05-30-2019, 03:22 PM | #1 |
Rep 124
Drives: 2020 M340i TB II
Aftermarket Sub-woofer on G20
I am new to BMW. I'm in the process of searching the right option combination on the M340i. Looks like I will be narrowing it down in the next couple of days.
My question, Has anyone installed a subwoofer into the new G20? - If so, what was the set up? I am looking for a powered Rockford Fosgate P300. |
05-31-2019, 03:12 AM | #2 |
Rep 186
Hi,
Like always with BMW it depends on the level of OEM audio you opt for. If you go with H/K there will likely be MOST integration to the amp and you will have to use a MOST integration (e.g. moBridge or similar) or a DSP which can cope with the high voltage output from the factory H/K amp. If you go with regular Hi-Fi with factory amp there is balanced differential low-level from the HU to the amp, or the same high voltage output after the amp. So basically same options as earlier generations.
05-31-2019, 09:02 AM | #3 | |
Rep 2,180
VetteGuy845.50 |
05-31-2019, 10:17 AM | #4 |
Rep 124
So, with the HK system it is safe to say if I go with a self powered woofer like rockford fosgate p300-10 punch. It would work fine with the existing system? I know that this particular model does not require a remote wire from the HU.
05-31-2019, 07:13 PM | #5 |
Rep 2,180
The HK booster should output at least 100W per woofer... that's between 20-26V peak. That p300-10 accepts 3V max -you need a LOC.
08-30-2019, 06:13 PM | #6 | |
BMW4LIFE
30
Rep 35
09-17-2019, 03:42 PM | #7 |
Rep 124
Eagle Creek139.00 |
11-08-2019, 07:55 PM | #8 |
Rep 114
Going to be putting a sub in my m340. Have a quote for a custom mounted sub that would sit in the trunk floor with a custom box and metal cover. Would be 2 10in jbl and a 1000 watt amp.
He said 2400 which felt like a lot. I have an existing sub and amp which I was thinking of just bringing over to save money. Do you think best buy would be capable of connecting my existing system to the m340 without much trouble? |
12-02-2019, 01:08 PM | #9 | |
Rep 1,168
2020 M340xi PB (sold)
12-02-2019, 04:13 PM | #10 | |
Rep 114
I have the hk system. It's very nice sounding with good stage, bass has some punch but not 500+ watts of external sub which I'm used to. I'm getting ppf and tinting done now so maybe in a few weeks I'll consider it. |
08-27-2020, 10:56 PM | #12 | |
Rep 84
audison.eu Or those Alpha One from bimmertech https://www.bimmer-tech.net/speakers...ifier-for-bmw/ |
08-27-2020, 11:53 PM | #13 |
Rep 219
It's easy to add an amp to the car. I dropped in a 12" solo baric and JL rd1000 Amp and I have the hifi system. Shop charged $150 for install.
'20 Portimao Blue M340i – Current '17 Dark Graphite 530i – Retired '14 Alpine White 328i – Retired |
09-01-2020, 12:18 PM | #14 | ||
Rep 124
09-03-2020, 04:22 AM | #15 |
Rep 1
after some time i realize My BMW speaker sound not fine so i decide buy special Studio monitors for my BMW .. Now i installed in it & very good Sound quality i buy from this reasonable price.https://bringmag.com/best-studio-monitors-under-500/
11-30-2020, 07:35 PM | #16 |
Rep 61
Did you have to run a loc to this?
Jb
possible335i2008165.50 |
11-30-2020, 07:38 PM | #17 | |
Rep 61
Jb
12-02-2020, 04:48 PM | #19 |
Rep 61
Yes. Mine does. I coded it off with BimmerCode app but it's still there. Just not as bad. Very annoying.
Jb
01-05-2021, 11:49 AM | #20 | |
Rep 219
02-02-2021, 01:01 PM | #21 | |
Rep 35
Just got my 2020 330i with HiFi audio and not impressed with audio. For starters want to install my existing 12" Kicker sub and Pioneer GM-D8601 amp. Appears pretty easy since I have a AudioControl LC2i 2 Channel Line Out Converter. Just planned to tie LOC into rear speakers and power amp from battery in trunk. Trying to make sure no hidden surprises I am not thinking of, as I had unexpected surprises with same setup in my previous Cadillac and had to make mods to its onboard DSP. Thanks in advance |
