01-16-2023, 08:01 AM | #45 | |
Rep 7,484
https://www.cambridgeaudio.com/usa/e...w-run-speakers So breaking in is not a joke. Also discussed here: https://x3.xbimmers.com/forums/showthread.php?t=721725 What are you not feeling about HK? Bass? |
01-16-2023, 08:24 AM | #46 |
Rep 109
“Takes time to break in.” Is that a joke or serious? Didn’t know solid state electronics take time to break in and I’m an engineer (but mechanical not electrical).
I love my new 330, but mostly dislike everything about the HK system, except the logos on the screens. Anyway, Thanks I’ll try this as Ive been playing with the settings posted on this site for a few weeks with no real improvement. Listen mostly to classic rock and R and B. Have a great day. |
01-16-2023, 09:58 AM | #47 | |
Rep 1,780
01-16-2023, 11:29 AM | #48 |
B58 Power
492
Rep 628
I also used the F30 settings in my G21 but like to try the settings from elambo.
01-16-2023, 02:16 PM | #49 | |
Rep 7,484
https://www.cambridgeaudio.com/usa/e...w-run-speakers So breaking in is not a joke. What are you not feeling about HK? Bass? |
LousyShot49.00 |
01-16-2023, 02:37 PM | #51 |
Rep 109
(1) I never heard of speakers taking time to break in. Always thought electronic / fiber optic is what it is with essentially no moving parts. Anyway, I guess you learn something new every day. Next time my wife wants to replace a TV or Toaster or most anything else electric, I'll tell her wait, it needs time to break in.
(2) With HK that came with the 3 series I bought, I'm just not feeling any bass, any range, it sounds weak, almost like a portable handheld radio, but somewhat better. (3). I know most car stereos are made by the same company, Samsung or LG or whatever, but having experienced the Mcintosh in Jeep and Bang and Olufson in Audi, and so many others over the years, it is hard to adjust to such a decrease in sound quality with the HK. Had I never heard other high end systems, the HK would probably sound a bit better to my ears. I've been playing with the HK settings almost every day for the last 2 weeks, and not much has changed. When I have the extra money, the HK is getting replaced with something much higher end. To me, high end car audio is so important, it makes driving so much more enjoyable! |
01-16-2023, 03:13 PM | #52 | |
Rep 7,484
https://g20.bimmerpost.com/forums/sh....php?t=1724795 I replaced my under seat woofers with SWS. I’m happy with the bass. |
01-16-2023, 04:05 PM | #53 |
Rep 109
I have the 2023 3 series with HK. There definitely is some bass, just so weak. The amp is fine, I already had service check it, they said a year or two ago some HK amp units needed to be replaced, but mine was fine. The service writer recommended a local car audio installer that they refer, but said a high end upgrade will cost about 4,000, and I don't have that to spend.
He said a lot of M3 owners have replaced the HK components with a French brand called "Focal" and have been very happy and that the same parts will work in any G20. I think the issue, plain and simple, is that I am a bit spoiled by having heard other systems and how good car audio can truly be. I just took a ride in my neighbor's new Volvo a half an hour ago, he opted for the Bowers & Wilkens upgrade (over the base HK). Wow, the Bowers & Wilkens is also an amazing system - maybe even better than Bang Olufson or McIntosh, and far superior to the HK I have in the 3 series. However, I am still very happy with my 2023 3 series purchase! |
Soul_Glo13347.00 |
01-17-2023, 09:48 AM | #54 |
Rep 288
A decent upgrade from the Harmon Kardon can probably be done for less than 4K.
Enter your VIN at the Alpha One Bimmer Tech website and it shows if any speaker / amp upgrades etc available. https://www.bimmer-tech.net/speakers...lifier-for-bmw |
01-17-2023, 12:14 PM | #55 |
Rep 109
Thank you for that. I plugged in my VIN at the site. It gives me the speaker upgrade, but says no compatible Amp upgrade available. I hope that does not mean I'm stuck with the Harmon; if that were the case I would have found a car without the Harmon in the first place.
01-17-2023, 04:18 PM | #57 |
Rep 1,719
Drives: 2014 650xi Gran Coupe Msport
Everyone unhappy with HK should start by coding on the B&O option, then tweaking the sound from there. Much improved over HK. Still not amazing, but a nice improvement.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
01-17-2023, 06:29 PM | #58 | |
Rep 167
Drives: M340i xDrive Tanzanite II
Anyways that aside. Bowers & Wilkins sound profiles definitely sound different and will have more profiles to expand the sound stage. However NONE of them except STUDIO is completely accurate due to the software coding and actual amp to channels to physical speakers configuration. If you use onstage it will use all 16 Channel in which the Harman Amp has only 10 in which only 9 are used (BMW Logic). When you change the Sound Stage from Studio to --> Onstage in the Bowers & Wilkins profile it's CLEARLY Underpowered and missing channels it will give you a surround effect at the cost of the music being heavily underwhelming in volume and it will have missing Frequencies due to the extra channels and physical speakers required. So unless you're purely listening in STUDIO in Bowers & Wilkins it's not worth it. Tweaking the EQ from the forums provided feedback / screenshot is the best way to listen with Logic 7 (Surround). Other Options : Cheap Solution : Swap out the subwoofers fixes your Bass needs. $800 or $600 D.I.Y. : 2x Focal or Bavsound Subwoofers + Shop Install Full Speaker solution 2-2.5k : For All 16 speakers replacement from Bavsound or Focal Speakers + Plus Shop Install Labor (a lot of door cards and speakers). Full Solution = 4-4.5k : Requires Full Speaker Replacements + Match 10 DSP + AMP signal (Will be better then 80% of named Branded Systems out there excluding those Signature Reference Audio with ceiling / backrest speakers IE BMW B&W 4D Diamond, Meridian Reference Signature, Naim, ... etc)
2020 M340i xDrive : Fully Optioned ; ZTK Pkg, Exec Pkg, DAP Pkg, HK, etc with 4 Screws Painted due to F.L.P. & the land of the $2 Gas tax.
Soul_Glo13347.00 |
01-17-2023, 07:14 PM | #59 | |
Rep 1,719
01-18-2023, 09:16 AM | #60 | |
Rep 109
01-18-2023, 11:43 AM | #61 |
B58 Power
492
Rep 628
Has anyone already looked at the RAM module from the LCI?
It´s a little bit better compared to the PreLCI and maybe it´s an easy retrofit!
01-18-2023, 12:35 PM | #62 |
Rep 7,484
01-18-2023, 01:44 PM | #64 |
Rep 140
In my opinion, reducing 1k all the way helps a lot to let bass and treble to have clear development for the rock, blues, jazz and pop music. Classic may need the 1k flat it to be better heard, IMO.
Try to diminish 1k and try to adjust the rest toward your liking. In almost every sound system I have had it works and HK isn't the exception. Also, if Spotify is used, it allows you to equalize the output... If you mix both systems you might be surprised by the results. Regards, JI |
01-18-2023, 02:14 PM | #65 |
Rep 404
All this does is unlock some parameter presets, but we've discovered settings which equal or surpass those so it's unnecessary to inject Bimmercode into the equation if it's not desired.
01-18-2023, 02:20 PM | #66 | |
Rep 404
I've experienced it in high end home systems. Speakers, in particular, will lose the edge in their high end over the course of a couple days. Sometimes more. I've experienced it with amps, too, but I'd rather not open Pandora's Box and start the argument. These components may technically exhibit different properties over the course of a few days of playing but I'd be surprised if it's much. It's certainly not going to promote it from good to great. |
Soul_Glo13347.00 ultrared93103.00 |
