01-29-2020, 05:19 PM | #199 |
Rep 3,961
BMW definitely has multiple problems on their hands. Some tints affect it, other tints don't. Some without tinted even have the problem, and many don't.
I'm wondering if everyone who says they don't have the issue AT ALL are just less sensitive to their tolerance of dimming (kind of like auto dimming on a cell phone). Others will never notice much of a difference if they are in a very sunny, shade free location. |
Rossgazz8.50 golferboy231278.50 |
01-29-2020, 05:29 PM | #200 | |
Rep 30
You could be correct. I've played around with it like others have described in previous posts by shining a small light in the area of the IR sensor and it immediately brights up to what I would consider normal. Pretty aggravating though, much like my Connected app that stopped working for over a month, but I digress.... |
01-29-2020, 05:40 PM | #201 | |
Rep 3,961
[QUOTE=Rossgazz;25744853]
Rossgazz8.50 |
01-29-2020, 08:42 PM | #202 | |
Rep 84
[QUOTE=Burrcold;25744888]
01-29-2020, 08:46 PM | #203 |
Rep 3,961
01-29-2020, 08:50 PM | #204 |
Rep 230
Yes to both of these things. To my knowledge, all BMWs with digital instrument clusters have this issue. It's not model specific, and it can be very evident even with no tint on the windows. No one's bimmer is immune to this, so anyone who says "I have no issues" falls into one or both of the categories you've spelled out above.
01-29-2020, 09:08 PM | #205 | |
Rep 3,961
I don't have much faith that BMW will change anything anytime soon. Like you said this isn't model specific. |
01-29-2020, 09:36 PM | #206 |
Rep 230
Me either, especially since it's not a new issue. I've seen some older posts in other forums that suggest this issue has been around for as long as the digital cluster displays have. If they haven't addressed it already, that suggests they know and don't care.
01-31-2020, 12:54 AM | #207 |
Rep 18
I got Xpel Prime XR black(85% IR heat rejection/ 64% TSER) 20% all around Minus the Front Windshield. I am noticing that the Dash is now dimming to varying degrees depending on how much ambient sunlight is coming through. If the sun is at an angle where it can hit the dash I get a nice bright vibrant display. Other times, i have a dim muggy washed out live cockpit and its really disappointing that BMW doesn't have an option to disable the dreaded auto-dimming.
I'm in So Cal btw so its hot and sunny here like 95% of the time. |
01-31-2020, 06:32 AM | #208 | |
Rep 3,961
alpinewhite3556.00 |
02-26-2020, 07:43 PM | #209 | ||
Rep 25
I've always had 5% all around on all my cars here in Vegas, never got a ticket(for tint). Seems like police don't pay much attention since it does get very hot and sunny out here. |
02-29-2020, 12:42 PM | #210 |
Rep 265
I don't seem to have this issue -- tint installed by dealer prior delivery. Unsure of tint brand but I assume the dealer wouldn't use it if it created conflicts with car electronics.
I did a couple of tests to see if I could reproduce, with direct sunlight hitting the sensor (rolling window up and down) and couldn't get the brightness to change. |
02-29-2020, 02:25 PM | #211 | |
Rep 3,961
I've done a ton more testing since my last post, and there is 100% a very large impact by the use of either nano-carbon and ceramic films (good quality ones anyway) vs dyed films. Dyed films reduce the dimming effect greatly...the VLT (or how dark the film is) plays into it as well but not as much. My testing has been with 4 different brands of tint, and 4 different VLT percentages. |
03-01-2020, 07:27 AM | #212 |
Rep 265
I'm not sure, I believe 35%. If cheap dyed tint, I'd be surprised, they outsource the tinting to a shop that uses primarily HuperOptik ceramic, so that's probably what it is.
03-01-2020, 08:03 AM | #213 | |
Rep 230
Additionally my coworker just got a brand new X5, and his dealer offered him 35% ceramic tint, which in theory is the worst offender since it blocks the most IR. He asked them if they were aware that it can cause screen dimming issues and they were clueless about it as well. Based on my advice he declined, and it's a good thing he did. His screens are already prone to being unacceptably dim in the middle of a GA winter afternoon, even without any tint applied to his front windows. I shot a video of my undimming unit applied to his dash. Check out how washed out his instrument cluster is at the beginning and the end (brightness takes about 10 seconds to ramp all the way back down)... |
03-01-2020, 08:55 AM | #214 | |
Rep 3,961
Also 30% Huper Optik is one of the films we tested and it made the dimming issues even worse compared to the following (25% Suntek CXP, 30% Autobahn Black dyed, 20% Autobahn Black dyed, 20% Formula One Pinnacle Ceramic, and Formula One Classic Color Stable dyed). Ceramic and hybrid carbon films are the worst offenders (especially the darker you go). Regular dyed films produce the least amount of dimming (but still dim slightly) and aren't as sensitive to how dark you go but they still are affected by darkness level or VLT. The biggest difference between the dyed films and ceramic films seems to be related to the IR reduction. VLT being equal for both, the ceramic causes the most up and down dimming (example going from 2 to 10 back down to 2 then to 5 - assume brightness levels are a 1 to 10 scale). This is especially evident when it's a sunny day and you drive under tree covered areas or when the sun is coming in and out of the clouds. Also as you change direction...it's up and down and up and down. The dyed films are much more stable with the ups and downs in the dimming. They still dim (say it's overcast, you may see them dim to a 5 or 6). On sunny days they may be at an 8 or 9, and will usually stay at this level even when going into tree covered areas, being surrounded by tall buildings, sun in and out of clouds, etc. My last picture I posted in this thread was with a dyed Autobahn Black 30% (these are made by Huper Optiks). I've gone through 4 different tints since then, and now have 20% dyed Formula One Classic. This film has been the most stable and produced the least up and down dimming issues to date. Luckily my tint shop has been awesome and have been using my car as a test mule to try and figure the issue out (they do work for the local BMW dealership as well so they want to be prepared to add a disclaimer if anyone comes in with a G20 and asks for ceramic films). |
VipinLJ1941.50 |
03-01-2020, 09:47 AM | #215 |
Rep 1,067
Just chiming in - i have found this so frustrating lately...Seems like the effect is amplified 10x in winter. I find my display to be almost pitch black on my bright sunny morning commute.
I do have dealer installed tints but not sure if that is the culprit. The digital dash is essentially useless if i can't see anything. The location of that the sensor does not seem like it was well thought out.
2019 G20 330i RWD
2014 F30 328i RWD 2009 E90 328i RWD 2006 E90 330i RWD 2002 E46 330i RWD |
03-01-2020, 10:19 AM | #216 | |
Rep 3,961
Some of the testing I did with the tint shop was leaving it outside and checking on the level of dimming at various stages in the day, and moving my car to face different directions. We also checked the scenarios on sunny days, cloudy/sunny days, and full cloud covered days. This was all over a few days of testing so not just a five minute quick test. The most impact to dimming was on sunny days early morning or afternoon when the sun was lower (totally shitty because that's most of the time we all spend in the car...commuting). |
VipinLJ1941.50 alpinewhite3556.00 |
03-01-2020, 10:49 AM | #217 |
Rep 3,961
I took these two pictures on Friday and Saturday this weekend after getting my tint redone again on Friday morning. Both of these scenarios would have had my screens so dim (first with the sun low with the majority the light passing through the tinted windows and the other picture is a sunny but partly cloudy day where the sun wasn't really out or directly above). The result after the new tint? Both gauges were an 8 or 9 out of 10 brightness. I'll take that!
premier3is1631.50 |
03-01-2020, 12:12 PM | #219 | |
Rep 3,961
I've shown a few people that didn't think they had an issue with dimmi until I shined a light on the display and they saw how much brighter it actually got. |
03-01-2020, 12:15 PM | #220 | ||
Rep 44
