BIMMERPOST Universal Forums General BMW News and Cars Discussion Climate Control Issue
      12-13-2023, 03:53 PM   #1
kaibroadbentt
Drives: BMW 118i
2019 BMW 118i  [0.00]
When using my climate control, hot or cold, air con or no air con, there seems to be a sort of whistling sound that becomes louder the higher the fan speed. Was just wondering if anyone can help me try figure out what it is? Would attach a video to try and show the noise but that doesn’t seem possible
      12-13-2023, 03:56 PM   #2
kaibroadbentt
Drives: BMW 118i
The noise comes from the left footwell (passenger side)
      12-13-2023, 04:52 PM   #3
Joralemon st.
Joralemon st.'s Avatar
Drives: 2021 X3 xDrive30i M Sport
I had that happen — they ended up replacing something in the AC system, the compressor, I think. I have the paperwork somewhere, I can see if I can pull it up if you'd like.
      12-13-2023, 04:55 PM   #4
kaibroadbentt
Drives: BMW 118i
I would appreciate it if you could, but if you can’t don’t worry about it. Thank you )
      12-13-2023, 04:59 PM   #5
Joralemon st.
I think I have an idea of where they may be))) Let me check. Mind you I have an X3, but I imagine it may likely be the same thing.
      12-13-2023, 05:12 PM   #6
Joralemon st.
Found it. If what is described here sound like what you're experiencing — this will hopefully help.
      12-16-2023, 05:43 PM   #7
No one
Drives: F21 118i
It's likely the blower: https://www.realoem.com/bmw/enUS/sho...77#64119350395.
I happened to remove mine when trying to replace the cabin air filter myself. Put it back and found out it didn't work anymore. Called a BMW official service. They offered a ridiculously expensive computer diagnostics. When declined ("I'm telling you what happened, I don't need a computer to know that! You only need to reinstall it correctly for me.") they hung it up. So I removed/installed it again myself and it works ever since.
      12-16-2023, 09:54 PM   #8
Joralemon st.
I concur. And what dickheads btw)))
No one1044.50
      12-17-2023, 06:05 PM   #9
beachcomberfl
Drives: 2020 BMW X5
That whistling [I]is[I] annoying! Ive just been dealing with it. Too scared to hear what the dealer is going to charge
      12-18-2023, 10:59 AM   #10
Joralemon st.
Are you past your 50k part of warranty?
