04-02-2021, 11:49 AM | #23 | |
Rep 1,168
2020 M340xi PB (sold)
Banana Clipper330.50 |
04-02-2021, 02:20 PM | #24 |
Rep 80
I actually have a set of the PS4, just waiting for my wheels to arrive so I could put them on.
04-02-2021, 03:41 PM | #25 | |
Jewel Runner
331
Rep 911
I dont doubt it but I do want to be wrong
04-02-2021, 03:44 PM | #26 | |
Jewel Runner
331
Rep 911
My neighbors 2001 Integra has wider tires than the OEM 225's LOL Just for the lulz I'm toying with the idea of slapping on some Federal RS RR's you can get all 4 in the proper size for about $500 mounted and the reviews on track use are pretty stellar. I usually run Conti DWS 06's though so I'd be going against my better intuitions.
04-02-2021, 03:46 PM | #27 | |
Jewel Runner
331
Rep 911
At the drag strip, same thing, car got a little more sideways, as the tires just spun, than I was comfortable with and had to let up and ran a 12 sec 1/8th mile lol The track was pretty well prepared and it wont get better than that on the street. Launching in 2nd around 2krpms the car hooked and made boost out the hole. I'm sure the trans didnt like it but I wont tell if you dont.
04-02-2021, 06:13 PM | #28 |
Rep 462
I experienced the same and got rid of the jb4 it worked well on the old f series but not the G20, the newer dme pulls limits torque a lot more and I see that with flash tuning which is why tuners are now lessening torque limiting in flashes, but the jb4 cannot do that and bef isn’t that great either
04-02-2021, 11:03 PM | #29 | |
1942
Rep 3,521
I'd suggest testing map 0 and then map 2/3 (whichever you run daily) on the same road. If possible, on the same day to rule out the effect of ambient temp.
04-04-2021, 06:43 PM | #30 | |
Jewel Runner
331
Rep 911
I’ll be back out at Sonoma on the 14th and will perform my original test As you mentioned, there is a valid increase in performance between the maps and I’m satisfied with my purchase. On one of my last runs this past week, I was so stoked I ran a 8.04 on a 8.00 dial that I let off at the 1/8th mile mark and still ran a 12.6 @ 92mph just coasting from about the 1000’ mark, so safe to say this is an 11sec car with just a JB4 Car was heat soaked the entire night and temps never got below 140/150 but I know why and won’t repeat those mistakes. 3hrs driving in traffic with the AC on, flying through tech in 5 mins and straight to the lanes before running every 30mins sounds fun but never gave the car a chance to cool down. Also, the engine covers just trap heat like crazy. After removing mine the temps finally started getting into normal ranges but lack of cars kept me running every 30mins or so 14th is full quarter mile, finally, and I’ll bring an extra phone dedicated to the Draggy so I can live stream the runs, capture draggy and waylens data and log via JB4
VipinLJ1941.50 |
04-04-2021, 11:17 PM | #31 |
1942
Rep 3,521
Can't wait for your quarter mile runs on the strip!
And yes. I personally believe the G20 is limited by it's cooling management. Lots of heat soak.
04-15-2021, 09:56 AM | #32 |
Jewel Runner
331
Rep 911
Copied from above for historical value
##################3-31-21 UPDATE################## Got some good and bad data from the drag strip today Car needs a CSF heat exchanger Driving to Sonoma and hot lapping results in poor 1/4 mile times Launch the car with all nannies off in 2nd @ 2000rpms Run flats do hook, I wasnt imagining it Its late and I just got home so I'll provide a better update tomorrow with videos and the few logs I did get but essentially the car was heat soaked from the 3hrs drive through traffic to get up to Sonoma and I ended up going straight through tech in all of 5 minutes before going straight into the staging lane with barely enough time to put my helmet on before getting my first run in Again Sonoma was only doing 1/8th miles and I ran everything from mid-9's t0 8.04. Again, more details tomorrow
07-01-2021, 08:18 PM | #33 |
Rep 32
Nice times..I was able to get a 12.3@116mph in a 2021 M340. Only.mod was JB+ turned all the way up with a E30 mix, 93 octane and E85, so around 96 octane I guess.. I have trapped 117mph on the street before recorded by draggy..I'd love to get a 11.9 with nothing but JB+ and E85 mix sometime.
07-02-2021, 11:12 AM | #34 |
Rep 524
Nice time given your level of mods. are you RWD or AWD? And what was your 1/8 Et/speed?
07-03-2021, 10:11 AM | #35 | |
Rep 32
8.126s @ 91.91mph in 1/8. The car is RWD. Not the best launch on these 225 tires. Think the car is making the power for a high 11s pass though. My 1/4 time is in the range of a stock car but the 116 - 117mph trap speeds are better than stock and the car just feels better to drive with JB+ Last edited by cjpp78; 07-05-2021 at 02:23 PM.. |
07-03-2021, 02:40 PM | #36 | |
Rep 524
8.05@92.13 with a full to the brim tank and 88 degree weather. |
07-03-2021, 03:16 PM | #37 |
Rep 32
My 60' was 2.07.. I unfortunately have the 225 Bridgestones all around
07-05-2021, 05:40 AM | #38 | |
Rep 32
Give a E30 mix or higher octane fuel a try and see if performance increases for you |
08-15-2021, 10:42 AM | #39 |
Rep 771
Just because you're running more boost, it doesn't mean your times should be faster.
There are many other factors to consider.
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White |
08-15-2021, 11:35 AM | #40 | |
Rep 2,700
https://www.mickeythompsontires.com/.../et-street-s-s in 275/40-17 on some cheap rims could do wonders if you want to be able to drive to the track.
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
08-18-2021, 08:23 PM | #41 |
Rep 547
Went to the drag strip over the weekend and my best run was 12.00 @116mph. My best time the prior time was 12.01 so I wanted to try the JB+ I just had in my closet that I had on my prior F30 340i but I forgot and was running late that morning. Hoping to get that hooked up one day and go for another run. I'd be stoked if I can get in the 11s lol.
Car is bone stock '20 M340i xDrive. Stock crappy A/S RFTs. Has MPE but I doubt that makes any difference. 93 octane I can post a picture of the time slip and my dashcam video of it if anyone's interested.
Current: 2020 M340xi Previous: 2016 340xi |
08-18-2021, 08:37 PM | #42 | |
Rep 2,700
08-18-2021, 08:50 PM | #43 | |
Rep 269
It took me a stage 2 91 mhd tune with a stage 1 xhp trans tune to hit 12 on my f30 340 xdrive, so still an amazing time. |
08-20-2021, 05:02 PM | #44 |
Rep 547
Here you go. I decided to upload the video too:
