11-16-2022, 09:11 AM | #23 |
Rep 225
Yes...I currently have a 2019 LCI C43 with AMG performance exhaust. Its really that feature that made me pull the trigger on the C43 over an M340i three years ago. Back then both the C43 and M340i were 6 cylinders....similar horsepower and similar price.
Frankly, I don't get the new C43. It has two less cylinders, less torque, and More price? Who pays more for a 4 cylinder than a 6 cylinder? Maybe if that 4 cylinder through modern engineering were delivering better performance but that does not seem to be the case. I am hearing that this 4 cylinder is slower than both my C43 and the M340I. So less performance, fewer cylinders, much more money? Who is doing the math over at Mercedes because that doesn't add up. Also, if your just wed to the AMG C Class....now it makes much more sense to wait for the AMG C63 s electrified. I didn't care to upgrade to a C 63s back in 2019 because I wanted 4 matic AWD and the V6 in my C43 at 385 was pretty close to the 503 HP in the C63s. At least close enough the price didn't make sense. But now the C63s has 4 matic and the performance gap is Huge!! The C43 has a little over 400HP but the C63s is a whopping 640HP! So if your going to spend huge money on a C43....you might as well go all in on a 63s because the performance gap is no longer "close"...its huge! The new C43 is much closer to C300 performance than the performance of the new C63s. The reverse use to be true. Not any more! Which is why I'm going to a 2023 M340i XDrive . |
11-16-2022, 01:15 PM | #24 | |
Rep 141
I think (just imo) those who pick the new C-Class 43 will be those who (most if not at least some): 1. like the exterior and interior design of this generation 2. don't mind the capacitive touch controls for basic things like heated seats, seat adjustments, and touchscreens which also includes climate controls 3. don't care for exhaust sounds as much 4. don't mind having four-cylinders 5. like the 64 ambient lighting 6. don't mind the weight when tossing around corners 7. prefers rear axle steering 8. cares or not care for engine being handbuilt 9. willing to test the e-turbo charger out which brings almost instant torque and willing to take time off from their day going to the dealership if it does go wrong being new technology at least outside of F1 and into the consumer market. 10. don't mind the higher price tag as you mentioned because it is a new generation while as the G20 had an LCI but not all new Another good point for the C 63 e performance but do keep in mind the C 63 e's ICE itself puts out 469 horsepower. In the case of the 671 horsepower, it is only available for 10 seconds, continuous horsepower is 671-201 (electric motor peak horsepower according to press release) + 94 (horsepower from motor continuously when not at peak). Which by the way on paper, the horsepower number is not low even after the subtraction but when you factor in the weight of the battery and all the electrical systems that creates the C 63s e-performance, the remaining horsepower is needed to simply pull the vehicle. This C 63 e performance has the weight of the outgoing S-Class almost. https://media.mbusa.com/releases/rel...n-of-a-new-era The M340i is an enthusiast's car after all so B58, driving dynamics, etc. will be the first on the list of those shoppers. |
11-16-2022, 10:25 PM | #25 | |
Rep 517
Not sure why you're thinking the C43 will be some porker. Mercedes lists the weight as 3,893 lbs on the MB press site; BMW lists the M340i as 3,951 on bmwusa.com. The C43 can only be had with 4MATIC, so I'd use those numbers to compare. https://media.mbusa.com/releases/rel...ter-efficiency https://www.bmwusa.com/vehicles/3-se...specifications The reality is that the 4-cylinder is a big question in my mind. I know it'll be fast, and I know the C43 will handle great. But how will it sound? All the YouTube videos right now show the EU version with that extra particulate filter or whatever they need to do with EU regulations. I'm gonna wait to see how the US market ones sound. I've heard some really good CLA45's out there stock, so I'm still flabbergasted that MB would allow the C43 to sound as meh as we've seen thus far.
2023 BMW M340i xDrive
2020 BMW 330i xDrive 2018 BMW X3 xDrive30i |
11-16-2022, 11:32 PM | #26 | |
Rep 141
If you are only concerned with sound, you might not need to, here is a video I came across on YouTube, US Spec without the European OPF/PPF, youtube.com/watch?v=DYlZXGc9b8M I am not sure if the speaker in the front of the vehicle and the sound bar in the rear of the vehicle that is said to be in the C 63 e performance is also in the C 43 though. youtu.be/Ae0hSODXhc4?t=211 (timestamp 3:11). So it also depends if you prefer authentic sound (or more accurately sound coming from the exhaust) or artificial sound (coming from speaker or synthetic, although they call it the real performance sound from the exhaust I am only saying it is artificial because it is not coming directly from the exhaust). |
RCtennis3811467.50 |
11-18-2022, 02:50 PM | #27 |
Rep 225
I have a 2019 LCI C43 with AMG Performance exhaust...I just cant figure out what they were thinking with the new C43? Fewer cylinders....more money? Even though its "hand built" I would still take a "factory" built 6 Cylinder B58 over it.
I also don't understand who would now choose a C43 instead of a C63 Se. I shopped both when looking at my 2019 C43 but chose the C43 because it came with 4Matic and the C63 did not. Plus the V6 Biturbo puts out 385 HP. Now its not the V8 503 HP in the old C63 but the 0 to 60s were due different given the 4Matic in the C43 and C43 was plenty fast. But the new C43 is very expensive and now sits closer to a C300. The new C43 has 400HP but new C63se will have a whopping 640 HP. It now has 4Matic as well! So if your going to pay all that money for so so performance out of the C43 you can pay more...but not wildly more...and get the 640 HP 4Matic beast that will be the C63se. 75K for 400HP C43 vs 95K for 640HP C63se? The C63 for sure. |
11-18-2022, 05:39 PM | #28 |
Rep 82
When you're in this type of dilemma what you need it's a Porsche!
jiimmmayyy235.00 |
11-18-2022, 09:37 PM | #29 | |
Rep 141
11-19-2022, 08:29 AM | #30 | |
Rep 283
I really appreciated the read. I have a prelci 330e and Mercedes just gave me a c300e for a day so I could decide my next car. Other than the amazing electric range of the Mercedes I could not find almost anything better on the Mercedes. Everything you wrote may seems little details but I felt most of them, it was like you read my mind after driving the Mercedes for a day. The "safety" systems are insanely bad, also the car feels totally disconnected, steering, front and rear, like it is just a mean of transportation for people who don't care or think about the driving experience at all. Unfortunately the battery hold on the lci 330e doesn't charge the battery, it works like in the Mercedes now, which I find very disappointing as well. |
04-09-2023, 02:31 PM | #32 |
Rep 4,164
not sure about the MB but things i dislike about the M340i
- uncomfortable seats all round - average sound system - can't hear real engine sound, fake engine sound is not good - steering wheel is too thick - very difficult to find wheels that fit - car feels heavy when you push it - a lot of harsh road noise |
04-09-2023, 03:24 PM | #33 | |
Rep 346
04-09-2023, 07:58 PM | #34 | |
Rep 4,164
It's not good. Last edited by G30M; 04-09-2023 at 09:40 PM.. |
04-10-2023, 03:30 PM | #35 |
Rep 263
04-10-2023, 04:26 PM | #36 |
Rep 4,666
Drives: BMW
Personally there’s way too much going against the C Class than there is for it.
I will say this, the W206 is significantly better than the W205. The W205 was mostly all bling and very substandard quality (creaks galore), the W206 solves a lot of it but there’s still plastics and creaks but greatly improved over the W205. The engine is not bad but isn’t great, it just does its job although very noisy even for a 4 cylinder (the B48 doesn’t really have this issue). Ride quality is what you expect for the C Class, more compliant than a 3/4er (not by a huge margin) but not as soft as an E Class. Price is ridiculous regardless of trim especially here in Canada. Lightly spec’d car will still be around $1,200-1,300. Go heavy on options you’re looking at a $90K C 300 for around $1,500/month. The 3er isn’t perfect but you factor in engine, overall quality, price, it does it’s job better as being a 3 Series than a C 300 does as being a C Class. |
04-10-2023, 04:31 PM | #37 |
Rep 459
Thanks for the post on this. I am in the same predicament with my 330i lease ending in 8 mos. and am tempted by the C43 for the modern interior and technology. So far I have only driven the C300 w/ AMG Line and I ruled that out quickly. The suspension is too floaty and the brake pedal too mushy; odd since the AMG Line includes a sport suspension, steering, and brakes. It drove like a 530i.
If the C43 is more "taut" then I might be swayed. But then I am reminded of why I picked a 330i over the M340i. The lighter car is more fun to toss around and I am not keen on driving a car that weighs another 500 lbs. I see posts above referencing 3,893 lbs in Mercedes press materials, but the MBUSA site lists 4,092 lbs.
_______________________________
current: G20 330i retired: G30 540i, F10 528i, F30 328i |
04-11-2023, 12:39 PM | #38 |
Rep 152
I am a little biased, as my last 7 cars have been BMWs. But from time to time I test drive MBs just to check. My conclusion is always that, even in their sportiest trim, MBs feel like an older person car. More luxury and gadgets, but inferior handling and lack of fun-to-drive feel.
2023 330i Xdrive, phytonic blue/ tacora
04-11-2023, 02:20 PM | #39 |
Rep 1,201
I built out a C43 and a mostly but not fully loaded spec comes out to $5k more than my equivalent M340i build.
Also, I don't get what people are complaining about the tech in the M340i. There's loads of high tech features! You have lane change assist, a really nice high res HUD, carplay/android auto in IC, automated parking, backup assist, headlights are actually quite good, digital key, 3D remote view. Im sure the new C class may have a few new features, but it's 4 cylinder, heavier, slower, and quite a bit more expensive. |
04-11-2023, 05:29 PM | #40 |
Rep 346
If its any indication, I sat in a new C300 this week. My findings below:
- Some of the interior materials felt a bit cheap - You can really tell its a 4-cylinder, but makes good power - Tech was nice, but not a fan of the touch buttons on the steering, driver mentioned he accidentally hits them - AMG line is a must, it looks very dull and boring without it |
04-12-2023, 10:29 PM | #41 |
Rep 517
If these are actually the official EPA fuel economy numbers for the new C43, what’s the point? Slower than an M340i, sounds worse, and drinks more gas? 0 for 3, MB.
04-13-2023, 06:53 AM | #42 | |
Rep 459
I feel like every performance-oriented hybrid turns out the same. The weight required for the hybrid components offsets fuel efficiency gains, leaving a heavier and more complicated compromise. At least those with some electric range net a high eMPG.
04-13-2023, 07:00 AM | #43 |
Rep 225
I have a 2019 C43 and will not be getting the new C43. Its M440i XDrive Grand Coupe all the way.
The engine and transmission of the new C43 just do not compare to the B58 and ZF 8 eight speed transmission. |
04-13-2023, 07:00 AM | #44 |
Monkeyman8
132
Rep 165
There is nothing "true AMG" about the c43, even if AMG make the engine the performance and overall numbers are disappointing. More marketing than anything else. Overweight (S class weight), underpowered and more expensive than than a 340. There was a time that AMG would never produce anything remotely close to this but the world has changed. Not to mention fake quad exhausts, seriously that alone will turn me off.
To me the 340 is a clear winner. Unless someone prefers the flashier interior and tech. Then so be it. |
