04-14-2021, 10:29 AM | #23 | ||||
Rep 117
Again, thanks for sharing!! |
04-14-2021, 04:02 PM | #24 | |||||
Rep 255
Drives: BMW 320d g20
04-14-2021, 04:24 PM | #25 | ||||||
Rep 255
Found Fault in system for VIP control unit. Carried out programming to rectifiy." |
04-20-2021, 12:08 AM | #26 |
Rep 117
Thanks for the report, one last question, did you see in instrument cluster or idrive notification area, any error or message suggesting a VIP ecu error?
Is possible that here we're having exactly this issue without noticing it (no visible error or message) |
Jorge12123.50 |
06-26-2021, 11:12 AM | #27 |
1942
Rep 3,521
Just got to the service centre for an oil change since that was the only thing the car needed.
They read the key and apparently car asked for a rear brake pad change. Checked it out and pads were almost worn out. Car is at 13.8k miles at the moment. Pad life clearly sucks since I have other cars I drive harder with more mileage and zero brake pad issues.
06-26-2021, 12:39 PM | #28 |
Rep 8
I just picked up a M340i MPE and so I hope that's not the case. I just returned a 17 440i MPPSK with over 44,000km and never had to change the pads or rotors. Rears we're still at 7mm.
06-26-2021, 12:54 PM | #29 |
1942
Rep 3,521
Same. Sold my X3 at 35k miles and dealer asked of I never use the brakes since pads were like new. And this dealer said it's not the first G20 with this issue. He's seen many come in with the same complaints (premature pad wear).
09-23-2021, 04:33 AM | #30 | |
Rep 255
09-23-2021, 09:59 AM | #31 |
Rep 2,700
Problem seems to be too much size disparity between front and rear pads.
We are starting to see 2021+ M3/4 guys going trough a rear pad set in a day or two of track work..
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
09-24-2021, 07:56 AM | #32 |
Rep 32
There is a SIB 34 03 20 bulletin about non M brakes - check it.
This also explains why M brakes owners have no issues. https://www.tsbsearch.com/BMW/SI-B34-03-20
'20 BMW 330i M-Sport G21
ex - '16 BMW 320d M-Sport F30 LCI Last edited by radoslavp; 09-25-2021 at 11:16 AM.. |
09-24-2021, 11:04 AM | #33 |
Rep 117
09-24-2021, 02:45 PM | #34 |
Rep 32
The attached .pdf file in my original post should be enough - it is the official BMW document
ex - '16 BMW 320d M-Sport F30 LCI |
09-24-2021, 06:11 PM | #35 |
Rep 117
09-25-2021, 11:32 PM | #38 |
Rep 185
09-25-2021, 11:34 PM | #39 |
1942
Rep 3,521
Nope. Mine was discovered when the service advisor did a key read. Car apparently said rear pads were worn and needed to be replaced. Nothing on the idrive indicating that.
09-26-2021, 12:07 AM | #40 | |
Rep 185
06-22-2022, 08:01 AM | #41 |
Rep 51
My 2018 just had this rear brake wear issue.
Dealer replaced both rear calipers, pads and discs - @ 15500 miles and about 3 months out of warranty. Invoice cost was around £1200 GBP. |
03-31-2023, 10:07 PM | #44 |
Rep 1,115
Sounds like driver error or TC doing it’s job. I don’t believe it’s BMW error.
