09-05-2024, 09:46 PM | #1 |
Rep 34
Clear-coat failure on 2020 M340i
I recently purchased a 2020 M340i. It's still under a CPO warranty which is being transferred to myself from the previous owner.
There are cosmetic imperfections along the edges where the rear bumper piece meets the rear quarter panels on both sides. They appear to be slowly progressing, and the rear left side appears to have clear-coat beginning to peel off on the corner of the rear bumper as seen in the picture. I know the car was paint-corrected and ceramic coated by the previous owner some time in 2023. I'm not sure if that's really relevant or not. Is there anything I can do to prevent this from spreading and fix it? Are clear coat issues covered under BMW's warranty? Last edited by LopsidedLand; 09-05-2024 at 09:55 PM.. |
09-06-2024, 12:17 AM | #2 |
Rep 460
That does look like it could be clear coat failure at first glance, but I'm hard pressed to imagine that it would happen so soon through normal wear and tear. Paint correction ahead of ceramic coating usually indexes a lot heavier on polishing than cutting, so I am skeptical that any paint correction caused this. Is the car fax clean? It looks like a the rear bumper was replaced and they didn't let the paint settle properly before doing the install, which can most definitely cause this. Also, if they didn't prep the surface of the bumper before replacing it and they just sprayed on more paint or clearcoat, it could cause this as well.
09-06-2024, 10:29 AM | #4 |
General
17773
Rep 24,812
No matter the cause, it would not be covered by the CPO warranty.
09-06-2024, 12:45 PM | #5 |
Rep 5,262
This looks like a subpar bumper paint job, or damage from paint correction, instead of failing clear coat from the factory.
If the damage keeps progressing then the bumper may need to be repainted. |
09-06-2024, 03:23 PM | #6 | |
Rep 34
It was leased the by the original owner for 3 years, then sold to the 2nd owner. The 2nd owner said the paint had a lot of swirl marks so he got it corrected and ceramic coated. That's the only body /paint work he told me about. |
09-06-2024, 03:26 PM | #7 |
Rep 34
Is there anything I can do to stop it from progressing or fix the small amount that is there?
09-06-2024, 03:29 PM | #8 |
Rep 34
09-06-2024, 03:30 PM | #9 |
Rep 42
Drives: 2020 BMW M340i X-Drive Exc Pkg
Looks like it was repainted without removing bumper from car. Have seen this many times before. All you can do is get it painted by a reputable body shop.
09-06-2024, 11:06 PM | #10 |
Rep 334
Drives: 2021 bmw m340i xdrive
Many moons ago when I use to work at a used Honda dealership department. We had a touch up guy that came in once a week to recondition the used cars that had bumper scratches and hood chips.
He would literally recondition the bumpers and re spray them fully or blended. ( didn’t remove the bumper cover he just taped what he needed to protect. And he did this right out side. This is probably what happen. Since there is no accident report on file. I’m sure it wouldn’t cost a lot to have the bumper cover wet sanded, and re-cleared |
09-06-2024, 11:12 PM | #11 |
Rep 5,262
Tags |
auto body, body repair, body work, ceramic, clear-coat, cpo, m340i, paint, peeling, warranty |
