Technical Topics Cosmetic and Lighting Modifications (exterior & interior) Painted my 330i Exhaust Tips
      06-04-2020, 05:12 PM   #45
Deepdish1983
Drives: G20 330i M Sport
Looks good!
      06-04-2020, 08:05 PM   #46
VipinLJ
VipinLJ's Avatar
Originally Posted by zachart View Post
Mine are still looking good. I'll keep updated if they start to chip.
Plus I believe you used engine enamel paint? I used the stuff that they use to paint the insides of a grill. I assumed it would withstand heat better but I guess either I was wrong on thinking that or I made a mistake by applying too many layers?
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      06-05-2020, 04:26 PM   #47
murderedg20
murderedg20's Avatar
Drives: 2019 330i M Sport
@VipinLJ Yeah this is what I used
VipinLJ1941.50
      06-06-2020, 12:22 AM   #48
VipinLJ
VipinLJ's Avatar
I did see that and regret not getting it. I’ll use that the next time I remove my tips to repaint it. Right now, you’ll notice the crack only if you look for it. To an untrained eye, it isn’t that obvious. So I’ll wait for it to chip a bit more before I repaint it.
      06-09-2020, 11:04 PM   #49
OM3RTA
391
Yup. I thought my exhaust was about to come off when I tried removing the driver‘s (passenger for you) side tip but people use hammers and screwdrivers and stuff to pop it off. So yes. Some force is necessary.
You were right. Took a serious bit of force, weirdly I was the same on the drivers side(passenger for you) in that it was way more difficult even with using a little WD40 & it took me a good 10- 15mns & really sore fingers to remove.
Seems as if my MP cf tips will not fit properly but I did rush to get them on as the weather rapidly began to change for the worse.
VipinLJ1941.50
      06-09-2020, 11:14 PM   #50
VipinLJ
VipinLJ's Avatar
If the tips are off, maybe measure the two and see if the part where the tip slides in are the same diameters? Wonder why BMW made different sized tips for the same car.
Reinstalling the tips are extremely easy. No force needed. It easily slides in and locks into place. Takes all of 5 seconds (or less actually) per side to reinstall.
OM3RTA391.00
      06-12-2020, 09:12 AM   #51
OM3RTA
391
I should have done that before I put the new ones on.
However it seems as if they may not be too different in size as they do fit...just not properly but after having dug the 1st below attachment:
Name:  Screenshot_20200609-172650_Write on PDF.jpg
That seems to suggest that seems to suggest that the tips have to go right up to the 'pins' which you may have felt or seen when removing yours. Now as I say I haven't done so as yet as in the earlier fitment instructions prior to the one I have shown it suggests that a bit of cutting to the exhaust pipe was needed, now granted the instructions are for the MPE and not the MSE that I have made me think I might not have to do anything other than push them on but now thinking about it the gap I have from the end of the tip to the 'pin' is near the exact same as the M logo on the tip to the placement of the tip in relation to the apron(see below) as said in the above attachment.
Leaving it as is leaves it sticking out a bit far and I'm not sure if it does increase the risk of burning so much that I should just remove them again until I can cut the parts I need to off.
VipinLJ1941.50
      06-12-2020, 03:29 PM   #52
VipinLJ
VipinLJ's Avatar
Attachment 2336721
Attachment 2336735
Attachment 2336738
You mean you didn't try pushing it past the pins because of the screw thingys on the m performance tip?
      06-12-2020, 10:18 PM   #53
OM3RTA
391
No, you physically can't push it that far as the existing exhaust is too long, unless it's possible to open the clamps on the cf tips further which I never tried & I highly doubt can be done.
VipinLJ1941.50
      09-01-2020, 10:07 AM   #54
murderedg20
Update: exhaust tips still look good like they did when I painted them 4 or 5 months ago. No signs of chipping yet.
      10-17-2020, 09:52 PM   #55
Merami fan
めらみぽっぷ fan
Merami fan's Avatar
Drives: 2020 330i xDrive
I found that a 1/4 x 2 inch toggle bolt works perfectly for this. Take the butterfly/anchor part off, pinch it together, and wedge it between the V clips (small side up). Makes this a 2 or 3 minute job.
Username and profile picture in admiration of the goddess of treble, めらみぽっぷ (Meramipop).
https://www.youtube.com/watch?v=fQYWhQXOeQg
https://open.spotify.com/playlist/1w...1L3y6cmPEyGSoI
VipinLJ1941.50
      05-11-2023, 03:58 PM   #56
murderedg20
Just wanted to provide a quick update as I’ve had these painted for over 3 years now. Definitely faded a bit but still looks good. Wouldn’t pay for the factory ones.
