10-08-2022, 10:37 PM | #67 |
Rep 565
Drives: G20 M340i
Finally got to replicate the noise with the foreman in the car. Back to the shop it goes. I added the suggestion about the strut mount (thanks panki_86). So we will see now.
panki_86112.00 |
10-09-2022, 06:06 PM | #68 |
Rep 125
Drives: 2020 m340i RWD
Wow! Lucky break. With the temperatures down mine has been silent. Good luck and keep us posted!
10-13-2022, 08:52 PM | #69 |
Rep 565
Drives: G20 M340i
Aaaannnnddd, they couldn't get the chassis ears to pick it up…FML. Guess I'll wait till next supper when it warms up.
10-17-2022, 04:02 PM | #70 | |
Rep 565
Drives: G20 M340i
Anyways, I wound up loosening the swaybar link and re-torquing them to spec (this was with one side up on a jack). Took it back out and nothing! Maybe a coincidence? If your willing/can do it. Try doing this to see if it works for you. You will need a 16mm ratcheting wrench (or pass through socket) and a T30 torque bit to hold on to the link end. Google it for more details on how to remove/tighten nut. Pic of link I re-tightened: |
11-26-2022, 06:01 PM | #71 |
LawrenceG
Rep 1
Same knock on mine, plus just found oil leak
At around 8k the noise started. A clunking sound from the front left which I can just feel through the steering wheel.
The car is at 20k now, and I booked it in last week for a service in 2 weeks. Today, however, after moving the car out of my garage, I found an oil leak on the floor around the inside of where my front right wheel is parked. Clear clean oil, so I think it's some kind of hydraulic leak rather than engine oil. I've re-booked it in for tomorrow. This thread has been useful, and it appears that BMW have not done enough to educate their dealers on how to fix it. My clunking noise starts after I've had the car out on a trip, so is hot under the bonnet. Almost only at slow speeds, going over slightly imperfect road surfaces. The noise is now louder than it was. I think the reason many dealers haven't been able to replicate it is because the car isn't warm enough. I recommend that if you have this issue, give the car at least a half hour's run at motorway speed and get them to test it immediately. I'm hoping, they'll be able to fix mine. |
11-29-2022, 02:20 PM | #72 |
Rep 262
I have a front suspension clunk when reversing and turning full lock. The steering feel has been a bit "off" for a while as well. Dealer is replacing both front tension struts. We will see if that remedies my situation.
SportySpice204.00 |
11-29-2022, 03:20 PM | #73 | |
Rep 108
12-14-2022, 12:14 AM | #74 |
Rep 75
i have clunking/clattering on the right (mine is RHD 330i) on slow uneven roads or tapping brakes or turn steering to and fro in quick succession.
after different diagnosis it is found to have issue with the EPS. dealer is going to order part from germany to resolve the issue |
12-14-2022, 08:03 AM | #75 |
Rep 1,467
I had a drivers side suspension clunk. when putting that corner on a jack, I noticed it would pop. I took it to the dealer and told them how to reproduce it. They ended up replacing the top hat on the strut. I swear I still hear a noise but I can say the popping is gone when jacking up the car.
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
12-14-2022, 04:15 PM | #77 |
Rep 1,467
did the dealer perform this under warranty?
12-15-2022, 09:07 AM | #78 |
Rep 262
03-05-2023, 10:05 PM | #79 |
Rep 38
I have a 2023 M340i with adaptive and with 600 miles on it, started having the left front knocking sound. At the dealer at the moment but I am sure they will tell me it’s normal. Did anyone fully fix the issue?
03-10-2023, 05:11 PM | #80 | |
Rep 1,115
https://www.bimmerpost.com/forums/sh....php?t=1999946
03-10-2023, 07:40 PM | #81 |
Rep 565
Drives: G20 M340i
[QUOTE=peelerec;29923778]Update just released. Looks like an official service bulletin has been released.
https://www.bimmerpost.com/forums/sh....php?t=1999946 Just saw this too! Finally! Can this be the answer??? |
03-10-2023, 08:36 PM | #82 |
Rep 38
I got the car back today after over a week and they replaced both tie rods on the front left side. Drove home with no noise, and they did mention BMW was quick to tell them to change the tie rods out. I guess this came out while they had my car but weird it’s a 2023 having the same issue. Glad it is fixed and hopefully stays that way.
teknic9098.50 |
05-29-2023, 06:27 AM | #83 |
Rep 52
I have the same issue with mine only a week old. 2023 m340 adaptive suspension as well. Did anyone manage to come to a solution to this?
05-29-2023, 04:46 PM | #84 | |
Rep 1,467
If you have a Thyssen steering rack you can get the tie rod ends replaced under an SIB.
07-07-2023, 11:35 AM | #86 |
Rep 52
Had both my tie rod changed. And the clunking sound came back within 2-3 days 😓
07-09-2023, 06:21 PM | #87 |
Rep 1,467
07-10-2023, 05:50 PM | #88 |
Rep 4
Same Problem is Back
The left and right tie rod got replaced and the noises was gone for 1 month and it’s back again, anyone had success with different repair? Please advise
