11-30-2022, 09:03 PM | #23 |
Rep 255
Drives: BMW 320d g20
First rear pad change at 28000 km. 20,000 km later they are now at 4 mm again. Replaced them. At this rate I will have to replace brakes every 18 months at $1200 aud. I have the dealer the service bulletin for Bmw Australia. They rejected it saying Australian cars do not have this problem.
12-05-2022, 03:31 AM | #24 |
Rep 255
Can some one check something for me please. While driving on a highway, take the foot off the accelerator, do not press the brakes. Please see whether the car automatically starts applying regenerative braking while cruising? You can check that on your digital instrument panel (toggle via BC until you see the fuel economy display). Mine clearly shows regenerative braking (blue line indicating battery charging) not sure if this is intentional or proof of residual braking. Thanks
12-05-2022, 08:32 AM | #25 | |
Rep 15,858
You don't need the brakes to harvest energy to the battery, it is triggered by foot off the throttle, on the over-run. Been this way since Efficient Dynamics features were introduced. From my own vehicle, and watching the voltage real-time, that can also increase, showing there is a charge on the over-run. No braking required. The rapid rear brake wear rate, according to the TSB, is a build tolerance issue. Is a mechanical problem. Interprets as extra pad resistance, not freeing off the rear service brakes. The extra drag, equals a rapid pad wear rate. |
francton126.50 |
12-05-2022, 05:14 PM | #26 | ||
Rep 255
HighlandPete6658.50 |
12-06-2022, 04:50 AM | #27 |
Rep 255
I've now booked a paid service with a dealer to examine rear calipers , specifically the tolerances mentioned in the SIB. I'm not holding my breath but it's the last straw really.
01-16-2023, 05:36 AM | #28 |
Rep 255
How many miles should rear brakes ( standard not brembo) last if mostly driven on winding roads? Fast but safe driving not track stuff.
01-16-2023, 06:11 AM | #29 | |
Rep 15,858
Hope you get a few examples of similar use. |
francton126.50 |
01-16-2023, 06:18 AM | #30 |
Rep 255
I’m having to replace my rear brakes every 25k km. It’s either the reported defect with the brakes calipers (there is an SIB) or it’s the dsc kicking in. Hopefully will get some examples from people who live in the hills. By the way is there some indication when dsc kicks in? Is there an audible sound from the wheel where it kicks in?
01-16-2023, 06:44 AM | #31 | |
Rep 15,858
No, you don't know when the DSC is intervening. The only way to possibly detect, intervention is drive the same road with and without DTC engaged. You may sense a slight change in chassis balance between full DSC control and using DTC. DTC feeling a bit more agile. |
francton126.50 |
01-25-2023, 04:03 PM | #32 |
Rep 255
Not getting much traction from BMW in addressing my break wear issue. Is it safe to replace the rear brakes calipers through a third party mechanic instead of a bmw dealer?
02-01-2023, 01:50 PM | #33 |
Rep 255
Is it safe to replace brakes and rotors through a third party mechanic (not via the dealer)
03-18-2023, 03:55 AM | #34 |
Rep 1
Strange coincidence.. or not perhaps.
Hi, just joined the forum.
I have a 1 year old 320i Msport and oddly enough my rear pads are gone. Had the service warning and dealer confirms that pads are down to 1mm. Car has done 13k miles. Should I just pay or push for a warranty replacement. Thanks |
