02-19-2023, 04:21 PM | #1 |
Rep 54
G20 2 or 3 Piece Strut Brace
Has anyone found a 3 piece strut brace for the g20? I've been searching around and found this one from KC Design and a small thread about it. Would a 2 piece one like dinan/bms be good enough? Rigidity of a 3 piece sounds better just don't like how the KC one is the o ly available one / not a lot of reviews.
https://www.tw-kcdesign.com/products_detail/46 |
02-19-2023, 05:27 PM | #2 |
Rep 351
Drives: 2023 M340i
That looks like a 4 piece.
02-20-2023, 11:47 AM | #3 |
Rep 54
I think it has the option of going 4 piece if you buy this
https://www.tw-kcdesign.com/products_detail/47 But that first link is just the 2 angled braces and that flat horizontal one. I guess my question was am I over thinking wanting a 3 point brace or is something like dinan/BMS 2 point brace good enough? |
02-20-2023, 02:20 PM | #5 | |
Rep 351
Drives: 2023 M340i
02-20-2023, 03:04 PM | #6 |
Rep 54
02-20-2023, 05:01 PM | #7 |
Rep 4,143
I'm talking about the link provided where it shows 3 or 4 pieces of metal and at the bottom it says weight 1.3kg
4 pieces of metal weighing 1.3kg isn't going to stop the front of the car from twisting. but i'm not sure i have not load tested the metals. but if they are stiffer than your car already is, then it will work. if not, you are just adding dead weight for no benefit. |
02-21-2023, 09:28 AM | #9 |
Rep 1,521
Take a look at the below. CPM makes one of the best strut braces on the market.
https://g20.bimmerpost.com/forums/sh....php?t=1747162 https://www.blackhawkjapan.com/products/cpm-csrb-b205 |
1WickedE90198.00 |
02-21-2023, 07:37 PM | #10 | |
Rep 1,009
That is a good-looking setup & functional as well.
Chubbiejones891.00 |
02-21-2023, 08:53 PM | #11 | |
Rep 351
Drives: 2023 M340i
Also does the front horizontal brace do anything? |
02-22-2023, 11:48 AM | #12 |
Rep 54
I'll let you know, I'm sure it comes with some bolts for that price. I ordered the front brace, arriving in about 2 weeks.
02-22-2023, 12:11 PM | #13 | |
Rep 1,521
1WickedE90198.00 |
03-02-2023, 09:06 PM | #14 |
Rep 54
Installed them today, took maybe 30 min at the most. Lay out the bars, jack up one corner & start the bolts, lowe & do the same for the other side. Then do the middle bolts.
I mis read the torque spec and snapped the two middle bolts surprisingly... I didn't even think it was that much, but picked up 2 grade 8.8 bolts to replace them. |
Chubbiejones891.00 dancing__narwhal141.50 |
03-03-2023, 06:09 PM | #15 | |
Rep 1,521
03-03-2023, 07:16 PM | #16 |
Rep 54
Fit was good, everything lined up perfectly. Haven't had time to go out for a drive & test it yet, but will do this weekend. I like how the brand name isn't as in your face as Dinan's. I ordered from their amazon store and came earlier than expected. Took about 7 business days.
I don't like that the radiator shroud is silver, but I also don't want to buy a carbon fiber shroud lol. Black underneath would make it pop more. |
03-03-2023, 07:31 PM | #17 | |
Rep 351
Drives: 2023 M340i
Is the install the same as all others with nut and bolt? |
03-04-2023, 07:51 PM | #18 | |
Rep 1,521
03-08-2023, 12:26 PM | #19 | |
Rep 54
The install is the same as others, bolt through the hole on the top of the strut tower & on the radiator area. |
03-08-2023, 01:56 PM | #20 | |
Rep 351
Drives: 2023 M340i
03-08-2023, 09:32 PM | #21 | |
Rep 54
https://www.blackhawkjapan.com/search?page=2&q=cpm |
03-08-2023, 10:04 PM | #22 | |
Rep 351
Drives: 2023 M340i
kapa112241.50 |
