Forum for the entire range of BMW electric vehicles
BMW i4 Forum - i430, i440 (G26) EV Forum BMW i4 Forum - M50, eDrive40, eDrive35 (G26) EV Forum
      02-24-2024, 12:51 AM   #23
freshxdough
BMW Elite Master Tech | HV Gen 5 | HV Specialist
freshxdough's Avatar
3546
Drives: 2024 iX 50 | 2020 X3 M40i
Perform EOS short test.
Also, put something else underneath the battery. You have a 1500lb battery balanced dead center on a single 55 gallon drum????
      02-26-2024, 12:52 PM   #24
ahmedmph
Drives: F15 2015
Please elaborate from where I can perform short EOS test, under which service function, I put two gallon drum under the battery not only one 😉 but it is not shown in the picture
      02-26-2024, 02:04 PM   #25
freshxdough
3546
In the EOS tester. You need to perform an EOS test
      02-26-2024, 08:03 PM   #26
ahmedmph
Drives: F15 2015
I use BMW ISTA along with BMW IMIB HV
      03-06-2024, 03:00 PM   #27
martinux
Drives: BMW F30
Hi,
I also have BMW i4 after crash, installed new SME and other related parts. SME was coded to the vehicle. After coding, I am getting such faults:
- 0x21F415 High-voltage battery unit, cell module 04, component protection, voltage: reuse limit exceeded (safety function)
- 0x21F414 High-voltage battery unit, cell module 03, component protection, voltage: reuse limit exceeded (safety function)
- 0x21F413 High-voltage battery unit, cell module 02, component protection, voltage: reuse limit exceeded (safety function)
- 0x21F412 High-voltage battery unit, cell module 01, component protection, voltage: reuse limit exceeded (safety function)
-0x21F4DA High-voltage battery unit, control unit, service life estimation: Estimation failed due to implausible CAN communication
-0x21F306 High-voltage battery unit, control unit, service life estimation: Estimation failed
Maybe someone had similar faults and knows how to solve it?
Thanks in advance!
      03-10-2024, 03:43 AM   #28
freshxdough
3546
Originally Posted by martinux View Post
Hi,
Thanks in advance!
You have to replace those cell modules and enter new serial numbers.
      04-11-2024, 11:16 AM   #29
Marcelpavel
Mr
Drives: I4
Bmw i4 Crash error
Ive changed pss1 and pss4 and i stilul cant clear crush detected error
bmw
