01-15-2023, 09:50 PM | #23 |
Rep 558
all piggybacks suck and pail in comparison to an actual flash which plays nice nice with your cars computer. Piggybacks are not tunes but rather trick boxes that hoax your car cars DME (computer, CPU, call it what you will) into making more power. So which trick box suck less? JB4 is the way to go.
But keep in mind trick box installed or removed after the fact can be found by the dealer so go with trick box because you can not unlock and have no other option and are desperate for a power bump not because its the best choice |
01-16-2023, 04:48 AM | #24 | |
Rep 113
That is the official statement of femto : [1/3] Unlocking services info: - **** DME needs to be sent to us for the initial unlock **** After that: - Remote Software Update / Over-The-Air updates must be disabled by yourself because any official update will remove our unlock completely. - Flashing is available with use of our own femto obd flasher beta ONLY (Purchased separately. If you want other flashers to work with our unlock - you'll have to ask their developers to add this option) - Only map (calibration/swfk) area is available for OBD writing (*) - We can flash asw (software/swfl) area only while your DME is at our labs upon your request (*) - Another option (petrol only!): MGFlasher / MHD or Bm3 app (purchased separately) - you can flash your car using their phone app after our unlock. Please explicitly indicate if you wish to use this option. Check 'unlocking options' (below) for details. - Prices are: EUR 750/each ECU for the M series cars, EUR 600/each ECU for others - V8 Engines are eqipped with 2xECUs - Shipping cost NOT included |
01-16-2023, 09:11 AM | #25 |
Joint Chiefs of Staff
24198
Rep 190,807
The JB4 is the most popular piggyback.
01-28-2023, 12:52 AM | #26 | |
Rep 1,712
I have the catless dp waiting to be installed. Im sure that will bump up the power even more dramatically. |
B58Medina26.00 |
01-28-2023, 10:33 AM | #27 | |
24198
Rep 190,807
M340i Pride209.00 |
01-28-2023, 03:41 PM | #28 | |
Rep 558
Most of what I have read over the years says that while there may be some added punch for sure with a piggyback the characteristics of the car change. Not necessarily a bad thing just curious. Is it oem smooth? Thank you |
M340i Pride209.00 |
01-28-2023, 03:46 PM | #29 | |
Rep 1,712
And higher map definitely feels more gritty compared to stock. Its a trade off lol. Im sure that’s why people eventually gravitate towards true tune. I am sure i will in few years lol. |
01-28-2023, 04:18 PM | #30 | |
Rep 558
M340i Pride209.00 |
01-28-2023, 06:12 PM | #31 |
Rep 16
JB4 for sure take it from someone who has both. Racechip is a pile of crap and barley works but JB4 adds a good 70hp I know because I dynod it
M340i Pride209.00 330eJL115.50 |
01-30-2023, 09:43 AM | #32 | |
Rep 29
01-30-2023, 10:21 AM | #33 | |
24198
Rep 190,807
Once you press on the gas pedal, it hits a more substantial than stock because of the extra torque its adds. The power delivery is the same as you are adding the same amount of boost through the entire RPM range keeping the same HP curve just higher.
01-30-2023, 12:11 PM | #34 |
Rep 116
Map 3 is a lot of boost for the new b58tu. It’s already running a lot higher boost levels than the gen 1 b58 and the jb4 was designed for that engine. If you install the downpipe you definitely can’t be running map 3 unless you want to overboost way too much. For example on map 3 it will probably make somewhere around 22-23psi which is pushing this tiny turbo way to far without proper fueling from a ecu tune. Just head ups running map 3 way better off on map 4 since 20 psi seems to be the sweet spot on these stock turbos.
01-31-2023, 10:06 AM | #35 | |
24198
Rep 190,807
01-31-2023, 03:42 PM | #36 |
Rep 134
If your racechip was that bad I’d suggest it was faulty or installed incorrectly , I’ve run my Racechip for a year now with great results and gains over stock with numerous dragy runs back to back with chip on and off.
01-31-2023, 03:55 PM | #37 |
Rep 16
It wasn’t bad because I sent it out to Germany and they sent me a new one. It definitely wasn’t installed correctly either the power gains were just very slight.
01-31-2023, 04:41 PM | #38 |
Rep 244
02-02-2023, 06:02 AM | #39 |
Rep 134
I haven’t run many 1/4 miles as I’ve nowhere to do them here in UK but 11.64 is the best I had on the road.
I’ve done the following comparisons Chip off. Chip on 0-100mph. 9.52 secs. 8.83 secs 62-124mph. 10.76 secs. 8.95 secs 30-100mph. 8.12 secs. 6.97 secs 30-80mph. 4.96 secs. 4.35 secs I’m impressed with it |
Jens Mariager3.00 Mark338079.50 |
02-07-2023, 02:06 PM | #40 | |
Rep 17
02-08-2023, 09:57 AM | #41 |
Rep 134
01-22-2024, 01:29 AM | #42 |
Rep 29
Drives: G22 BMW
“ps- if it were me I would piggyback and then wait for a state side unlock - while the flash tunes deliver an experience well beyond what a trick box can - the thought of having to send my DME back overseas when it gets relocked by the dealer would be a real bummer - just my 2-cents.”
It will take years before other companies figure out how to bench unlock the 2021+ G chassis BMWs. FEMTO already said several times they will not repeat the mistake they made with the F chassis bench unlocks. Reason why the F chassis is so easily tunable is because they told a few people how to and those people sold that information and FEMTO lost big money because of it. As of now 5 people know the SecureBMW Code to unlock post June 2021 G chassis DMEs. I’m sure given enough time Kies motorsports will figure it out but it could be well into the H chassis models which isn’t expected to start until 2028. The Price to send your DME out to FEMTO keeps falling, right now your looking at a cost of $1,800 and a 8-14 day turnaround time which is very reasonable, especially for B58 and S58 vehicles. |
01-22-2024, 10:56 AM | #43 | |
24198
Rep 190,807
If you are running E85, then map 7 is fine. If you are running lower quality fuel like 91, map 5 is the most I would use on daily driving.
01-22-2024, 11:41 PM | #44 |
Rep 4
So I've been running Map 5 and a Map 6 (from Terry) with roughly an E30 mixture for the past couple of months and couple thousand miles and the car has been great. Drives like stock when you're not flooring it but when you need the power and put your foot down, the torque is amazing. Using a Dragy, the best time I've gotten is 0-60 in 3.36s and a quarter mile of 11.54 @ 118.02mph. The car is completely stock other than the JB4. No other modifications. Waiting for a stateside DME unlock as well though.
330eJL115.50 |
