10-31-2021, 12:17 PM | #903 |
General
10445
Rep 40,774
Drives: 2018 Alpina B6 650ix GC
It's Chinese though. Is the English translation / interface good?
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
10-31-2021, 09:47 PM | #904 |
Rep 1,777
What's much better about it? I got the same Launcher Pro from davyg and it works great. As long as it gets the job done really shouldn't matter - unless there's something about the Chinese version you are referring to that is exceptional.
11-01-2021, 05:06 PM | #906 |
General
10445
Rep 40,774
PM sent.
11-01-2021, 11:27 PM | #908 |
Rep 263
Ncd comparison tool inside , reboot ecu inside with 1 click ,read DTC s and much more that even EsysX copied their features
11-02-2021, 02:39 PM | #909 | |
Rep 46
Drives: 2020 G20 330i
Once I plugged in and read the ECU , it did indeed show the CAFD values were back to original, not sure why the 1st time I read it they showed the changed values. Either way, took me about 30 minutes of changing the coding and using the cheat codes where available, and managed to code both the anti-dazzle and tesla mode back in does anyone happen to remember where to go to set the 'mode' on start up? similar setting to ASS where I want it in sport individual on start up each time, not comfort |
11-02-2021, 08:35 PM | #910 | |
Not new just quite
31
Rep 123
Drives: E60, F30, G22 & G80
Try...
Code:
Change startup mode to Adaptive 00007083 BDC_BODY3 3221 FesPiaDefaultLastUserMode 11111111b >0A< Change startup mode to Sport 00007083 BDC_BODY3 3221 FesPiaDefaultLastUserMode 11111111b >01< Change startup mode to Sport Individual 00007083 BDC_BODY3 3221 FesPiaDefaultLastUserMode 11111111b >03< Change startup mode to Comfort (default) 00007083 BDC_BODY3 3221 FesPiaDefaultLastUserMode 11111111b >04< Change startup mode to Eco Pro 00007083 BDC_BODY3 3221 FesPiaDefaultLastUserMode 11111111b >07< Change startup mode to Eco Pro Individual 00007083 BDC_BODY3 3221 FesPiaDefaultLastUserMode 11111111b >09< Quote:
2024 BMW M3Cx G80 | Alpine White + Fiona Red | 2021 BMW M440i G22 |
11-03-2021, 03:07 AM | #911 |
Rep 51
hi Shawn
Sorry to bother you but am confused. I downloaded latest files and the full files are in RAR and about 37 individual files. I cannot see where in esys x that i put these files as they look nothing like what is stored in the pszd file there. Is the RAR download correct or is the file to be downloaded in a different manner and then replace the pszd file there? Thankyou |
11-03-2021, 06:50 AM | #912 | |
General
10445
Rep 40,774
11-04-2021, 11:05 AM | #913 |
Not new just quite
31
Rep 123
Is it possible to enable Assisted Driver View and/or Automatic Lane Change Assistant on a car w/o Active Driver Assistant Pro option?
Tkx!
11-04-2021, 04:34 PM | #915 | |
Rep 46
I found the correct entries, but the only options that show up when editing the CAFD file are EcoPro, Comfort, and 2 Hybrid options I believe last time I did this I had to find the part that details what options show up in that menu, but i wasn't able to do it this time Any idea where that is? Otherwise I'm not able to select sportindividual in that menu Thanks! -- Specifically these are the choices, but I only see 2 listed here, and 2 not listed Not sure how to pick 03 (Sport Individual) without it appearing in the list under DefaultLastUserMode ECU: BDC_BODY3/00007083 FDL: FesPiaDefaultLastUserMode to value 02 for Sport Pro/Plus mode Complete set of FesPiaDefaultLastUserMode codes are listed here. The mode needs to be enabled on the car for these to work: 01 - Sport 02 - Sport Pro/Plus 03 - Sport Individual 04 - Comfort 05 - Comfort Plus 06 - Comfort Individual 07 - Eco 08 - Eco Plus 09 - Eco Individual 0A - Adaptive Last edited by BlueOnBlue; 11-04-2021 at 04:42 PM.. |
11-04-2021, 04:39 PM | #916 | |
Not new just quite
31
Rep 123
Strange mine listed all, I adjusted to Sport Individual yesterday after on Adaptive for a few days from the deafult Comfort... but your SI option shows up in iDrive?
PS: ... wait maybe edit the Werte value instead of the drop down selection? Quote:
11-04-2021, 05:07 PM | #917 | |
Rep 46
i input 03, but when i clicked away it wouldn't save it, I must be missing something obvious there! |
11-04-2021, 05:40 PM | #918 |
Not new just quite
31
Rep 123
At the bottom box where you input "03" there's little save icon on the far right side on the bar of that box.
11-04-2021, 07:34 PM | #919 | |
Rep 46
that's great i managed to code everything I wanted to from last time until the next software update! lol |
11-05-2021, 03:43 PM | #920 |
Rep 6
Esys Launcher Pro
Hello,
How I can contact with dayvg? I want to buy from him latest Launcher Pro https://www.bimmerfest.com/members/dayvg.437094/ Thank you very much! |
11-05-2021, 03:47 PM | #921 | |
General
10445
Rep 40,774
11-07-2021, 12:07 PM | #922 |
Rep 31
I don't get any errors, but the settings just don't transfer to the car. After I edit the setting, save, and press Code, everything goes fine, no alerts. But if I read data and look at it again, the settings are back to default.
I'm using E-Sys 3.27.1 and v.4.31.41_PSdZData with TokenMaster's Laundher Pro 3.7.0.315 Anything you can think of I can try? |
11-07-2021, 12:10 PM | #923 | |
General
10445
Rep 40,774
