9
I800C0LLECT
Drives: BMW M340
Sidewall is half inch thicker. It rides nice and smooth. Pilot sport all season 4 is a great tire. It’s not a dramatic difference vs the run flat. Nobody in my family noticed the difference in ride quality but it is smoother for sure. The bumps aren’t quite as harsh…but again, nobody noticed but me
      04-18-2024, 11:33 PM   #10
GreenStreet
Drives: 330
Good to know. I was hoping the added sidewall would make a more noticeable impact on comfort, but doesn’t sound like there would be a huge benefit (I switched to the PSAS4 in stock sizes already). Thanks for sharing!
