12-21-2023, 07:16 PM | #89 | |
Rep 457
Thanks so much for your insight. Real-world tested feedback. I appreciate that.
So I'd be happy to try the Project Mu pads. I don't track the car, so pads last a long time, thus the decision is a serious one otherwise I am stuck with pads I don't like for a long time, or have to ditch them and try something else (which I have done before). The Project Mu pads you use for the street are PS pads. They seem like ceramic pads with no metal in them. You find them strong enough for the occasional spirited driving? I would guess they'd work really well from stone cold, as opposed to other more track focused pads (with metal) which, when cold may require more pedal pressure. That's the main issue I am trying to avoid - I would love a higher temp pad but that doesn't require extra pedal pressure when stone cold, because on a road car they are pretty much always cold, except in some spirited driving. I'd guess that pads like HC+ would not be as good cold. Quote:
12-21-2023, 07:27 PM | #90 | |
Rep 5,506
The oem Brembo pads for the m340i dusted too much. It was an on/off switch and hard to modulate smoothly. Stopping power was good but it was not a smooth pad. It also sometimes was sticky and you’d get a thump as it released the rotor from a stop. HC+ is getting into the track use pads category. It will squeak on street driving but otherwise ok for street. HC-CS is better in that it doesn’t make as much noise and has higher heat tolerance on track - trading off with lower braking torque. I run these on track as I don’t want to swap pads between track days. Project Mu has a whole range of these track pads that can be driven on the street.. it’s a category that’s often missed by more racing oriented companies. Even the club racer and racing 999 pads, you can street drive and the brake dust is wheel and paint friendly. I wouldn’t recommend for street as it’s noisy and dusty but it’s doable. You can get very fine with just how much civility you want to trade off for track ability. A step in between the project mu PS and HC, the Endless MX72 is good. Just don’t track the mx72.. it has issues with high heat.
Auto Detailing Enthusiast!
12-21-2023, 07:35 PM | #91 | |
Rep 457
Any recommendations on rotors - there doesn't seem to be a lot of choice. Are the OEM rotors fine, or are there better alternatives? Again, really appreciate your insight. |
12-21-2023, 07:41 PM | #92 | |
Rep 5,506
Stock rotors are fine. If yours are in good condition, keep using them. Slotted cleans the pads for track use. Drilled is supposed to cool the brakes better. Both reduce rotor surface area which is not good for actual braking power. On the street you’re not going to overheat brakes and need pad cleaning between stops so these have little use. Not to mention noisy on the street. If you need to replace the rotors, get oem or other quality rotor like Brembo or Centric high carbon ones.
cyam188.50 |
12-21-2023, 08:00 PM | #93 | |
Rep 1,114
12-21-2023, 08:13 PM | #94 | |
Rep 5,506
There’s a lot of vendors that sell them in the US as well. Just Google endless pads for a90 Supra and you’ll find a bunch. Most of them will be the mx72 street pads. If you want something more specialized like CCRG or ME20 track pads, the Japanese vendors can get it easily. US distribution is pretty slow for special orders as they do sea shipping from Japan. It can take up to 1/2 year to get brake pads.
12-21-2023, 08:27 PM | #95 | |
Rep 1,114
12-22-2023, 03:47 AM | #96 |
Rep 562
This thread really should be stickied. Lots of good info the last few days.
I’m going to try the Endless MX72+ this spring. Should be a good mix for street plus a couple trips down to the Ring. |
12-22-2023, 12:04 PM | #97 | |
Rep 102
Drives: M440i xdrive, X5, Acura MDX
12-22-2023, 12:26 PM | #98 | |
Rep 5,506
For Project Mu, you can find any pad by going by the pad shape part number and the desired pad compound. For the normal M340i Brembo brakes, front the pad shape is Z723. Rear is Z625. Here is the fronts, The "Euro Sports Excellence" is the same pad with a different name for European markets. Evasive is in California so if it is in stock you can get it within days. https://www.evasivemotorsports.com/s...0u-hWzqOnVhz2I Front Type PS: https://www.rhdjapan.com/project-mu-...k-package.html https://www.blackhawkjapan.com/produ...z723-type-ps-7 Type PS rear: https://www.rhdjapan.com/project-mu-...k-package.html https://www.blackhawkjapan.com/produ...u-z625-type-ps
12-22-2023, 01:41 PM | #99 | |
Rep 5,506
Normal MX72 is a good street pad but should not be driven on track. I had bad experiences with it on track. The pad compound melts at high temperatures and warps rotors. CC-RG is a step above the MX72 Plus. I used this before. It does squeal under street driving. But on track it is a good pad with high torque and fade resistance. It is pretty similar to the Project Mu HC+. There is a new MX87.. it looks like a new upgraded MX72 replacement? Just introduced new in 2023.
12-22-2023, 01:59 PM | #100 |
Rep 5,506
Quick google on the new MX87 pads. This is a post from the Porsche forums.
Kind of makes sense. MX72 is a 15+ year old pad compound. MX72 plus is newer compound with more torque and heat control. MX87 might be hard to get because it is only available OUTSIDE of Japan. Availability is totally up to local distributors.
12-22-2023, 03:59 PM | #101 | |
Rep 102
12-22-2023, 04:20 PM | #102 | |
Rep 5,506
Bimmerworld has a article on the G series brakes: https://www.bimmerworld.com/About-Us...rakes-G20-G22/ You may want to measure your brake discs as the article shows to make certain or find the exact brake kit option code based on your VIN. BMW M340/440i only have two different brake pad shapes for the front. It will be one or the other. One complication in mid 2022+ cars with the normal Brembo brakes use the same pads but they changed the retaining pin location so you may have to drill a hole on the pad backing plate to make it fit. Really weird but Brembo does weird things. 2022+ hole location: Before 2022 location:
12-22-2023, 04:29 PM | #103 | |
Rep 102
What’s another similar option without having to drill? |
12-22-2023, 04:40 PM | #104 | |
Rep 5,506
For the regular Brembo brakes, I don't see many options for the 2022+ front brakes outside of OEM. Aftermarket support will be limited since it is so new.
Gryph8n25.50 |
12-22-2023, 05:21 PM | #106 | |
Rep 5,506
It's not uncommon for brake pads to do this. Brembo is not alone with this issue. But it is a bit annoying in a street car.
12-30-2023, 07:40 PM | #107 |
Rep 457
Does anyone know the minimum thickness for the rotors on M Sport?
So the nominal thickness is 36mm front and 24mm rear, but what is the minimum thickness allowed? I am trying to figure how much the first set of pads have worn the rotors down to see if a second set will wear them past the minimum thickness (after skimming). |
12-31-2023, 03:51 PM | #108 |
Rep 185
Z K So you would recommend either Project Mu HC+ or HC-CS for dual track/street use? I don't want to change my pads between track days and don't mind some squealing on street. I'm also admittingly very lazy with cleaning up brake dust, and I don't want to worry about any ill effects. What about on the Endless side for similar use? I have a race shop nearby that sells Endless and Pagid and so I could probably source from them.
01-12-2024, 06:59 PM | #109 | |
Rep 5,506
Edit: Here's Club Racers in stock: https://www.evasivemotorsports.com/s...a-a90-30-2020/ https://www.evasivemotorsports.com/s...-caliper-2020/ Endless, you probably want a MX72 Plus or higher like a CC-RG or ME20/22 pad. Do not use the normal MX72 on track.
prostcfc56.50 |
01-17-2024, 11:10 AM | #110 | |
Rep 185
